cgma
FacetBody Member List
This is the complete list of members for FacetBody, including all inherited members.
add_lump(FacetLump *lump_to_add)FacetBody
append_simple_attribute_virt(const CubitSimpleAttrib &)FacetBody [virtual]
attribSetFacetBody [private]
bodysm()TopologyBridge
BodySM()BodySM
bodysms(DLIList< BodySM * > &bodies, bool unique=true)TopologyBridge
bounding_box()BodySM
bridge_manager() const TopologyBridge
bridge_manager(BridgeManager *manager)TopologyBridge
bridge_sense()TopologyBridge [inline]
can_be_deleted(DLIList< Body * > &body_list)FacetBody
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true)TopologyBridge
copy()FacetBody [virtual]
curves(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
disconnect_all_lumps()FacetBody
FacetBody(DLIList< Lump * > &myLumps)FacetBody
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER)TopologyBridge
get_children_virt(DLIList< TopologyBridge * > &children)FacetBody [virtual]
get_coedges(DLIList< FacetCoEdge * > &coedges)FacetBody
get_curves(DLIList< FacetCurve * > &curves)FacetBody
get_geometry_query_engine() const FacetBody [virtual]
get_loops(DLIList< FacetLoop * > &loops)FacetBody
get_lumps(DLIList< FacetLump * > &lumps)FacetBody
get_parents(DLIList< TopologyBridge * > &parents)TopologyBridge
get_parents_virt(DLIList< TopologyBridge * > &parents)FacetBody [virtual]
get_points(DLIList< FacetPoint * > &points)FacetBody
get_shells(DLIList< FacetShell * > &shells)FacetBody
get_simple_attribute(DLIList< CubitSimpleAttrib > &)FacetBody [virtual]
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)FacetBody [virtual]
get_surfaces(DLIList< FacetSurface * > &surfaces)FacetBody
get_transforms(CubitTransformMatrix &tfm)FacetBody [virtual]
init_edge_flags(DLIList< Surface * > &surf_list, int flag)FacetBody [private]
layer() const TopologyBridge [inline, virtual]
loopsm()TopologyBridge
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true)TopologyBridge
lump()TopologyBridge
lumps(DLIList< Lump * > &lumps, bool unique=true)TopologyBridge
mass_properties(CubitVector &result, double &volume)FacetBody [virtual]
MAX_TB_LAYER enum valueTopologyBridge
move(double, double, double)FacetBody [virtual]
myLumpsFacetBody [private]
myTransformsFacetBody [private]
owner() const TopologyBridge [inline]
owner(TBOwner *new_owner)TopologyBridge [inline]
point_containment(const CubitVector &pos, double tolerance)FacetBody [virtual]
points(DLIList< TBPoint * > &points, bool unique=true)TopologyBridge
reflect(double, double, double)FacetBody
remove_all_simple_attribute_virt()FacetBody [virtual]
remove_lump(FacetLump *lump_to_remove)FacetBody
remove_simple_attribute_virt(const CubitSimpleAttrib &)FacetBody [virtual]
restore()FacetBody [virtual]
restore_attribs(FILE *file_ptr, unsigned int endian)FacetBody
reverse_bridge_sense()TopologyBridge [inline]
rotate(double, double, double, double)FacetBody [virtual]
save_attribs(FILE *file_ptr)FacetBody
scale(double, double, double)FacetBody [virtual]
scale(double)FacetBody [virtual]
set_transforms(CubitTransformMatrix tfm)FacetBody
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true)TopologyBridge
surfaces(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
topology_entity() const TopologyBridge
TopologyBridge()TopologyBridge [inline]
transform(CubitTransformMatrix &tfmat, CubitBoolean is_rotation)FacetBody [private]
validate(const CubitString &, DLIList< TopologyEntity * > &)FacetBody [virtual]
~BodySM()BodySM [virtual]
~FacetBody()FacetBody [virtual]
~TopologyBridge()TopologyBridge [virtual]
