add_ghe(GeometryHealerEngine *ghe_ptr) | GeometryHealerTool | |
analyze_badgeom(DLIList< Body * > &body_list, DLIList< TopologyEntity * > &bad_geometry, FILE *logfile=NULL) | GeometryHealerTool | |
auto_heal_bodies(DLIList< Body * > &body_list, DLIList< Body * > &new_body_list, DLIList< TopologyEntity * > &bad_geometry, CubitBoolean rebuild=CUBIT_FALSE, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL) | GeometryHealerTool | |
clean_attributes(DLIList< Body * > &body_list) | GeometryHealerTool | |
delete_instance() | GeometryHealerTool | [inline, static] |
force_simplify_to_cone(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE) | GeometryHealerTool | |
force_simplify_to_cylinder(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE) | GeometryHealerTool | |
force_simplify_to_plane(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE) | GeometryHealerTool | |
force_simplify_to_sphere(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE) | GeometryHealerTool | |
force_simplify_to_torus(DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE) | GeometryHealerTool | |
GeometryHealerTool(GeometryHealerEngine *GHEPtr) | GeometryHealerTool | [protected] |
get_badgeom(DLIList< Body * > &body_list, DLIList< TopologyEntity * > &bad_geometry) | GeometryHealerTool | |
get_check_curve_on_heal_flg() | GeometryHealerTool | |
get_check_surf_on_heal_flg() | GeometryHealerTool | |
get_check_vol_on_heal_flg() | GeometryHealerTool | |
get_cleanatt_flg() | GeometryHealerTool | |
get_curve_on_heal_limit() | GeometryHealerTool | |
get_default_analytic_tol() | GeometryHealerTool | |
get_default_geombuild_tol() | GeometryHealerTool | |
get_default_isospline_tol() | GeometryHealerTool | |
get_default_reblend_classify_tol() | GeometryHealerTool | |
get_default_reblend_tol() | GeometryHealerTool | |
get_default_simplify_tol() | GeometryHealerTool | |
get_default_stitch_max_tol() | GeometryHealerTool | |
get_default_stitch_min_tol() | GeometryHealerTool | |
get_engine(TopologyBridge *tb_ptr) const | GeometryHealerTool | [private] |
get_engine(TopologyEntity *te_ptr) const | GeometryHealerTool | [private] |
get_inc_analytic_flg() | GeometryHealerTool | |
get_inc_genericspline_flg() | GeometryHealerTool | |
get_inc_geombuild_flg() | GeometryHealerTool | |
get_inc_isospline_flg() | GeometryHealerTool | |
get_inc_postprocess_flg() | GeometryHealerTool | |
get_inc_preprocess_flg() | GeometryHealerTool | |
get_inc_reblend_flg() | GeometryHealerTool | |
get_inc_sharpedge_flg() | GeometryHealerTool | |
get_inc_simplify_flg() | GeometryHealerTool | |
get_inc_stitch_flg() | GeometryHealerTool | |
get_inc_wrapup_flg() | GeometryHealerTool | |
get_show_bad_bodies_flg() | GeometryHealerTool | |
get_show_bad_coedges_flg() | GeometryHealerTool | |
get_show_bad_curves_flg() | GeometryHealerTool | |
get_show_bad_loops_flg() | GeometryHealerTool | |
get_show_bad_shells_flg() | GeometryHealerTool | |
get_show_bad_surfaces_flg() | GeometryHealerTool | |
get_show_bad_vertices_flg() | GeometryHealerTool | |
get_show_bad_volumes_flg() | GeometryHealerTool | |
get_show_details_flg() | GeometryHealerTool | |
get_show_method() | GeometryHealerTool | |
get_show_on_heal_flg() | GeometryHealerTool | |
get_show_summary_flg() | GeometryHealerTool | |
get_surf_on_heal_limit() | GeometryHealerTool | |
get_tcurves(DLIList< Body * > &body_list, DLIList< RefEdge * > &t_curves) | GeometryHealerTool | |
get_vol_on_heal_limit() | GeometryHealerTool | |
gheList | GeometryHealerTool | [private] |
heal_incremental(DLIList< Body * > &body_list, DLIList< Body * > &new_bodies, DLIList< TopologyEntity * > &bad_geometry, double simplify_tol=CUBIT_DBL_MAX, double stitch_min_tol=CUBIT_DBL_MAX, double stitch_max_tol=CUBIT_DBL_MAX, double geombuild_tol=CUBIT_DBL_MAX, double analytic_tol=CUBIT_DBL_MAX, double isospline_tol=CUBIT_DBL_MAX, double reblend_classify_tol=CUBIT_DBL_MAX, double reblend_tol=CUBIT_DBL_MAX, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL) | GeometryHealerTool | |
instance(GeometryHealerEngine *GHEPtr=NULL) | GeometryHealerTool | [static] |
instance_ | GeometryHealerTool | [private, static] |
list_default_tolerances() | GeometryHealerTool | |
list_incremental() | GeometryHealerTool | |
list_onshow_flgs() | GeometryHealerTool | |
list_tolerances(DLIList< Body * > &body_list) | GeometryHealerTool | |
reset_default_tolerances() | GeometryHealerTool | |
same_healer_engine(DLIList< RefEntity * > &ref_entity_list, CubitBoolean check_children) const | GeometryHealerTool | [private] |
same_healer_engine(DLIList< TopologyEntity * > &topo_list) const | GeometryHealerTool | [private] |
set_check_curve_on_heal_flg(CubitBoolean flg) | GeometryHealerTool | |
set_check_surf_on_heal_flg(CubitBoolean flg) | GeometryHealerTool | |
set_check_vol_on_heal_flg(CubitBoolean flg) | GeometryHealerTool | |
set_cleanatt_flg(CubitBoolean flg) | GeometryHealerTool | |
set_curve_on_heal_limit(double limit) | GeometryHealerTool | |
set_default_analytic_tol(double tol) | GeometryHealerTool | |
set_default_geombuild_tol(double tol) | GeometryHealerTool | |
set_default_isospline_tol(double tol) | GeometryHealerTool | |
set_default_reblend_classify_tol(double tol) | GeometryHealerTool | |
set_default_reblend_tol(double tol) | GeometryHealerTool | |
set_default_simplify_tol(double tol) | GeometryHealerTool | |
set_default_stitch_max_tol(double tol) | GeometryHealerTool | |
set_default_stitch_min_tol(double tol) | GeometryHealerTool | |
set_inc_analytic_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_genericspline_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_geombuild_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_isospline_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_postprocess_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_preprocess_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_reblend_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_sharpedge_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_simplify_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_stitch_flg(CubitBoolean flg) | GeometryHealerTool | |
set_inc_wrapup_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_bodies_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_coedges_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_curves_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_loops_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_shells_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_surfaces_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_vertices_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_bad_volumes_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_details_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_method(int method) | GeometryHealerTool | |
set_show_on_heal_flg(CubitBoolean flg) | GeometryHealerTool | |
set_show_summary_flg(CubitBoolean flg) | GeometryHealerTool | |
set_surf_on_heal_limit(double limit) | GeometryHealerTool | |
set_vol_on_heal_limit(double limit) | GeometryHealerTool | |
~GeometryHealerTool() | GeometryHealerTool | |
