cgma
OldUnmergeCode Member List
This is the complete list of members for OldUnmergeCode, including all inherited members.
cleanup_unmerge()OldUnmergeCode [private]
end_unmerge(CubitBoolean top)OldUnmergeCode [inline, private]
event_listOldUnmergeCode [private]
find_curves(TBPoint *point_ptr, DLIList< Curve * > &result_set)OldUnmergeCode [private, static]
find_surfaces(Curve *curve_ptr, DLIList< Surface * > &result_set)OldUnmergeCode [private, static]
get_use_old_unmerge_code()OldUnmergeCode [static]
initialize_settings()OldUnmergeCode [static]
instance()OldUnmergeCode [static]
new_unmergedOldUnmergeCode [private]
old_unmergedOldUnmergeCode [private]
OldUnmergeCode()OldUnmergeCode [inline, private]
remove_CAEntityId_attrib(TopologyBridge *tb_ptr)OldUnmergeCode [private, static]
set_use_old_unmerge_code(bool value)OldUnmergeCode [static]
split_out_Curves(DLIList< Curve * > &curve_list, CubitBoolean &reversed)OldUnmergeCode [private]
split_out_Loop(LoopSM *loopsm, RefFace *new_loop_owner, CubitBoolean reverse)OldUnmergeCode [private]
split_out_Points(DLIList< TBPoint * > &point_list)OldUnmergeCode [private]
split_out_Surface(Surface *surface_ptr, CubitBoolean &reversed)OldUnmergeCode [private]
start_unmerge()OldUnmergeCode [inline, private]
unmerge(DLIList< RefEntity * > &entity_list, CubitBoolean descend=CUBIT_TRUE)OldUnmergeCode
unmerge(RefEntity *entity_ptr, CubitBoolean descend=CUBIT_TRUE)OldUnmergeCode
unmerge(RefFace *face_ptr, CubitBoolean descend=CUBIT_TRUE)OldUnmergeCode
unmerge(RefEdge *edge_ptr, CubitBoolean descend=CUBIT_TRUE)OldUnmergeCode
unmerge(Body *body_ptr)OldUnmergeCode
unmerge(RefVolume *vol_ptr)OldUnmergeCode
unmerge(RefVertex *vertex_ptr)OldUnmergeCode
unmerge(RefFace *face_ptr, RefVolume *parent_ptr)OldUnmergeCode [private]
unmerge(RefEdge *edge_ptr, RefFace *parent_ptr)OldUnmergeCode [private]
unmerge(RefVertex *vtx_ptr, RefEdge *parent_ptr)OldUnmergeCode [private]
unmerge_all()OldUnmergeCode
unmerge_modifiedOldUnmergeCode [private]
unmerged_list_in_useOldUnmergeCode [private]
useOldUnmergeCodeOldUnmergeCode [private, static]
