cgma
GeometryQueryEngine Member List
This is the complete list of members for GeometryQueryEngine, including all inherited members.
bodies_overlap(BodySM *body_ptr_1, BodySM *body_ptr_2) const =0GeometryQueryEngine [pure virtual]
curve_is_on_ignored_surface(Curve *, Surface *)GeometryQueryEngine [inline, virtual]
delete_solid_model_entities(DLIList< BodySM * > &body_list) const =0GeometryQueryEngine [pure virtual]
delete_solid_model_entities(GeometryEntity *ref_entity_ptr) const GeometryQueryEngine [virtual]
delete_solid_model_entities(BodySM *body_ptr) const =0GeometryQueryEngine [pure virtual]
delete_solid_model_entities(Surface *surf_ptr) const =0GeometryQueryEngine [pure virtual]
delete_solid_model_entities(Curve *curve_ptr) const =0GeometryQueryEngine [pure virtual]
delete_solid_model_entities(TBPoint *point_ptr) const =0GeometryQueryEngine [pure virtual]
delete_topology_bridge(TopologyBridge *bridge) const GeometryQueryEngine [virtual]
entity_entity_distance(GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)=0GeometryQueryEngine [pure virtual]
entity_extrema(DLIList< GeometryEntity * > &ref_entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr)=0GeometryQueryEngine [pure virtual]
export_solid_model(DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options)=0GeometryQueryEngine [pure virtual]
export_solid_model(DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)=0GeometryQueryEngine [pure virtual]
fire_ray(CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits=0, double ray_radius=0.0, DLIList< TopologyBridge * > *hit_entity_list=0) const =0GeometryQueryEngine [pure virtual]
get_allint_version()GeometryQueryEngine [virtual]
get_engine_version_string()=0GeometryQueryEngine [pure virtual]
get_graphics(BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const GeometryQueryEngine [virtual]
get_graphics(Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance=15, double distance_tolerance=0, double longest_edge=0) const =0GeometryQueryEngine [pure virtual]
get_graphics(Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double max_edge_length=0.0) const GeometryQueryEngine [virtual]
get_graphics(Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const =0GeometryQueryEngine [pure virtual]
get_intersections(Curve *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
get_intersections(Curve *curve, Surface *surface, DLIList< CubitVector > &intersection_list, bool bounded=false)=0GeometryQueryEngine [pure virtual]
get_isoparametric_points(Surface *ref_face_ptr, int &nu, int &nv, GMem *&gMem) const =0GeometryQueryEngine [pure virtual]
get_major_version()=0GeometryQueryEngine [pure virtual]
get_minor_version()=0GeometryQueryEngine [pure virtual]
get_ordered_loops(RefFace *, DLIList< Loop * > &) const GeometryQueryEngine [inline, virtual]
get_point_containment(DLIList< BodySM * > &body_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices)GeometryQueryEngine [virtual]
get_sme_resabs_tolerance() const =0GeometryQueryEngine [pure virtual]
get_subminor_version()=0GeometryQueryEngine [pure virtual]
get_u_isoparametric_points(Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const =0GeometryQueryEngine [pure virtual]
get_underlying_bridges(TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list)GeometryQueryEngine [virtual]
get_underlying_curves(Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list)GeometryQueryEngine [virtual]
get_underlying_surfaces(Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list)GeometryQueryEngine [virtual]
get_v_isoparametric_points(Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const =0GeometryQueryEngine [pure virtual]
get_visible_entities(TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs)GeometryQueryEngine [virtual]
get_visible_entity_at_point(TopologyBridge *, CubitVector *)GeometryQueryEngine [inline, virtual]
import_solid_model(const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options)=0GeometryQueryEngine [pure virtual]
import_solid_model(DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size)=0GeometryQueryEngine [pure virtual]
is_intermediate_engine()GeometryQueryEngine [inline, virtual]
list_engine_versions(CubitString &versions)GeometryQueryEngine [virtual]
modeler_type()=0GeometryQueryEngine [pure virtual]
reflect(BodySM *body, const CubitVector &axis)=0GeometryQueryEngine [pure virtual]
reflect(GeometryEntity *ent, const CubitVector &axis)=0GeometryQueryEngine [pure virtual]
restore_transform(BodySM *body)=0GeometryQueryEngine [pure virtual]
rotate(BodySM *body, const CubitVector &axis, double angle)=0GeometryQueryEngine [pure virtual]
rotate(GeometryEntity *ent, const CubitVector &axis, double degrees)=0GeometryQueryEngine [pure virtual]
save_temp_geom_file(DLIList< TopologyBridge * > &ref_entity_list, const char *filename, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type)=0GeometryQueryEngine [pure virtual]
scale(BodySM *body, double factor)=0GeometryQueryEngine [pure virtual]
scale(BodySM *body, const CubitVector &factors)=0GeometryQueryEngine [pure virtual]
scale(GeometryEntity *ent, double factor)=0GeometryQueryEngine [pure virtual]
scale(GeometryEntity *ent, const CubitVector &factors)=0GeometryQueryEngine [pure virtual]
set_dbl_option(const char *opt_name, double val)=0GeometryQueryEngine [pure virtual]
set_export_allint_version(const int version)GeometryQueryEngine [virtual]
set_export_version(const int major, const int minor)GeometryQueryEngine [virtual]
set_int_option(const char *opt_name, int val)=0GeometryQueryEngine [pure virtual]
set_sme_resabs_tolerance(double new_resabs)=0GeometryQueryEngine [pure virtual]
set_str_option(const char *opt_name, const char *val)=0GeometryQueryEngine [pure virtual]
transform_vec_position(CubitVector const &position_vector, BodySM *OSME_ptr, CubitVector &transform_vector) const =0GeometryQueryEngine [pure virtual]
translate(BodySM *body, const CubitVector &offset)=0GeometryQueryEngine [pure virtual]
translate(GeometryEntity *ent, const CubitVector &offset)=0GeometryQueryEngine [pure virtual]
validate_geometry_database() const GeometryQueryEngine [inline, virtual]
volumes_overlap(Lump *lump1, Lump *lump2) const =0GeometryQueryEngine [pure virtual]
~GeometryQueryEngine()GeometryQueryEngine [inline, virtual]
