cgma
CubitUndo Member List
This is the complete list of members for CubitUndo, including all inherited members.
clear_undo_groups()CubitUndo [static]
create_dummy_undo_object()CubitUndo [static]
CubitUndo()CubitUndo
end_undo_group()CubitUndo [static]
execute_undo()CubitUndo [static]
get_undo_enabled()CubitUndo [static]
inside_undo_group()CubitUndo [static]
mInstanceCubitUndo [private, static]
note_result_bodies(DLIList< Body * > &bodies_to_delete)CubitUndo [static]
note_result_body(Body *body_to_delete)CubitUndo [static]
note_result_boundary_conditions(RefEntity *owner_entity)CubitUndo [static]
note_result_entities(DLIList< RefEntity * > &entities_to_delete)CubitUndo [static]
note_result_entities(DLIList< MRefVolume * > &vols_to_delete)CubitUndo [static]
note_result_entity(RefEntity *entity_to_delete)CubitUndo [static]
number_undo_groups()CubitUndo [static]
p_clear_undo_groups()=0CubitUndo [protected, pure virtual]
p_create_dummy_undo_object()=0CubitUndo [protected, pure virtual]
p_end_undo_group()=0CubitUndo [protected, pure virtual]
p_execute_undo()=0CubitUndo [protected, pure virtual]
p_get_undo_enabled()=0CubitUndo [protected, pure virtual]
p_inside_undo_group()=0CubitUndo [protected, pure virtual]
p_note_result_bodies(DLIList< Body * > &bodies_to_delete)=0CubitUndo [protected, pure virtual]
p_note_result_body(Body *body_to_delete)=0CubitUndo [protected, pure virtual]
p_note_result_boundary_conditions(RefEntity *owner_entity)=0CubitUndo [protected, pure virtual]
p_note_result_entities(DLIList< RefEntity * > &entities_to_delete)=0CubitUndo [protected, pure virtual]
p_note_result_entities(DLIList< MRefVolume * > &vols_to_delete)=0CubitUndo [protected, pure virtual]
p_note_result_entity(RefEntity *entity_to_delete)=0CubitUndo [protected, pure virtual]
p_number_undo_groups()=0CubitUndo [protected, pure virtual]
p_remove_last_undo()=0CubitUndo [protected, pure virtual]
p_remove_last_undo_group()=0CubitUndo [protected, pure virtual]
p_retain_mesh_on_result_bodies(DLIList< Body * > &bodies)=0CubitUndo [protected, pure virtual]
p_retain_mesh_on_result_curves(DLIList< RefEdge * > &curves)=0CubitUndo [protected, pure virtual]
p_retain_mesh_on_result_vertices(DLIList< RefVertex * > &vertices)=0CubitUndo [protected, pure virtual]
p_save_all_mesh_data(MRefEntity *entity)=0CubitUndo [protected, pure virtual]
p_save_merge_data(DLIList< RefEntity * > &ents, bool merging=true)=0CubitUndo [protected, pure virtual]
p_save_mesh_scheme_data(MRefEntity *entity)=0CubitUndo [protected, pure virtual]
p_save_mesh_size_data(MRefEntity *entity)=0CubitUndo [protected, pure virtual]
p_save_mesh_state_before_smoothing(DLIList< MRefEntity * > &ents_to_smooth)=0CubitUndo [protected, pure virtual]
p_save_mesh_state_before_smoothing(DLIList< MeshEntity * > &ents_to_smooth)=0CubitUndo [protected, pure virtual]
p_save_smooth_scheme_data(MRefEntity *entity)=0CubitUndo [protected, pure virtual]
p_save_state()=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(DLIList< Body * > &bodies_to_save, DLIList< RefEntity * > *free_ref_ents=NULL)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(DLIList< RefVolume * > &volumes_to_save)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(DLIList< RefFace * > &faces_to_save)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(RefFace *face_to_save)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(RefVolume *volume_to_save)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(DLIList< MRefVolume * > &volumes_to_save)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(DLIList< RefEdge * > &edges_to_save)=0CubitUndo [protected, pure virtual]
p_save_state_with_cubit_file(DLIList< RefVertex * > &vertices_to_save, bool save_only_if_free=false)=0CubitUndo [protected, pure virtual]
p_set_undo_by_command(CubitString command)=0CubitUndo [protected, pure virtual]
p_set_undo_by_restoring_state()=0CubitUndo [protected, pure virtual]
p_set_undo_enabled(bool value)=0CubitUndo [protected, pure virtual]
p_start_undo_group()=0CubitUndo [protected, pure virtual]
remove_last_undo()CubitUndo [static]
remove_last_undo_group()CubitUndo [static]
retain_mesh_on_result_bodies(DLIList< Body * > &bodies)CubitUndo [static]
retain_mesh_on_result_curves(DLIList< RefEdge * > &curves)CubitUndo [static]
retain_mesh_on_result_vertices(DLIList< RefVertex * > &vertices)CubitUndo [static]
save_all_mesh_data(MRefEntity *entity)CubitUndo [static]
save_merge_data(DLIList< RefEntity * > &ents, bool merging=true)CubitUndo [static]
save_mesh_scheme_data(MRefEntity *entity)CubitUndo [static]
save_mesh_size_data(MRefEntity *entity)CubitUndo [static]
save_mesh_state_before_smoothing(MRefEntity *entity)CubitUndo [static]
save_mesh_state_before_smoothing(DLIList< MRefEntity * > &ents)CubitUndo [static]
save_mesh_state_before_smoothing(DLIList< MeshEntity * > &ents)CubitUndo [static]
save_smooth_scheme_data(MRefEntity *entity)CubitUndo [static]
save_state()CubitUndo [static]
save_state_with_cubit_file(DLIList< Body * > &bodies_to_save, DLIList< RefEntity * > *free_ents_to_save=NULL)CubitUndo [static]
save_state_with_cubit_file(DLIList< RefVolume * > &volumes_to_save)CubitUndo [static]
save_state_with_cubit_file(DLIList< RefFace * > &faces_to_save)CubitUndo [static]
save_state_with_cubit_file(RefFace *face_to_save)CubitUndo [static]
save_state_with_cubit_file(RefVolume *volume_to_save)CubitUndo [static]
save_state_with_cubit_file(DLIList< MRefVolume * > &volumes_to_save)CubitUndo [static]
save_state_with_cubit_file(DLIList< RefEdge * > &edges_to_save)CubitUndo [static]
save_state_with_cubit_file(DLIList< RefVertex * > &vertices_to_save, bool save_if_free=false)CubitUndo [static]
set_undo_by_command(CubitString command)CubitUndo [static]
set_undo_by_restoring_state()CubitUndo [static]
set_undo_enabled(bool value)CubitUndo [static]
start_undo_group()CubitUndo [static]
~CubitUndo()CubitUndo [virtual]
