cgma
CubitFacetEdge Member List
This is the complete list of members for CubitFacetEdge, including all inherited members.
add_facet(CubitFacet *)CubitFacetEdge [inline, virtual]
add_facets()CubitFacetEdge
add_TD(ToolData *new_td)ToolDataUser [virtual]
adj_facet(int index)=0CubitFacetEdge [pure virtual]
adj_facet_on_surf(int tool_id)CubitFacetEdge
angle_between_facets()CubitFacetEdge
bezier_order()CubitFacetEdge [inline, virtual]
bezierOrderCubitFacetEdge [protected]
boundary_edge_points(CubitPoint *&pt0, CubitPoint *&pt1, int tool_id=0)CubitFacetEdge
bounding_box()CubitFacetEdge
center()CubitFacetEdge [inline]
closest_point(const CubitVector &point, CubitVector &closest_point)CubitFacetEdge
contains(CubitPoint *point_ptr)CubitFacetEdge
control_points(CubitVector *ctrl_pts)CubitFacetEdge [virtual]
control_points()CubitFacetEdge [inline, virtual]
control_points(CubitVector *ctrl_pts, int order)CubitFacetEdge [inline, virtual]
control_points(CubitFacet *facet, CubitVector *ctrl_pts)CubitFacetEdge [virtual]
controlPointsCubitFacetEdge [protected]
CubitFacetEdge()CubitFacetEdge
debug_draw(int color=-1, int flush=1, int draw_uv=0)CubitFacetEdge [virtual]
delete_TD(IdentityFn specified_type)ToolDataUser [virtual]
delete_TD(ToolData *td)ToolDataUser [virtual]
dist_to_edge(const CubitVector &this_point, CubitVector &close_point, CubitBoolean &outside_edge)CubitFacetEdge
edge_curvature(const CubitVector &point_on_edge, CubitVector &curvature, CubitFacetEdge *closest_edge)CubitFacetEdge
edge_tangent(const CubitVector &point_on_edge, CubitVector &tangent)CubitFacetEdge
edges(DLIList< CubitFacetEdge * > &edge_list)=0CubitFacetEdge [pure virtual]
end_node()=0CubitFacetEdge [pure virtual]
evaluate(double &t, CubitVector *eval_point, CubitVector *eval_tangent)CubitFacetEdge
evaluate_2nd_derivative(double &t, CubitVector *outv)CubitFacetEdge
evaluate_position(const CubitVector &start_position, CubitVector *eval_point, CubitVector *eval_tangent)CubitFacetEdge
evaluate_single(double &t, CubitVector *outv)CubitFacetEdge
evaluate_single_tangent(double &t, CubitVector *outv)CubitFacetEdge
FacetEntity()FacetEntity
facets(DLIList< CubitFacet * > &facet_list)=0CubitFacetEdge [pure virtual]
find_start_point_for_edge_list(DLIList< CubitFacetEdge * > edge_list)CubitFacetEdge [static]
flip()=0CubitFacetEdge [pure virtual]
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_all_TDs(DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_control_points(CubitPoint *point_ptr, CubitVector ctrl_pts[3])CubitFacetEdge [inline, virtual]
get_flag()CubitFacetEdge [inline, virtual]
get_parents(DLIList< FacetEntity * > &facet_list)CubitFacetEdge [virtual]
get_TD(IdentityFn specified_type)ToolDataUser [virtual]
get_TD(IdentityFn specified_type) const ToolDataUser [virtual]
id()=0CubitFacetEdge [pure virtual]
intersect(CubitVector &aa, CubitVector &bb, CubitVector &norm, CubitVector &qq, CubitBoolean &does_intersect)CubitFacetEdge
intersect_2D_segments(double P0[2], double P1[2], double P2[2], double P3[2], double qq[4])CubitFacetEdge [static]
intersect_intervals(double u0, double u1, double v0, double v1, double w[2])CubitFacetEdge [static]
is_feature()CubitFacetEdge [inline]
is_flipped()CubitFacetEdge [inline]
is_flipped(int flipped)CubitFacetEdge [inline]
isFeatureCubitFacetEdge [protected]
isFlippedCubitFacetEdge [protected]
length()CubitFacetEdge
less_than(CubitFacetEdge *&e1, CubitFacetEdge *&e2)CubitFacetEdge [inline]
marked(int my_flag)CubitFacetEdge [inline, virtual]
marked()CubitFacetEdge [inline, virtual]
markedFlagCubitFacetEdge [protected]
num_adj_facets()=0CubitFacetEdge [pure virtual]
num_adj_facets_on_surf(int tool_id)CubitFacetEdge
number_faces()CubitFacetEdge [inline, virtual]
number_tris()CubitFacetEdge [inline, virtual]
order_edge_list(DLIList< CubitFacetEdge * > &edge_list, CubitPoint *start_point, CubitPoint *&end_point)CubitFacetEdge [static]
other_facet(CubitFacet *facet_ptr)CubitFacetEdge
other_facet_on_surf(CubitFacet *facet_ptr)CubitFacetEdge
other_point(CubitPoint *point_ptr)CubitFacetEdge
point(int index)=0CubitFacetEdge [pure virtual]
points(DLIList< CubitPoint * > &point_list)=0CubitFacetEdge [pure virtual]
position_from_fraction(double zero_to_one)CubitFacetEdge
proj_to_line(const CubitVector &this_point, CubitVector &proj_point)CubitFacetEdge
remove_facet(CubitFacet *)=0CubitFacetEdge [pure virtual]
remove_TD(IdentityFn specified_type)ToolDataUser [virtual]
remove_TD(ToolData *td)ToolDataUser [virtual]
set_as_feature()CubitFacetEdge [inline]
set_control_points(CubitPoint *point_ptr, CubitVector ctrl_pts[3])CubitFacetEdge [inline, virtual]
set_control_points(const double *ctrl_pt_array)CubitFacetEdge
set_flag(int my_flag)CubitFacetEdge [inline, virtual]
set_id(int)CubitFacetEdge [inline, virtual]
shared_point(CubitFacetEdge *edge_ptr)CubitFacetEdge
start_node()=0CubitFacetEdge [pure virtual]
toggle_is_flipped()CubitFacetEdge [inline]
ToolDataUser()ToolDataUser [inline]
tris(DLIList< CubitFacet * > &facet_list)CubitFacetEdge [inline]
tris(int *, DLIList< CubitFacet * > &facet_list)CubitFacetEdge [inline]
~CubitFacetEdge()CubitFacetEdge [virtual]
~FacetEntity()FacetEntity [virtual]
~ToolDataUser()ToolDataUser [virtual]
