cgma
CubitQuadFacet Member List
This is the complete list of members for CubitQuadFacet, including all inherited members.
add_TD(ToolData *new_td)ToolDataUser [virtual]
CubitQuadFacet()CubitQuadFacet
debug_draw(int color=-1, int flush_it=1, int draw_uv=0)CubitQuadFacet [virtual]
delete_TD(IdentityFn specified_type)ToolDataUser [virtual]
delete_TD(ToolData *td)ToolDataUser [virtual]
edge(int index)=0CubitQuadFacet [pure virtual]
edges(DLIList< CubitFacetEdge * > &edge_list)CubitQuadFacet [virtual]
eval_derivatives(double u, double v, CubitVector &point, CubitVector &du, CubitVector &dv)CubitQuadFacet [private]
evaluate(double u, double v, CubitVector *eval_point, CubitVector *eval_normal=NULL, CubitVector *eval_du=NULL, CubitVector *eval_dv=NULL)CubitQuadFacet
FacetEntity()FacetEntity
facets(DLIList< CubitFacet * > &facet_list)CubitQuadFacet [virtual]
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_all_TDs(DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_control_points(double *ctrl_pts)CubitQuadFacet
get_parents(DLIList< FacetEntity * > &)CubitQuadFacet [inline, virtual]
get_TD(IdentityFn specified_type)ToolDataUser [virtual]
get_TD(IdentityFn specified_type) const ToolDataUser [virtual]
get_tri_facet(int index)=0CubitQuadFacet [pure virtual]
get_tri_facet_at_point(CubitPoint *point_ptr)=0CubitQuadFacet [pure virtual]
init_patch()CubitQuadFacet
map_to_tri_system(double u, double v, int &tri_index, double &A, double &B, double &C)CubitQuadFacet [private]
point(int index)=0CubitQuadFacet [pure virtual]
points(CubitPoint *points[4])=0CubitQuadFacet [pure virtual]
points(DLIList< CubitPoint * > &point_list)CubitQuadFacet [virtual]
remove_TD(IdentityFn specified_type)ToolDataUser [virtual]
remove_TD(ToolData *td)ToolDataUser [virtual]
remove_tri_facets()=0CubitQuadFacet [pure virtual]
set_control_points(double *ctrl_pts)CubitQuadFacet
ToolDataUser()ToolDataUser [inline]
tri_to_quad_index(int tri_index, int pt_index)=0CubitQuadFacet [pure virtual]
~CubitQuadFacet()CubitQuadFacet [virtual]
~FacetEntity()FacetEntity [virtual]
~ToolDataUser()ToolDataUser [virtual]
