cgma
OCCQueryEngine Member List
This is the complete list of members for OCCQueryEngine, including all inherited members.
add_shape_to_map(TopoDS_Shape &sh, TopoDS_Shape &aShape, int &current_id)OCCQueryEngine [private]
bodies_overlap(BodySM *body_ptr_1, BodySM *body_ptr_2) const OCCQueryEngine [virtual]
body_attributes_for_writing(DLIList< OCCBody * > &OCC_bodies, BRep_Builder &B, TopoDS_Compound &Co, DLIList< OCCLump * > &single_lumps, DLIList< DLIList< CubitSimpleAttrib > * > &lists)OCCQueryEngine
BodyListOCCQueryEngine
bound_TopoDS_Shape(const TopoDS_Shape &aShape)OCCQueryEngine
copy_attributes(TopoDS_Shape &old_shape, TopoDS_Shape &new_shape)OCCQueryEngine
create_super_bounding_box(DLIList< BodySM * > &body_list, CubitBox &super_box)OCCQueryEngine
curve_is_on_ignored_surface(Curve *, Surface *)GeometryQueryEngine [inline, virtual]
CurveListOCCQueryEngine
delete_bodies(DLIList< BodySM * > &body_list, bool remove_lower_entities=CUBIT_TRUE) const OCCQueryEngine
delete_body(BodySM *body_ptr, bool remove_lower_entities=CUBIT_TRUE) const OCCQueryEngine
delete_loop(LoopSM *loopsm) const OCCQueryEngine [private]
delete_solid_model_entities(DLIList< BodySM * > &body_list) const OCCQueryEngine [virtual]
delete_solid_model_entities(GeometryEntity *ref_entity_ptr, bool remove_lower_entities) const OCCQueryEngine [virtual]
delete_solid_model_entities(BodySM *body_ptr) const OCCQueryEngine [virtual]
delete_solid_model_entities(Surface *surf_ptr) const OCCQueryEngine [virtual]
delete_solid_model_entities(Curve *curve_ptr) const OCCQueryEngine [virtual]
delete_solid_model_entities(TBPoint *point_ptr) const OCCQueryEngine [virtual]
GeometryQueryEngine::delete_solid_model_entities(GeometryEntity *ref_entity_ptr) const GeometryQueryEngine [virtual]
delete_topology_bridge(TopologyBridge *bridge) const GeometryQueryEngine [virtual]
ensure_is_ascii_stl_file(FILE *fp, CubitBoolean &is_ascii)OCCQueryEngine
entity_entity_distance(GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)OCCQueryEngine [virtual]
entity_extrema(DLIList< GeometryEntity * > &ref_entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr)OCCQueryEngine [virtual]
entity_type_info() const OCCQueryEngine [virtual]
EXPORT_ATTRIBOCCQueryEngine
export_solid_model(DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options)OCCQueryEngine [virtual]
export_solid_model(DLIList< TopologyBridge * > &ref_entity_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)OCCQueryEngine [virtual]
fire_ray(CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits=0, double ray_radius=0.0, DLIList< TopologyBridge * > *hit_entity_list=0) const OCCQueryEngine [virtual]
get_allint_version()GeometryQueryEngine [virtual]
get_connected_patch(DLIList< OCCSurface * > &remaining_surfs, DLIList< OCCSurface * > &output_patch)OCCQueryEngine
get_engine_version_string()OCCQueryEngine [virtual]
get_graphics(Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance=15, double distance_tolerance=0, double longest_edge=0) const OCCQueryEngine [virtual]
get_graphics(TopoDS_Face *face_ptr, GMem *g_mem, unsigned short normal_tolerance=15, double distance_tolerance=0, double max_edge_length=0) const OCCQueryEngine
get_graphics(Curve *curve_ptr, GMem *gMem=NULL, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0.0) const OCCQueryEngine [virtual]
get_graphics(TopoDS_Edge *edge_ptr, GMem *gMem=NULL, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const OCCQueryEngine
GeometryQueryEngine::get_graphics(BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const GeometryQueryEngine [virtual]
GeometryQueryEngine::get_graphics(Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double max_edge_length=0.0) const GeometryQueryEngine [virtual]
get_intersections(Curve *, CubitVector &point1, CubitVector &, DLIList< CubitVector > &, CubitBoolean, CubitBoolean)OCCQueryEngine [virtual]
get_intersections(Curve *, Curve *, DLIList< CubitVector > &, CubitBoolean, CubitBoolean)OCCQueryEngine [virtual]
get_intersections(Curve *ref_edge, Surface *ref_face, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE)OCCQueryEngine [virtual]
GeometryQueryEngine::get_intersections(Curve *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
GeometryQueryEngine::get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
GeometryQueryEngine::get_intersections(Curve *curve, Surface *surface, DLIList< CubitVector > &intersection_list, bool bounded=false)=0GeometryQueryEngine [pure virtual]
get_isoparametric_points(Surface *, int &, int &, GMem *&) const OCCQueryEngine [virtual]
get_major_version()OCCQueryEngine [virtual]
get_minor_version()OCCQueryEngine [virtual]
get_ordered_loops(RefFace *, DLIList< Loop * > &) const GeometryQueryEngine [inline, virtual]
get_point_containment(DLIList< BodySM * > &body_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices)GeometryQueryEngine [virtual]
get_sme_resabs_tolerance() const OCCQueryEngine [virtual]
get_subminor_version()OCCQueryEngine [virtual]
get_TopoDS_Shape_of_entity(TopologyBridge *entity)OCCQueryEngine
get_u_isoparametric_points(Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const OCCQueryEngine [virtual]
get_underlying_bridges(TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list)GeometryQueryEngine [virtual]
get_underlying_curves(Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list)GeometryQueryEngine [virtual]
get_underlying_surfaces(Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list)GeometryQueryEngine [virtual]
get_v_isoparametric_points(Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const OCCQueryEngine [virtual]
get_visible_entities(TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs)GeometryQueryEngine [virtual]
get_visible_entity_at_point(TopologyBridge *, CubitVector *)GeometryQueryEngine [inline, virtual]
Handle(TDocStd_Document) MyDFOCCQueryEngine
import_solid_model(const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &options)OCCQueryEngine [virtual]
import_solid_model(DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size)OCCQueryEngine [virtual]
import_solid_model(FILE *file_ptr, const char *, DLIList< TopologyBridge * > &imported_entities, CubitBoolean print_results=CUBIT_TRUE, const char *logfile_name=NULL, CubitBoolean heal_step=CUBIT_TRUE, CubitBoolean import_bodies=CUBIT_TRUE, CubitBoolean import_surfaces=CUBIT_TRUE, CubitBoolean import_curves=CUBIT_TRUE, CubitBoolean import_vertices=CUBIT_TRUE, CubitBoolean free_surfaces=CUBIT_TRUE)OCCQueryEngine [private]
import_temp_geom_file(FILE *file_ptr, const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &bridge_list)OCCQueryEngine [virtual]
instance()OCCQueryEngine [static]
instance_OCCQueryEngine [private, static]
is_intermediate_engine()GeometryQueryEngine [inline, virtual]
is_solid_modeler_type() const OCCQueryEngine [inline, virtual]
iTotalTBCreatedOCCQueryEngine [static]
list_engine_versions(CubitString &versions)GeometryQueryEngine [virtual]
mainLabelOCCQueryEngine
modeler_type()OCCQueryEngine [inline, virtual]
occ_to_cgm(const TopoDS_Shape &shape)OCCQueryEngine
OCCMapOCCQueryEngine
OCCQueryEngine()OCCQueryEngine [protected]
OCCSurface classOCCQueryEngine [friend]
OccToCGMOCCQueryEngine
populate_topology_bridge(TopoDS_Shape &aShape)OCCQueryEngine
populate_topology_bridge(const TopoDS_Compound &aShape)OCCQueryEngine
populate_topology_bridge(const TopoDS_Solid &aShape, CubitBoolean build_body=CUBIT_FALSE)OCCQueryEngine
populate_topology_bridge(const TopoDS_Face &aShape, CubitBoolean build_body=CUBIT_FALSE)OCCQueryEngine
populate_topology_bridge(const TopoDS_Edge &aShape, CubitBoolean stand_along=CUBIT_FALSE)OCCQueryEngine
populate_topology_bridge(const TopoDS_Vertex &aShape, CubitBoolean stand_along=CUBIT_FALSE)OCCQueryEngine
populate_topology_bridge(const TopoDS_Shell &aShape, CubitBoolean standalone=CUBIT_FALSE)OCCQueryEngine
populate_topology_bridge(const TopoDS_Wire &aShape, CubitBoolean standalone=CUBIT_FALSE)OCCQueryEngine [private]
Read(TopoDS_Shape &Shapes, const Standard_CString File, TDF_Label label)OCCQueryEngine [private]
Read(TopoDS_Shape &Sh, const char *pBuffer, const int n_buffer_size, TDF_Label label)OCCQueryEngine [private]
reflect(BodySM *body, const CubitVector &axis)OCCQueryEngine [virtual]
reflect(GeometryEntity *ent, const CubitVector &axis)OCCQueryEngine [virtual]
restore_transform(BodySM *body)OCCQueryEngine [virtual]
rotate(BodySM *body, const CubitVector &axis, double angle)OCCQueryEngine [virtual]
rotate(GeometryEntity *ent, const CubitVector &axis, double degrees)OCCQueryEngine [virtual]
save_temp_geom_file(DLIList< TopologyBridge * > &ref_entity_list, const char *file_name, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type)OCCQueryEngine [virtual]
scale(BodySM *body, double factor)OCCQueryEngine [virtual]
scale(BodySM *body, const CubitVector &factors)OCCQueryEngine [virtual]
scale(GeometryEntity *ent, double factor)OCCQueryEngine [virtual]
scale(GeometryEntity *ent, const CubitVector &factors)OCCQueryEngine [virtual]
set_dbl_option(const char *opt_name, double val)OCCQueryEngine [virtual]
set_export_allint_version(const int version)GeometryQueryEngine [virtual]
set_export_version(const int major, const int minor)GeometryQueryEngine [virtual]
set_int_option(const char *opt_name, int val)OCCQueryEngine [virtual]
set_sme_resabs_tolerance(double new_resabs)OCCQueryEngine [virtual]
set_str_option(const char *opt_name, const char *val)OCCQueryEngine [virtual]
set_TopoDS_Shape(TopologyBridge *tb, TopoDS_Shape &new_shape)OCCQueryEngine
Shape_Label_MapOCCQueryEngine
SurfaceListOCCQueryEngine
total_coedgesOCCQueryEngine [static]
transform_vec_position(CubitVector const &, BodySM *, CubitVector &) const OCCQueryEngine [virtual]
translate(BodySM *body, const CubitVector &offset)OCCQueryEngine [virtual]
translate(GeometryEntity *ent, const CubitVector &offset)OCCQueryEngine [virtual]
unhook_BodySM_from_OCC(BodySM *bodysm, bool remove_lower_entities=CUBIT_TRUE) const OCCQueryEngine
unhook_CoEdges_from_OCC(DLIList< OCCCoEdge * > &coedges) const OCCQueryEngine [private]
unhook_coedges_of_a_curve(OCCCurve *curve, OCCLoop *loop) const OCCQueryEngine [private]
unhook_Curve_from_OCC(Curve *curve) const OCCQueryEngine
unhook_LoopSM_from_OCC(LoopSM *loopsm) const OCCQueryEngine [private]
unhook_Lump_from_OCC(Lump *lump) const OCCQueryEngine [private]
unhook_Point_from_OCC(TBPoint *point) const OCCQueryEngine
unhook_ShellSM_from_OCC(ShellSM *shell) const OCCQueryEngine [private]
unhook_Surface_from_OCC(Surface *surface) const OCCQueryEngine
update_entity_shape(GeometryEntity *entity_ptr, BRepBuilderAPI_ModifyShape *aTranf, BRepAlgoAPI_BooleanOperation *op=NULL)OCCQueryEngine
update_OCC_map(TopoDS_Shape &old_shape, TopoDS_Shape &new_shape)OCCQueryEngine
validate_geometry_database() const GeometryQueryEngine [inline, virtual]
volumes_overlap(Lump *lump1, Lump *lump2) const OCCQueryEngine [virtual]
WireListOCCQueryEngine
Write(const TopoDS_Shape &Sh, const Standard_CString File, TDF_Label label)OCCQueryEngine [private]
Write(const TopoDS_Shape &Sh, char *&p_buffer, int &n_buffer_size, bool b_export_buffer, TDF_Label label)OCCQueryEngine [private]
write_topology(const char *file_name, Model_File_Type file_type, DLIList< OCCBody * > &facet_bodies, DLIList< OCCSurface * > &facet_surfaces, DLIList< OCCCurve * > &facet_curves, DLIList< OCCPoint * > &facet_points)OCCQueryEngine [private]
write_topology(char *&p_buffer, int &n_buffer_size, bool b_export_buffer, DLIList< OCCBody * > &OCC_bodies, DLIList< OCCSurface * > &OCC_surfaces, DLIList< OCCCurve * > &OCC_curves, DLIList< OCCPoint * > &OCC_points)OCCQueryEngine [private]
~GeometryQueryEngine()GeometryQueryEngine [inline, virtual]
~OCCQueryEngine()OCCQueryEngine [virtual]
