add(Lump *lump) | CompositeLump | |
add(CompositeShell *shell) | CompositeLump | |
append_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeLump | [virtual] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const | CompositeLump | [virtual] |
bridge_destroyed(TopologyBridge *bridge) | TBOwner | [inline, virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
ChildType typedef | Lump | |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
combine(CompositeLump *dead_vol) | CompositeLump | |
compGeom | CompositeLump | [private] |
CompositeBody class | CompositeLump | [friend] |
CompositeLump(Lump *real_lump) | CompositeLump | |
CompositeLump(CompositeGeom *geom) | CompositeLump | |
contains_bridge(TopologyBridge *bridge) const | CompositeLump | [virtual] |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
first_shell() const | CompositeLump | [inline] |
firstShell | CompositeLump | [private] |
geometry_type() | Lump | [inline, virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_body() const | CompositeLump | [inline] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &children) | CompositeLump | [virtual] |
get_geometry_query_engine() const | CompositeLump | [virtual] |
get_hidden_surfaces(DLIList< Surface * > &surfaces) | CompositeLump | |
get_lump(int index) const | CompositeLump | [inline] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &parents) | CompositeLump | [virtual] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_simple_attribute(DLIList< CubitSimpleAttrib > &attrib_list) | CompositeLump | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list) | CompositeLump | [virtual] |
has_hidden_entities() const | CompositeLump | |
hidden_entities() | CompositeLump | [inline] |
hiddenSet | CompositeLump | [private] |
index_of(Lump *) const | CompositeLump | [inline] |
layer() const | CompositeLump | [inline, virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
Lump() | Lump | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
mass_properties(CubitVector ¢roid, double &volume) | CompositeLump | [virtual] |
Lump::mass_properties(CubitVector[3], CubitVector &, CubitVector &, double &) | Lump | [inline, virtual] |
MAX_TB_LAYER enum value | TopologyBridge | |
measure() | CompositeLump | [virtual] |
myBody | CompositeLump | [private] |
next_shell(CompositeShell *after_this) const | CompositeLump | [inline] |
nextLump | CompositeLump | [private] |
notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_reversed(TopologyBridge *bridge) | CompositeLump | [virtual] |
notify_split(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
num_lumps() const | CompositeLump | [inline] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
print_debug_info(const char *line_prefix=0, bool brief=false) | CompositeLump | |
remove(Lump *lump) | CompositeLump | |
remove(CompositeShell *shell) | CompositeLump | |
remove_all_simple_attribute_virt() | CompositeLump | [virtual] |
remove_bridge(TopologyBridge *bridge) | CompositeLump | [virtual] |
remove_lump(int index) | CompositeLump | |
remove_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeLump | [virtual] |
reverse_bridge_sense() | TopologyBridge | [inline] |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
split(VGArray< int > &indices_to_move) | CompositeLump | |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
swap_bridge(TopologyBridge *old_tb, TopologyBridge *new_tb, bool) | CompositeLump | [virtual] |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
update() | CompositeLump | [inline] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~CompositeLump() | CompositeLump | [virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~Lump() | Lump | [virtual] |
~TBOwner() | TBOwner | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
