add(CompositeLoop *loop) | CompositeSurface | |
add(CompositeCoSurf *cosurf) | CompositeSurface | |
append_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeSurface | [virtual] |
are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list) | Surface | [virtual] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const | CompositeSurface | [virtual] |
bridge_destroyed(TopologyBridge *bridge) | TBOwner | [inline, virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
ChildType typedef | Surface | |
closest_point(CubitVector const &location, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL, CubitVector *curvature1=NULL, CubitVector *curvature2=NULL) | CompositeSurface | [virtual] |
closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface) | CompositeSurface | [virtual] |
closest_point_trimmed(CubitVector from_point, CubitVector &result) | CompositeSurface | [virtual] |
closest_point_uv_guess(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL) | CompositeSurface | [virtual] |
closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL) | Surface | [virtual] |
closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list) | Surface | [virtual] |
closest_trimmed(int underlying_surface, const CubitVector &position, CubitVector &result) | CompositeSurface | [protected] |
closest_underlying_surface(const CubitVector &position) | CompositeSurface | |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
combine(CompositeSurface *dead_surface) | CompositeSurface | |
compGeom | CompositeSurface | [private] |
CompositeEngine class | CompositeSurface | [friend] |
CompositeSurface(Surface *surf_ptr) | CompositeSurface | |
CompositeSurface(CompositeGeom *geom_ptr) | CompositeSurface | |
CompositeSurface(const CompositeSurface &) | CompositeSurface | [private] |
contains_bridge(TopologyBridge *bridge) const | CompositeSurface | [virtual] |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2) | CompositeSurface | [virtual] |
Surface::evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3]) | Surface | [virtual] |
facetTool | CompositeSurface | [private] |
find_first(CompositeShell *shell) const | CompositeSurface | |
find_first(CompositeLump *lump) const | CompositeSurface | |
find_next(CompositeCoSurf *cosurf) const | CompositeSurface | |
first_loop() const | CompositeSurface | [inline] |
firstCoSurf | CompositeSurface | [private] |
firstLoop | CompositeSurface | [private] |
geometry_type() | CompositeSurface | [virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &children) | CompositeSurface | [virtual] |
get_cone_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const | CompositeSurface | [virtual] |
get_curves(DLIList< CompositeCurve * > &curves) | CompositeSurface | |
get_geometry_query_engine() const | CompositeSurface | [virtual] |
get_geometry_sense() | CompositeSurface | [virtual] |
get_graphics(GMem &gmem) | CompositeSurface | |
get_hidden_curves(DLIList< Curve * > &curves) | CompositeSurface | |
get_ignored_surfs(DLIList< Surface * > &surfs) | CompositeSurface | |
get_nurb_params(bool &rational, int °ree_u, int °ree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const | CompositeSurface | [virtual] |
get_param_range_U(double &lower, double &upper) | CompositeSurface | [virtual] |
get_param_range_V(double &lower, double &upper) | CompositeSurface | [virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &parents) | CompositeSurface | [virtual] |
get_point_normal(CubitVector &origin, CubitVector &normal) | CompositeSurface | [virtual] |
get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance) | CompositeSurface | [virtual] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_sense(int index) const | CompositeSurface | [inline] |
get_shell_sense(ShellSM *shell_ptr) const | CompositeSurface | [virtual] |
get_simple_attribute(DLIList< CubitSimpleAttrib > &attrib_list) | CompositeSurface | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list) | CompositeSurface | [virtual] |
get_sphere_params(CubitVector ¢er, double &radius) const | CompositeSurface | [virtual] |
get_stitch_partner() const | CompositeSurface | [inline] |
get_surface(int index) const | CompositeSurface | [inline] |
get_torus_params(CubitVector ¢er, CubitVector &normal, double &major_radius, double &minor_radius) const | CompositeSurface | [virtual] |
get_uv_sense() | Surface | [inline, virtual] |
HadBridgeRemoved | CompositeSurface | [private] |
has_hidden_entities() const | CompositeSurface | |
hidden_entities() | CompositeSurface | [inline] |
hiddenSet | CompositeSurface | [private] |
ignore_surface(int surface_id) | CompositeSurface | |
ignore_surface(Surface *surf) | CompositeSurface | |
index_of(Surface *surface) const | CompositeSurface | [inline] |
is_closed_in_U() | CompositeSurface | [virtual] |
is_closed_in_V() | CompositeSurface | [virtual] |
is_cylindrical() | Surface | [inline, virtual] |
is_dead_coedge(CompositeCoEdge *coedge) | CompositeSurface | [protected] |
is_parametric() | CompositeSurface | [virtual] |
is_periodic() | CompositeSurface | [virtual] |
is_periodic_in_U(double &period) | CompositeSurface | [virtual] |
is_periodic_in_V(double &period) | CompositeSurface | [virtual] |
is_position_on(CubitVector &position) | CompositeSurface | [virtual] |
is_singular_in_U(double u_value) | CompositeSurface | [virtual] |
is_singular_in_V(double v_value) | CompositeSurface | [virtual] |
layer() const | CompositeSurface | [inline, virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
MAX_TB_LAYER enum value | TopologyBridge | |
measure() | CompositeSurface | [virtual] |
next_co_surface(CompositeCoSurf *prev=0) const | CompositeSurface | [inline] |
next_loop(CompositeLoop *after_this=0) const | CompositeSurface | [inline] |
notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_reversed(TopologyBridge *bridge) | CompositeSurface | [virtual] |
notify_split(TopologyBridge *new_bridge, TopologyBridge *old_bridge) | CompositeSurface | [virtual] |
notify_topology_modified(TopologyBridge *bridge) | CompositeSurface | [virtual] |
notify_transformed() | CompositeSurface | |
num_surfs() const | CompositeSurface | [inline] |
operator=(const CompositeSurface &) | CompositeSurface | [private] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
param_dir(CubitVector &, CubitVector &, double &, double &) | Surface | [inline, virtual] |
point_containment(const CubitVector &point) | CompositeSurface | [virtual] |
point_containment(double u, double v) | CompositeSurface | [virtual] |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
position_from_u_v(double u, double v) | CompositeSurface | [virtual] |
principal_curvatures(CubitVector const &location, double &curvature_1, double &curvature_2, CubitVector *closest_location) | CompositeSurface | [virtual] |
print_cpt_stats() | CompositeSurface | [static] |
print_debug_info(const char *line_prefix=0, bool brief=false) | CompositeSurface | |
read_attributes() | CompositeSurface | [inline] |
remove(CompositeLoop *loop) | CompositeSurface | |
remove(CompositeCoSurf *cosurf) | CompositeSurface | |
remove_all_simple_attribute_virt() | CompositeSurface | [virtual] |
remove_bridge(TopologyBridge *bridge) | CompositeSurface | [virtual] |
remove_dead_coedge(CompositeCoEdge *coedge) | CompositeSurface | [protected] |
remove_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeSurface | [virtual] |
remove_surface(int index) | CompositeSurface | |
reset_cpt_stats() | CompositeSurface | [static] |
reverse_bridge_sense() | TopologyBridge | [inline] |
reverse_sense() | CompositeSurface | [virtual] |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
split(VGArray< int > &indices_to_move) | CompositeSurface | |
stitch(CompositeSurface *stitch_partner) | CompositeSurface | |
stitchPartner | CompositeSurface | [private] |
Surface() | Surface | |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfacesToIgnore | CompositeSurface | [private] |
swap_bridge(TopologyBridge *old_tb, TopologyBridge *new_tb, bool reversed) | CompositeSurface | [virtual] |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
u_v_from_position(CubitVector const &position, double &u, double &v, CubitVector *closest_point) | CompositeSurface | [virtual] |
unignore_surface(int surface_id) | CompositeSurface | |
unstitch() | CompositeSurface | |
update() | CompositeSurface | [inline] |
update_facet_tool() | CompositeSurface | [protected] |
update_facets_to_ignore() | CompositeSurface | [protected] |
update_modified(Surface *modified_surface, DLIList< CompositeCurve * > &new_curves) | CompositeSurface | [protected] |
update_modified() | CompositeSurface | [protected] |
uv_derivitives(double u, double v, CubitVector &du, CubitVector &dv) | CompositeSurface | [virtual] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
write_attributes() | CompositeSurface | [inline] |
~CompositeSurface() | CompositeSurface | [virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~Surface() | Surface | [virtual] |
~TBOwner() | TBOwner | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
