add(PartitionShell *shell) | PartitionLump | |
append_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionLump | [virtual] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const | PartitionLump | [virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
ChildType typedef | Lump | |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
find_parent_body() const | PartitionLump | |
first_shell() const | PartitionLump | [inline] |
geometry_type() | Lump | [inline, virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_all_children(DLIList< PartitionEntity * > &result) | PartitionLump | |
get_body() const | PartitionLump | |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &) | PartitionLump | [virtual] |
get_geometry_query_engine() const | PartitionLump | [virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &) | PartitionLump | [virtual] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_simple_attribute(DLIList< CubitSimpleAttrib > &) | PartitionLump | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | PartitionLump | [virtual] |
layer() const | PartitionLump | [inline, virtual] |
listHead | PartitionLump | [private] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
Lump() | Lump | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
mark | PartitionEntity | |
mass_properties(CubitVector &volume_centrioid, double &volume) | PartitionLump | [virtual] |
Lump::mass_properties(CubitVector[3], CubitVector &, CubitVector &, double &) | Lump | [inline, virtual] |
MAX_TB_LAYER enum value | TopologyBridge | |
measure() | PartitionLump | [virtual] |
move_to_geometry(CubitVector &position) | PartitionEntity | [virtual] |
next_shell(PartitionShell *after_this=0) const | PartitionLump | [inline] |
notify_split(FacetEntity *, FacetEntity *) | PartitionLump | [virtual] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
PartitionBody class | PartitionLump | [friend] |
partitioned_entity() const | PartitionEntity | [inline] |
PartitionEntity() | PartitionEntity | [protected] |
PartitionLump(Lump *real_lump) | PartitionLump | |
PartitionLump(PartitionLump *split_from) | PartitionLump | |
point_containment(const CubitVector &pos, double tolerance=-1) | PartitionLump | |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
print_debug_info(const char *prefix=0, bool print_subentity_set=true) const | PartitionEntity | [virtual] |
print_partitioned_entity(const char *prefix=0) const | PartitionEntity | |
real_lump() const | PartitionLump | |
relax_to_geometry(CubitPoint *facet_point, const CubitVector *input_position=0) | PartitionEntity | |
remove(PartitionShell *shell) | PartitionLump | |
remove_all_shells() | PartitionLump | |
remove_all_simple_attribute_virt() | PartitionLump | [virtual] |
remove_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionLump | [virtual] |
reverse_bridge_sense() | TopologyBridge | [inline] |
reverse_sense() | PartitionLump | [virtual] |
save(CubitSimpleAttrib &) | PartitionLump | [virtual] |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
sub_entity_set() const | PartitionEntity | [inline] |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
transform(const CubitTransformMatrix &) | PartitionLump | [virtual] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~Lump() | Lump | [virtual] |
~PartitionEntity() | PartitionEntity | [virtual] |
~PartitionLump() | PartitionLump | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
