cgma
CubitPointData Member List
This is the complete list of members for CubitPointData, including all inherited members.
add_facet(CubitFacet *facet)CubitPointData [virtual]
add_TD(ToolData *new_td)ToolDataUser [virtual]
adjacent_points(CubitPoint **adj_points, int &num_adj_points)CubitPoint
adjacent_points(DLIList< CubitPoint * > &result_list)CubitPoint
attachedFacetsCubitPointData [private]
bounding_box()CubitPoint
check_inverted_facets(const CubitVector &new_position)CubitPoint
coef_vector()CubitPoint [inline, virtual]
coef_vector(const CubitMatrix &coef)CubitPoint [inline, virtual]
coefVectorCubitPoint [protected]
collapse_edge(CubitPointData *dead_point)CubitPointData
compute_avg_normal()CubitPointData
coordinates() const CubitPointData [inline, virtual]
coordinates(double point_array[3])CubitPointData [virtual]
coordsCubitPointData [private]
CubitPoint()CubitPoint
CubitPointData(double x_val, double y_val, double z_val)CubitPointData
CubitPointData(double x_val, double y_val, double z_val, int *)CubitPointData
CubitPointData(const CubitVector &new_point)CubitPointData
d_coef(const double d_coefficient)CubitPoint [inline, virtual]
d_coef()CubitPoint [inline, virtual]
dCoefCubitPoint [protected]
debug_draw(int color=-1, int flush=1, int draw_uv=0)CubitPoint [virtual]
define_tangent_vectors()CubitPoint
delete_TD(IdentityFn specified_type)ToolDataUser [virtual]
delete_TD(ToolData *td)ToolDataUser [virtual]
du(CubitVector &duvec)CubitPoint [inline, virtual]
du()CubitPoint [inline, virtual]
dv(CubitVector &dvvec)CubitPoint [inline, virtual]
dv()CubitPoint [inline, virtual]
edges(DLIList< CubitFacetEdge * > &edge_list)CubitPointData [virtual]
entityIdCubitPointData [private]
FacetEntity()FacetEntity
facets(DLIList< CubitFacet * > &facet_list)CubitPointData [inline, virtual]
facets_on_surf(int surf_id, DLIList< CubitFacet * > &facet_list, CubitBoolean &on_internal_boundary)CubitPoint
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_all_TDs(DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_edge(CubitPoint *other_point)CubitPoint
get_parents(DLIList< FacetEntity * > &facet_list)CubitPoint [virtual]
get_TD(IdentityFn specified_type)ToolDataUser [virtual]
get_TD(IdentityFn specified_type) const ToolDataUser [virtual]
get_uv(CubitFacet *facet, double &u, double &v)CubitPoint [virtual]
get_uvs(CubitFacet *facet, double &u, double &v, double &s)CubitPoint [virtual]
id()=0CubitPoint [pure virtual]
is_feature()CubitPoint [inline]
isFeatureCubitPoint [protected]
marked(int marked)CubitPointData [inline, virtual]
marked()CubitPointData [inline, virtual]
markedFlagCubitPoint [protected]
memoryManagerCubitPointData [private, static]
merge_points(CubitPoint *dead_point, CubitBoolean keep_point=CUBIT_FALSE)CubitPointData [virtual]
next_feature_edges(CubitFacetEdge *this_edge_ptr, DLIList< CubitFacetEdge * > feature_edge_list)CubitPoint
normal(CubitVector &surf_norm)CubitPoint [inline, virtual]
normal()CubitPoint [inline, virtual]
normal(CubitFacet *facet_ptr)CubitPoint
normal(CubitQuadFacet *qfacet_ptr)CubitPoint
normal(CubitFacetEdge *edge_ptr)CubitPoint
normal_ptr()CubitPoint [inline, virtual]
num_adj_facets()CubitPointData [virtual]
points(DLIList< CubitPoint * > &point_list)CubitPointData [inline, virtual]
project_to_tangent_plane(CubitVector &pt)CubitPoint
remove_facet(CubitFacet *facet)CubitPointData [virtual]
remove_TD(IdentityFn specified_type)ToolDataUser [virtual]
remove_TD(ToolData *td)ToolDataUser [virtual]
reset_normal()CubitPoint [inline, virtual]
rotate_normal(CubitTransformMatrix &rotmat)CubitPoint
set(const CubitVector &pos)CubitPointData [inline, virtual]
set_as_feature()CubitPoint [inline]
set_box_tol(double tol)CubitPoint [inline, static]
set_id(int new_id)CubitPointData [inline, virtual]
set_normal(CubitVector &surf_norm)CubitPoint [inline, virtual]
set_uv(double u, double v)CubitPoint [inline, virtual]
set_uvs(double u, double v, double s)CubitPoint [inline, virtual]
SetDynamicMemoryAllocation(memoryManager) int id()CubitPointData [inline]
shared_edge(CubitPoint *other_point)CubitPoint
shared_facets(CubitPoint *other_point, CubitFacet *&facet1, CubitFacet *&facet2)CubitPoint
shared_facets(CubitPoint *other_point, DLIList< CubitFacet * > &result_list)CubitPoint
size()CubitPoint [inline, virtual]
sizeValCubitPoint [protected]
surfNormalCubitPoint [protected]
surfUCubitPoint [protected]
surfVCubitPoint [protected]
tangent(CubitFacetEdge *edge_ptr, double mindot)CubitPoint
ToolDataUser()ToolDataUser [inline]
transform(CubitTransformMatrix &tfmat)CubitPoint
transform_to_global(CubitVector &loc_vec, CubitVector &glob_vec)CubitPoint
transform_to_local(CubitVector &glob_vec, CubitVector &loc_vec)CubitPoint
tris(DLIList< CubitFacet * > &facet_list)CubitPointData [inline, virtual]
uValCubitPoint [protected]
vValCubitPoint [protected]
x()CubitPointData [inline, virtual]
y()CubitPointData [inline, virtual]
z()CubitPointData [inline, virtual]
~CubitPoint()CubitPoint [virtual]
~CubitPointData()CubitPointData
~FacetEntity()FacetEntity [virtual]
~ToolDataUser()ToolDataUser [virtual]
