add_body(BodySM *new_body) | FacetLump | [inline] |
add_shell(FacetShell *shell) | FacetLump | |
append_simple_attribute_virt(const CubitSimpleAttrib &) | FacetLump | [virtual] |
attribSet | FacetLump | [private] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const | FacetLump | [virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
ChildType typedef | Lump | |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
disconnect_all_shells() | FacetLump | |
FacetLump(DLIList< ShellSM * > &my_shells, BodySM *body_sm_ptr=NULL) | FacetLump | |
geometry_type() | Lump | [inline, virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_bodies(DLIList< FacetBody * > &bodies) | FacetLump | |
get_body() const | FacetLump | [inline] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &children) | FacetLump | [virtual] |
get_coedges(DLIList< FacetCoEdge * > &coedges) | FacetLump | |
get_curves(DLIList< FacetCurve * > &curves) | FacetLump | |
get_geometry_query_engine() const | FacetLump | [virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &parents) | FacetLump | [virtual] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_shells(DLIList< FacetShell * > &shells) | FacetLump | |
get_simple_attribute(DLIList< CubitSimpleAttrib > &) | FacetLump | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | FacetLump | [virtual] |
get_surfaces(DLIList< FacetSurface * > &surfaces) | FacetLump | |
is_sheet() | FacetLump | |
layer() const | TopologyBridge | [inline, virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
Lump() | Lump | |
lump() | TopologyBridge | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
mass_properties(CubitVector ¢roid, double &volume) | FacetLump | [virtual] |
Lump::mass_properties(CubitVector[3], CubitVector &, CubitVector &, double &) | Lump | [inline, virtual] |
MAX_TB_LAYER enum value | TopologyBridge | |
measure() | FacetLump | [virtual] |
merge(GeometryEntity *) | FacetLump | [inline, virtual] |
myBodyPtr | FacetLump | [private] |
myShells | FacetLump | [private] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
point_containment(const CubitVector &point, double tolerance) | FacetLump | |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
remove_all_simple_attribute_virt() | FacetLump | [virtual] |
remove_body() | FacetLump | [inline] |
remove_shell(FacetShell *shell) | FacetLump | |
remove_simple_attribute_virt(const CubitSimpleAttrib &) | FacetLump | [virtual] |
restore_attribs(FILE *file_ptr, unsigned int endian) | FacetLump | |
reverse_bridge_sense() | TopologyBridge | [inline] |
save_attribs(FILE *file_ptr) | FacetLump | |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
unmerge(DLIList< RefVolume * >) | FacetLump | [inline, virtual] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~FacetLump() | FacetLump | [virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~Lump() | Lump | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
