can_remove(RefVertex *vertex) | PartitionTool | [virtual] |
can_remove(RefEdge *edge) | PartitionTool | [virtual] |
can_remove(RefFace *face) | PartitionTool | [virtual] |
commonGroupingEntities(BasicTopologyEntity *first_bte_ptr, BasicTopologyEntity *secnd_bte_ptr, GroupingEntity *&first_gpe_ptr, GroupingEntity *&second_gpe_ptr) const | PartitionTool | [private] |
destroy_volume_partition(RefVolume *partition) | PartitionTool | |
facetingTolerance | PartitionTool | [private] |
get_faceting_tolerance() | PartitionTool | [inline] |
group_merged_surfaces(DLIList< RefFace * > &face_list, int &num_result_sets) | PartitionTool | [protected] |
insert_edge(RefFace *face_ptr, DLIList< CubitVector * > &segments, CubitBoolean is_meshed, DLIList< RefEdge * > &created_curves, int level_of_recursion=0, const double *tolerance_length=NULL) | PartitionTool | [virtual] |
insert_edge(DLIList< RefFace * > &input_faces, DLIList< CubitVector * > &segments, DLIList< RefFace * > &result_faces, DLIList< RefEdge * > &created_edges, CubitBoolean do_split_curves=CUBIT_FALSE) | PartitionTool | [virtual] |
instance() | PartitionTool | [inline, static] |
instance_ | PartitionTool | [protected, static] |
make_point_curve(RefFace *ref_face, const CubitVector &position) | PartitionTool | |
make_point_curves(RefFace *ref_face, DLIList< CubitVector > &position, DLIList< RefVertex * > &new_vertices) | PartitionTool | |
notify_partition(DLIList< RefEntity * > &partitioning_entities, BasicTopologyEntity *first_partitioned_entity, BasicTopologyEntity *second_partitioned_entity, BasicTopologyEntity *old_entity) | PartitionTool | [private] |
partition(RefEdge *edge_ptr, const CubitVector &split_point, RefEdge *&first_new_edge, RefEdge *&second_new_edge, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | [virtual] |
partition(RefEdge *edge_ptr, const CubitVector &split_point, DLIList< RefEdge * > &result_edges, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | [virtual] |
partition(RefFace *face_ptr, RefEdge *edge_ptr, RefFace *&new_face1, RefFace *&new_face2, CubitBoolean) | PartitionTool | [virtual] |
partition(RefFace *face_ptr, DLIList< RefEdge * > &split_edges, RefFace *&first_new_face, RefFace *&second_new_face, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | [virtual] |
partition(RefVolume *vol_ptr, DLIList< RefFace * > &split_faces, RefVolume *&first_new_volume, RefVolume *&second_new_volume, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | [virtual] |
partition(RefVolume *vol_ptr, DLIList< CubitFacet * > &split_faces, RefVolume *&first_new_volume, RefVolume *&second_new_volume, DLIList< RefFace * > &new_surfaces, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | [virtual] |
partition(RefEdge *edge_ptr, DLIList< CubitVector * > &split_points, DLIList< RefEdge * > &new_edges, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | |
partition(RefEdge *edge_ptr, DLIList< CubitVector * > &split_points, DLIList< RefVertex * > &new_vertices, DLIList< RefEdge * > &new_edges, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | |
partition(RefFace *face_ptr, const DLIList< RefEdge * > &split_edges, DLIList< RefFace * > &result_faces, CubitBoolean do_split_curves=CUBIT_FALSE, DLIList< RefEdge * > *new_edges=NULL, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | |
partition_face_by_curves(RefFace *face_ptr, const DLIList< Curve * > &split_curves, DLIList< RefFace * > &result_faces, CubitBoolean do_split_curves=CUBIT_FALSE, DLIList< RefEdge * > *new_edges=NULL, CubitBoolean ignore_mesh=CUBIT_FALSE) | PartitionTool | |
PartitionTool() | PartitionTool | [protected] |
unpartition(RefEdge *first_partition_edge, RefEdge *second_partition_edge) | PartitionTool | |
unpartition(RefFace *first_partition_face, RefFace *second_partition_face) | PartitionTool | |
unpartition(RefVolume *first_partition_volume, RefVolume *second_partition_volume) | PartitionTool | |
unpartition(DLIList< RefVolume * > &partition_volumes) | PartitionTool | |
unpartitionAll(DLIList< RefEdge * > &partition_edges, DLIList< RefEdge * > &restored_edges) | PartitionTool | [virtual] |
unpartitionAll(DLIList< RefFace * > &partition_faces, DLIList< RefFace * > &restored_faces) | PartitionTool | [virtual] |
unpartitionAll(DLIList< RefVolume * > &partition_vols, DLIList< RefVolume * > &restored_vols) | PartitionTool | [virtual] |
~PartitionTool() | PartitionTool | [virtual] |
