cgma
GeometryHealerEngine Member List
This is the complete list of members for GeometryHealerEngine, including all inherited members.
analyze_badgeom(DLIList< Body * > &body_list, DLIList< TopologyEntity * > &bad_geometry, FILE *logfile=NULL)=0GeometryHealerEngine [pure virtual]
auto_heal_bodies(DLIList< Body * > &body_list, DLIList< Body * > &new_body_list, DLIList< TopologyEntity * > &bad_geometry, CubitBoolean rebuild=CUBIT_FALSE, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL)=0GeometryHealerEngine [pure virtual]
clean_attributes(DLIList< Body * > &body_list)=0GeometryHealerEngine [pure virtual]
force_simplify_to_cone(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0GeometryHealerEngine [pure virtual]
force_simplify_to_cylinder(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0GeometryHealerEngine [pure virtual]
force_simplify_to_plane(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0GeometryHealerEngine [pure virtual]
force_simplify_to_sphere(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0GeometryHealerEngine [pure virtual]
force_simplify_to_torus(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0GeometryHealerEngine [pure virtual]
get_badgeom(DLIList< Body * > &body_list, DLIList< TopologyEntity * > &bad_geometry)=0GeometryHealerEngine [pure virtual]
get_check_curve_on_heal_flg()=0GeometryHealerEngine [pure virtual]
get_check_surf_on_heal_flg()=0GeometryHealerEngine [pure virtual]
get_check_vol_on_heal_flg()=0GeometryHealerEngine [pure virtual]
get_cleanatt_flg()=0GeometryHealerEngine [pure virtual]
get_curve_on_heal_limit()=0GeometryHealerEngine [pure virtual]
get_default_analytic_tol()=0GeometryHealerEngine [pure virtual]
get_default_geombuild_tol()=0GeometryHealerEngine [pure virtual]
get_default_isospline_tol()=0GeometryHealerEngine [pure virtual]
get_default_reblend_classify_tol()=0GeometryHealerEngine [pure virtual]
get_default_reblend_tol()=0GeometryHealerEngine [pure virtual]
get_default_simplify_tol()=0GeometryHealerEngine [pure virtual]
get_default_stitch_max_tol()=0GeometryHealerEngine [pure virtual]
get_default_stitch_min_tol()=0GeometryHealerEngine [pure virtual]
get_inc_analytic_flg()=0GeometryHealerEngine [pure virtual]
get_inc_genericspline_flg()=0GeometryHealerEngine [pure virtual]
get_inc_geombuild_flg()=0GeometryHealerEngine [pure virtual]
get_inc_isospline_flg()=0GeometryHealerEngine [pure virtual]
get_inc_postprocess_flg()=0GeometryHealerEngine [pure virtual]
get_inc_preprocess_flg()=0GeometryHealerEngine [pure virtual]
get_inc_reblend_flg()=0GeometryHealerEngine [pure virtual]
get_inc_sharpedge_flg()=0GeometryHealerEngine [pure virtual]
get_inc_simplify_flg()=0GeometryHealerEngine [pure virtual]
get_inc_stitch_flg()=0GeometryHealerEngine [pure virtual]
get_inc_wrapup_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_bodies_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_coedges_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_curves_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_loops_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_shells_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_surfaces_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_vertices_flg()=0GeometryHealerEngine [pure virtual]
get_show_bad_volumes_flg()=0GeometryHealerEngine [pure virtual]
get_show_details_flg()=0GeometryHealerEngine [pure virtual]
get_show_method()=0GeometryHealerEngine [pure virtual]
get_show_on_heal_flg()=0GeometryHealerEngine [pure virtual]
get_show_summary_flg()=0GeometryHealerEngine [pure virtual]
get_surf_on_heal_limit()=0GeometryHealerEngine [pure virtual]
get_tcurves(DLIList< Body * > &body_list, DLIList< RefEdge * > &t_curves)=0GeometryHealerEngine [pure virtual]
get_vol_on_heal_limit()=0GeometryHealerEngine [pure virtual]
heal_incremental(DLIList< Body * > &body_list, DLIList< Body * > &new_bodies, DLIList< TopologyEntity * > &bad_geometry, double simplify_tol=CUBIT_DBL_MAX, double stitch_min_tol=CUBIT_DBL_MAX, double stitch_max_tol=CUBIT_DBL_MAX, double geombuild_tol=CUBIT_DBL_MAX, double analytic_tol=CUBIT_DBL_MAX, double isospline_tol=CUBIT_DBL_MAX, double reblend_classify_tol=CUBIT_DBL_MAX, double reblend_tol=CUBIT_DBL_MAX, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL)=0GeometryHealerEngine [pure virtual]
is_healer_engine(const TopologyBridge *)=0GeometryHealerEngine [pure virtual]
is_healer_engine(const TopologyEntity *)=0GeometryHealerEngine [pure virtual]
list_default_tolerances()=0GeometryHealerEngine [pure virtual]
list_incremental()=0GeometryHealerEngine [pure virtual]
list_onshow_flgs()=0GeometryHealerEngine [pure virtual]
list_tolerances(DLIList< Body * > &body_list)=0GeometryHealerEngine [pure virtual]
measure_filter(DLIList< RefEntity * > &ref_entities, double measure_value, double tolerance)=0GeometryHealerEngine [pure virtual]
reset_default_tolerances()=0GeometryHealerEngine [pure virtual]
set_check_curve_on_heal_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_check_surf_on_heal_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_check_vol_on_heal_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_cleanatt_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_curve_on_heal_limit(double limit)=0GeometryHealerEngine [pure virtual]
set_default_analytic_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_geombuild_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_isospline_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_reblend_classify_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_reblend_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_simplify_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_stitch_max_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_default_stitch_min_tol(double tol)=0GeometryHealerEngine [pure virtual]
set_inc_analytic_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_genericspline_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_geombuild_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_isospline_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_postprocess_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_preprocess_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_reblend_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_sharpedge_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_simplify_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_stitch_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_inc_wrapup_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_bodies_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_coedges_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_curves_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_loops_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_shells_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_surfaces_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_vertices_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_bad_volumes_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_details_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_method(int method)=0GeometryHealerEngine [pure virtual]
set_show_on_heal_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_show_summary_flg(CubitBoolean flg)=0GeometryHealerEngine [pure virtual]
set_surf_on_heal_limit(double limit)=0GeometryHealerEngine [pure virtual]
set_vol_on_heal_limit(double limit)=0GeometryHealerEngine [pure virtual]
~GeometryHealerEngine()GeometryHealerEngine [inline, virtual]
