cgma
DLIList< X > Member List
This is the complete list of members for DLIList< X >, including all inherited members.
append(const_reference new_item)DLIList< X > [inline]
append_unique(const_reference new_item)DLIList< X > [inline]
as_vector() const DLIList< X > [inline]
back()DLIList< X > [inline]
back(int n)DLIList< X > [inline]
begin()DLIList< X > [inline]
begin() const DLIList< X > [inline]
casting_merge_unique(const DLIList< Y > &merge_list, bool merge_list_unique=false)DLIList< X > [inline]
change_to(X val)DLIList< X > [inline]
clean_out()DLIList< X > [inline]
const_iterator typedefDLIList< X >
const_pointer typedefDLIList< X >
const_reference typedefDLIList< X >
copy_from(X *other_array, const int other_size)DLIList< X > [inline]
copy_to(X *other_array)DLIList< X > [inline]
distance_to_nearby(const X val)DLIList< X > [inline]
DLIList(int size=0)DLIList< X > [inline, explicit]
DLIList(const DLIList< X > &from)DLIList< X > [inline]
DLIList(const std::vector< X > &from)DLIList< X > [inline, explicit]
DLIListIterator< X > classDLIList< X > [friend]
empty() const DLIList< X > [inline]
end()DLIList< X > [inline]
end() const DLIList< X > [inline]
extract()DLIList< X > [inline]
get() const DLIList< X > [inline]
get()DLIList< X > [inline]
get_and_back()DLIList< X > [inline]
get_and_step()DLIList< X > [inline]
get_index()DLIList< X > [inline]
indexDLIList< X > [private]
insert(X val)DLIList< X > [inline]
insert_first(X val)DLIList< X > [inline]
intersect(const DLIList< X > &merge_list)DLIList< X > [inline]
intersect_unordered(const DLIList< X > &merge_list)DLIList< X > [inline]
is_at_beginning() const DLIList< X > [inline]
is_at_end() const DLIList< X > [inline]
is_in_list(const_reference item) const DLIList< X > [inline]
last()DLIList< X > [inline]
last_item(void)DLIList< X > [inline]
last_item(void) const DLIList< X > [inline]
lengthen_list(int by_how_much=DLI_COUNT_INCREMENT, double by_what_factor=DLI_COUNT_FACTOR)DLIList< X > [inline, private]
listArrayDLIList< X > [private]
memory_use()DLIList< X > [inline]
merge_unique(const DLIList< X > &merge_list, bool merge_list_unique=false)DLIList< X > [inline]
move_between(X val1, X val2)DLIList< X > [inline]
move_to(const_reference item)DLIList< X > [inline]
move_to_nearby(const X val)DLIList< X > [inline]
next() const DLIList< X > [inline]
next(int n) const DLIList< X > [inline]
omit(const_reference val)DLIList< X > [inline]
operator!=(const DLIList< X > &from)DLIList< X > [inline]
operator+=(const DLIList< X > &from)DLIList< X > [inline]
operator+=(const std::vector< X > &from)DLIList< X > [inline]
operator-=(const DLIList< X > &from)DLIList< X > [inline]
operator=(const DLIList< X > &from)DLIList< X > [inline]
operator=(const std::vector< X > &from)DLIList< X > [inline]
operator=(const DLIListIterator< X > &from_iterator)DLIList< X > [inline]
operator==(const DLIList< X > &from)DLIList< X > [inline]
operator[](int index) const DLIList< X > [inline]
operator[](int index)DLIList< X > [inline]
pop()DLIList< X > [inline]
prev() const DLIList< X > [inline]
prev(int n) const DLIList< X > [inline]
push(X val)DLIList< X > [inline]
remove()DLIList< X > [inline]
remove(const_reference val)DLIList< X > [inline]
remove_all_with_value(const_reference val)DLIList< X > [inline]
reserve(int min_size)DLIList< X > [inline]
reset()DLIList< X > [inline]
reverse()DLIList< X > [inline]
shrink(int k)DLIList< X > [inline]
size() const DLIList< X > [inline]
sort()DLIList< X > [inline]
sort(SortFunction f)DLIList< X >
SortFunction typedefDLIList< X >
step(int n)DLIList< X > [inline]
step_and_get()DLIList< X > [inline]
swap(std::vector< X > &other)DLIList< X > [inline]
uniquify_ordered()DLIList< X > [inline]
uniquify_unordered()DLIList< X > [inline]
uniquify_unordered_checked()DLIList< X > [inline]
value_type typedefDLIList< X >
where_is_item(const_reference val) const DLIList< X > [inline]
~DLIList()DLIList< X > [inline]
