add_coedge(CoEdgeSM *coedge_ptr) | FacetCurve | [inline] |
adjust_periodic_parameter(double ¶m) | FacetCurve | [private] |
append_simple_attribute_virt(const CubitSimpleAttrib &) | FacetCurve | [virtual] |
attribSet | FacetCurve | [private] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const | FacetCurve | [virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
center_point() | Curve | [inline, virtual] |
ChildType typedef | Curve | |
closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL) | FacetCurve | [virtual] |
closest_point_trimmed(CubitVector const &from_pt, CubitVector &result_pt) | Curve | [virtual] |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
Curve() | Curve | |
curveFacetEvalTool | FacetCurve | [private] |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
disconnect_coedge(FacetCoEdge *coedge) | FacetCurve | |
end_param() | FacetCurve | [virtual] |
end_point() | FacetCurve | [inline] |
FacetCurve(CurveFacetEvalTool *curve_facet_tool, TBPoint *fp0, TBPoint *fp1, DLIList< CoEdgeSM * > &coedgelist) | FacetCurve | |
FacetCurve(CurveFacetEvalTool *curve_facet_tool, TBPoint *fp0, TBPoint *fp1, CubitSense sense) | FacetCurve | |
G1_discontinuous(double param, CubitVector *minus_tangent=NULL, CubitVector *plus_tangent=NULL) | FacetCurve | [virtual] |
geometry_type() | FacetCurve | [virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_arc_length() | Curve | [inline, virtual] |
get_arc_length(const CubitVector &point1, const CubitVector &point2) | Curve | [inline, virtual] |
get_arc_length(const CubitVector &point1, const int which_end) | Curve | [inline, virtual] |
get_center_radius(CubitVector ¢er, double &radius) | FacetCurve | [virtual] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &children) | FacetCurve | [virtual] |
get_coedges(DLIList< FacetCoEdge * > &coedges) | FacetCurve | |
get_ellipse_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio) const | FacetCurve | [virtual] |
get_eval_tool() | FacetCurve | [inline] |
get_facets(DLIList< CubitFacetEdge * > &facet_list) | FacetCurve | |
get_geometry_query_engine() const | FacetCurve | [virtual] |
get_interior_extrema(DLIList< CubitVector * > &interior_points, CubitSense &return_sense) | FacetCurve | [virtual] |
get_loops(DLIList< FacetLoop * > &loops) | FacetCurve | |
get_lumps(DLIList< FacetLump * > &lumps) | FacetCurve | |
get_param_range(double &lower_bound, double &upper_bound) | FacetCurve | [virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &parents) | FacetCurve | [virtual] |
get_point_direction(CubitVector &origin, CubitVector &direction) | FacetCurve | [virtual] |
get_points(DLIList< FacetPoint * > &points) | FacetCurve | |
get_points(DLIList< CubitPoint * > &point_list) | FacetCurve | |
get_relative_curve_sense() | FacetCurve | [private] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_sense() | FacetCurve | [inline] |
get_shells(DLIList< FacetShell * > &shells) | FacetCurve | |
get_simple_attribute(DLIList< CubitSimpleAttrib > &) | FacetCurve | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | FacetCurve | [virtual] |
get_spline_params(bool &rational, int °ree, DLIList< CubitVector > &cntrl_pts, DLIList< double > &cntrl_pt_weights, DLIList< double > &knots, bool &spline_is_reversed) const | FacetCurve | [virtual] |
get_surfaces(DLIList< FacetSurface * > &surfaces) | FacetCurve | |
has_parent_coedge() | FacetCurve | [inline] |
id() | FacetCurve | [inline] |
is_periodic(double &period) | FacetCurve | [virtual] |
is_position_on(const CubitVector &test_position) | FacetCurve | [virtual] |
is_tolerant() | Curve | [inline, virtual] |
layer() const | TopologyBridge | [inline, virtual] |
length_from_u(double parameter1, double parameter2) | FacetCurve | [virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
MAX_TB_LAYER enum value | TopologyBridge | |
measure() | FacetCurve | [virtual] |
mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &mid_point) | Curve | [inline, virtual] |
mid_point(CubitVector &mid_point) | Curve | [inline, virtual] |
myCoEdges | FacetCurve | [private] |
myEndPoint | FacetCurve | [private] |
myId | FacetCurve | [private] |
myStartPoint | FacetCurve | [private] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
periodic | FacetCurve | [private] |
point_containment(const CubitVector &point) | FacetCurve | [virtual] |
point_containment(double u, double v) | FacetCurve | [virtual] |
point_containment(CubitVector &point, double u, double v) | FacetCurve | [virtual] |
point_from_arc_length(double root_param, const double arc_length, CubitVector &new_point) | Curve | [virtual] |
point_from_arc_length(const CubitVector &root_point, double const arc_length, CubitVector &new_point) | Curve | [virtual] |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
position_from_fraction(const double fraction_along_curve, CubitVector &output_position) | Curve | [inline, virtual] |
position_from_u(double u_value, CubitVector &output_position) | FacetCurve | [virtual] |
relative_sense(Curve *other_curve) | Curve | [virtual] |
remove_all_simple_attribute_virt() | FacetCurve | [virtual] |
remove_end_point() | FacetCurve | [inline] |
remove_simple_attribute_virt(const CubitSimpleAttrib &) | FacetCurve | [virtual] |
remove_start_point() | FacetCurve | [inline] |
reset_length() | FacetCurve | |
restore_attribs(FILE *file_ptr, unsigned int endian) | FacetCurve | |
reverse_bridge_sense() | TopologyBridge | [inline] |
run_test_function() | FacetCurve | [friend] |
save_attribs(FILE *file_ptr) | FacetCurve | |
sense_ | FacetCurve | [private] |
set_eval_tool(CurveFacetEvalTool *eval_tool) | FacetCurve | [inline] |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
start_param() | FacetCurve | [virtual] |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
u_from_arc_length(double root_param, double arc_length) | FacetCurve | [virtual] |
u_from_position(const CubitVector &input_position) | FacetCurve | [virtual] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~Curve() | Curve | [virtual] |
~FacetCurve() | FacetCurve | [virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
