bounding_box() | CurveFacetEvalTool | |
closest_point(CubitVector &this_point, CubitVector &closest_point_ptr, CubitVector *normal_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL) | CurveFacetEvalTool | |
CurveFacetEvalTool() | CurveFacetEvalTool | |
curvSense | CurveFacetEvalTool | [private] |
debug_draw_facet_edges(int color=-1) | CurveFacetEvalTool | |
destroy_facets() | CurveFacetEvalTool | [private] |
draw_edge(CubitFacetEdge *edge, int color) | CurveFacetEvalTool | [private] |
draw_edges(int color=-1) | CurveFacetEvalTool | [private] |
draw_line(CubitVector &begin, CubitVector &end, int color=-1) | CurveFacetEvalTool | [private] |
draw_location(CubitVector &loc, int color=-1) | CurveFacetEvalTool | [private] |
evaluate_bezier_edge(CubitFacetEdge *edge, int index0, int index1, double fraction, CubitVector &location_on_curve, double *tangent) | CurveFacetEvalTool | [private] |
facetLength | CurveFacetEvalTool | [private] |
find_curv_sense(CubitPoint *start_ptr) | CurveFacetEvalTool | [private] |
find_curv_sense(CubitVector &start) | CurveFacetEvalTool | [private] |
fix_point_edge_order() | CurveFacetEvalTool | [private] |
get_facets(DLIList< CubitFacetEdge * > &facet_list) | CurveFacetEvalTool | [inline] |
get_output_id() | CurveFacetEvalTool | [inline] |
get_points(DLIList< CubitPoint * > &point_list) | CurveFacetEvalTool | [inline] |
get_segments_from_loops(DLIList< DLIList< CubitFacetEdge * > * > *facet_loop_list, CubitVector &start, CubitVector &end, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, CubitSense owrts) | CurveFacetEvalTool | [private] |
get_segments_from_loops(DLIList< DLIList< CubitFacetEdge * > * > *facet_loop_list, CubitPoint *start_pt, CubitPoint *end_pt, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, CubitSense owrts) | CurveFacetEvalTool | [private] |
get_segments_from_positions(std::vector< CubitVector > &positions, CubitVector &start_pt, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list) | CurveFacetEvalTool | [private] |
get_surf_eval_tool() | CurveFacetEvalTool | [inline] |
goodCurveData | CurveFacetEvalTool | [private] |
has_good_curve_data() | CurveFacetEvalTool | [inline] |
initialize(DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, FacetEvalTool *surf_eval=NULL) | CurveFacetEvalTool | |
initialize(FacetEvalTool *surf_eval_tool, CubitPoint *start_point, CubitPoint *end_point, CubitSense orientation) | CurveFacetEvalTool | |
initialize(FacetEvalTool *surf_eval_tool, CubitVector &start, CubitVector &end, CubitSense orientation) | CurveFacetEvalTool | |
initialize(FacetEvalTool *surf_eval_tool, CubitVector &start, std::vector< CubitVector > &positions) | CurveFacetEvalTool | |
interpOrder | CurveFacetEvalTool | [private] |
length() | CurveFacetEvalTool | [inline] |
length_from_u(double root_param, double end_param) | CurveFacetEvalTool | |
myBBox | CurveFacetEvalTool | [private] |
myEdgeList | CurveFacetEvalTool | [private] |
myPointList | CurveFacetEvalTool | [private] |
output_id | CurveFacetEvalTool | [private] |
position_from_fraction(double fraction, CubitVector &location_on_curve) | CurveFacetEvalTool | |
project_to_bezier_edge(CubitFacetEdge *edge, CubitVector &point, CubitVector &projected_point, double *tangent, double *tval) | CurveFacetEvalTool | [private] |
remove_facets(DLIList< CubitFacetEdge * > &facet_edges) | CurveFacetEvalTool | |
replace_facets(DLIList< CubitFacetEdge * > &curv_edges) | CurveFacetEvalTool | |
replace_point(CubitPoint *del_pnt, CubitPoint *keep_pnt) | CurveFacetEvalTool | |
restore(FILE *fp, unsigned int endian, int num_edges, int num_points, CubitFacetEdge **edges, CubitPoint **points, int num_fets, FacetEvalTool **fet_list) | CurveFacetEvalTool | |
save(FILE *fp) | CurveFacetEvalTool | |
sense() | CurveFacetEvalTool | [inline] |
set_facet_eval_tool(FacetEvalTool *surf_eval_tool_ptr) | CurveFacetEvalTool | [inline] |
set_length() | CurveFacetEvalTool | |
set_output_id(int id) | CurveFacetEvalTool | [inline] |
surfFacetEvalTool | CurveFacetEvalTool | [private] |
toolID | CurveFacetEvalTool | [private] |
u_from_arc_length(double root_param, double arc_length) | CurveFacetEvalTool | |
u_on_facet_edge(CubitFacetEdge *edge_at_pt, CubitVector pt) | CurveFacetEvalTool | [private] |
~CurveFacetEvalTool() | CurveFacetEvalTool | |
