check_valid_chain(DLIList< RefEdge * > &ref_edge_list, DLIList< RefVertex * > &problem_vertices) | GeometryUtil | |
check_valid_chain_by_coord(DLIList< RefEdge * > &ref_edge_list, DLIList< RefVertex * > &problem_vertices) | GeometryUtil | |
check_valid_loop(DLIList< RefEdge * > &ref_edge_list, DLIList< RefVertex * > &problem_vertices) | GeometryUtil | |
check_valid_loop_by_coord(DLIList< RefEdge * > &ref_edge_list, DLIList< RefVertex * > &problem_vertices) | GeometryUtil | |
closest_face_coedge(RefFace *face_ptr, const CubitVector &from_pt, CoEdge *&other_coedge, CubitVector *closest_pt=NULL) | GeometryUtil | |
closest_loop_coedge(Loop *loop_ptr, const CubitVector &from_pt, CoEdge *&other_coedge, CubitVector *closest_pt=NULL) | GeometryUtil | |
closest_point_trimmed(RefFace *face_ptr, const CubitVector &from_pt, CubitVector &result_pt, CubitPointContainment *cont=0) | GeometryUtil | |
closest_shell_coface(Shell *shell_ptr, const CubitVector &from_pt, DLIList< CoFace * > &result_set, CubitVector *closest_pt=NULL) | GeometryUtil | |
default_angle_tol | GeometryUtil | |
default_midpoint_tol | GeometryUtil | |
delete_instance() | GeometryUtil | [inline, static] |
find_connected_ref_edge(RefVertex *ref_vertex_ptr, DLIList< RefEdge * > &ref_edge_list, int &start_flg) | GeometryUtil | |
find_connected_ref_edge_by_coord(CubitVector &coords, DLIList< RefEdge * > &ref_edge_list, int &start_flg) | GeometryUtil | |
find_connected_ref_edges(RefVertex *ref_vertex_ptr, DLIList< RefEdge * > &ref_edge_list, DLIList< RefEdge * > &connected_edges_list) | GeometryUtil | |
find_connected_ref_edges_by_coord(CubitVector &coords, DLIList< RefEdge * > &ref_edge_list, DLIList< RefEdge * > &connected_edges_list) | GeometryUtil | |
form_ref_edge_chain(DLIList< RefEdge * > &ref_edge_list) | GeometryUtil | |
form_ref_edge_chain_by_coord(DLIList< RefEdge * > &ref_edge_list) | GeometryUtil | |
form_ref_edge_loop(DLIList< RefEdge * > &ref_edge_list) | GeometryUtil | |
form_ref_edge_loop_by_coord(DLIList< RefEdge * > &ref_edge_list) | GeometryUtil | |
GeometryUtil() | GeometryUtil | [protected] |
inside_of_curve(const CubitVector &curve_tangent, const CubitVector &curve_position, const CubitVector &surf_position, const CubitVector &surf_normal) | GeometryUtil | [protected] |
instance_ | GeometryUtil | [private, static] |
is_point_on_face(RefFace *ref_face_ptr, const CubitVector &point, CubitBoolean check_on_surface=CUBIT_TRUE) | GeometryUtil | |
is_position_in_volume(const CubitVector &position, RefVolume *ref_volume_ptr, CubitVector *closest_on_bounary=NULL) | GeometryUtil | |
is_position_within_loop(const CubitVector &position, Loop *loop_ptr, CubitVector *closest_on_loop=NULL, CubitVector *normal=NULL) | GeometryUtil | |
is_position_within_shell(const CubitVector &position, Shell *shell_ptr, CubitVector *closest_on_shell=NULL) | GeometryUtil | |
is_shell_a_void(Shell *shell_ptr) | GeometryUtil | |
linearized_curve_debug_count_ | GeometryUtil | [private] |
list_SM_topology(TopologyBridge *bridge, int depth) | GeometryUtil | [static] |
list_SM_topology(TopologyBridge *bridge, int depth, int indent, int counts[8]) | GeometryUtil | [protected, static] |
loop_area(Loop *loop_ptr) | GeometryUtil | |
make_linearized_curve(Surface *surface_ptr, const CubitVector &start_pt, const CubitVector &end_pt, DLIList< CubitVector * > &segment_points, double arc_angle_tol=CUBIT_DBL_MAX, double midpoint_dist_tol=CUBIT_DBL_MAX, const CubitVector *mid_point=NULL) | GeometryUtil | |
other_cpu_time | GeometryUtil | |
print_topo_bridge(TopologyBridge *bridge, int indent) | GeometryUtil | [protected, static] |
recursive_make_curve(Surface *surface_ptr, const CubitVector &start_pt, const CubitVector &end_pt, DLIList< CubitVector * > &segment_points, double arc_angle_tol, double midpoint_dist_tol) | GeometryUtil | [protected] |
surface_cpu_time | GeometryUtil | |
valid_edge(RefEdge *edge_ptr, CubitBoolean print_error=CUBIT_TRUE) | GeometryUtil | |
valid_loop_coedges(Loop *loop_ptr, CubitBoolean print_error=CUBIT_TRUE) | GeometryUtil | |
valid_shell_cofaces(Shell *shell_ptr, CubitBoolean print_error=CUBIT_TRUE) | GeometryUtil | |
valid_sm_topology(DLIList< RefEntity * > &entity_list, CubitBoolean print_error=CUBIT_TRUE) | GeometryUtil | |
valid_sm_topology(Body *body_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(RefVolume *vol_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(Shell *shell_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(RefFace *face_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(Loop *loop_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(CoEdge *coedge_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(RefEdge *edge_ptr, CubitBoolean print) | GeometryUtil | |
valid_sm_topology(RefVertex *vtx_ptr, CubitBoolean print) | GeometryUtil | |
valid_topology(TopologyEntity *topo_ptr, CubitBoolean print_error=CUBIT_TRUE, DLIList< TopologyEntity * > *invalid_list=NULL) | GeometryUtil | |
