cgma
FBPolyhedron Member List
This is the complete list of members for FBPolyhedron, including all inherited members.
add_new_triangle_data()FBPolyhedron [private]
addavertex(double x, double y, double z)FBPolyhedron [private]
boxintersection(FBPolyhedron *otherpoly)FBPolyhedron
debug_draw_boundary_edges(int color)FBPolyhedron [private]
debug_draw_fb_triangle(FB_Triangle *tri)FBPolyhedron [private]
dudded_trisFBPolyhedron [private]
edge_exists(int v0, int v1)FBPolyhedron [private]
edge_exists_in_tri(FB_Triangle &tri, int v0, int v1)FBPolyhedron
edgmmapFBPolyhedron [private]
FBClassify classFBPolyhedron [friend]
FBImprint classFBPolyhedron [friend]
FBIntersect classFBPolyhedron [friend]
FBPolyhedron()FBPolyhedron
hashobjFBPolyhedron [private]
intersection_edgesFBPolyhedron [private]
kdtreeFBPolyhedron [private]
make_tri_boundingbox(FB_Triangle *tri)FBPolyhedron [private]
make_tri_plane_coeffs(FB_Triangle *tri)FBPolyhedron [private]
makeahashvaluefrom_coord(double x, double y, double z)FBPolyhedron [private]
makepoly(const std::vector< double > &coords, const std::vector< int > &connections, std::vector< int > *f_c_indices)FBPolyhedron
min_max_angles_in_fb_triangle(FB_Triangle *tri, double &min_angle, double &max_angle)FBPolyhedron [private]
min_max_angles_in_polyhedron(double &min_angle, double &max_angle)FBPolyhedron [private]
numptsFBPolyhedron [private]
numtrisFBPolyhedron [private]
original_numtrisFBPolyhedron [private]
orphaned_edgesFBPolyhedron [private]
polyxmaxFBPolyhedron [private]
polyxminFBPolyhedron [private]
polyymaxFBPolyhedron [private]
polyyminFBPolyhedron [private]
polyzmaxFBPolyhedron [private]
polyzminFBPolyhedron [private]
putedges(std::vector< int > &newedges)FBPolyhedron [private]
putnewpoints(std::vector< double > &newpoints)FBPolyhedron [private]
remove_small_angles_in_triangle_range(int lower_index, int upper_index)FBPolyhedron [private]
removeduddedtriangles()FBPolyhedron [private]
retriangulate(std::vector< int > &newfacets, std::vector< int > &newfacetsindex)FBPolyhedron
retriangulate(std::vector< int > &newfacets)FBPolyhedron
vertsFBPolyhedron [private]
~FBPolyhedron()FBPolyhedron
