cgma
CubitUtil Member List
This is the complete list of members for CubitUtil, including all inherited members.
compare(const char *a, const char *b)CubitUtil [inline, static]
convert_string_to_lowercase(char *string)CubitUtil [static]
cubit_sleep(int duration_in_seconds)CubitUtil [static]
CubitUtil()CubitUtil [inline, private]
file_exist(const char *buffer)CubitUtil [static]
file_exist(const CubitString &buffer)CubitUtil [static]
fpCubitUtil [private, static]
get_computer_name()CubitUtil [static]
get_digits()CubitUtil [static]
get_entity_ids_str(const char *pre_string, DLIList< int > &int_list, int width=80, const char *post_string="\n", int sort=CUBIT_TRUE, int unique=CUBIT_TRUE, int left_tab=3, const char *sep_string=",", const char *post_string_none="none\n")CubitUtil [static]
get_file_ptr()CubitUtil [inline, static]
get_os()CubitUtil [static]
get_temporary_filename()CubitUtil [static]
getenv(const CubitString &str)CubitUtil [static]
int_len(int num)CubitUtil [static]
list_entity_ids(const char *pre_string, const DLIList< CubitEntity * > &entity_list, int width=80, const char *post_string="\n", int sort=CUBIT_TRUE, int unique=CUBIT_TRUE, int tab=3, const char *sep_string=",", const char *post_string_none="none\n")CubitUtil [static]
list_entity_ids(const char *pre_string, DLIList< int > &id_list, int width=80, const char *post_string="\n", int sort=CUBIT_TRUE, int unique=CUBIT_TRUE, int tab_len=3, const char *sep_string=",", const char *post_string_none="none\n")CubitUtil [static]
list_ids(const char *const heading, const DLIList< CubitEntity * > &entity_list, int should_sort=CUBIT_FALSE, int report_once=CUBIT_FALSE, int wrap=80)CubitUtil [static]
num_cpu()CubitUtil [static]
opposite_sense(CubitSense sense)CubitUtil [inline, static]
print_columns(const std::vector< CubitString > &array, const CubitString &indent=CubitString())CubitUtil [static]
process_entity_ids(int method, CubitString &ret_str, const char *pre_string, DLIList< int > &id_list, int max_len, const char *post_string, int sort, int unique, int tab_len, const char *sep_string, const char *post_string_none="none\n")CubitUtil [static]
reset_file_ptr()CubitUtil [inline, static]
set_digits(int new_digits)CubitUtil [static]
set_file_ptr(FILE *file_ptr)CubitUtil [inline, static]
setenv(const CubitString &var, const CubitString &value)CubitUtil [static]
sort_and_print_ids(const char *const heading, DLIList< int > &id_list, int should_sort=CUBIT_FALSE, int report_once=CUBIT_FALSE, int wrap=80)CubitUtil [static]
strcmp_case_insensitive(const char *s1, const char *s2)CubitUtil [static]
string_length(const char *string, int tabsize=8)CubitUtil [static]
strncmp_case_insensitive(const char *s1, const char *s2, int n)CubitUtil [static]
util_strdup(const char *s1)CubitUtil [static]
util_strdup_free(char *s1)CubitUtil [inline, static]
