add_child(RStarTreeNode< Y > *child_node, CubitBoolean recalc_b_box) | RStarTreeNode< Y > | |
adjust_tree(RStarTreeNode< Y > *l, RStarTreeNode< Y > *ll, RStarTreeNode< Y > *root_node, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels) | RStarTreeNode< Y > | [private] |
bounding_box() | RStarTreeNode< Y > | [inline] |
calc_enlargement(RStarTreeNode< Y > *current, RStarTreeNode< Y > *add_to) | RStarTreeNode< Y > | [private] |
calc_enlargement(CubitBox ¤t, CubitBox &add_to) | RStarTreeNode< Y > | [private] |
calc_overlap(RStarTreeNode< Y > *current, RStarTreeNode< Y > *add_to) | RStarTreeNode< Y > | [private] |
can_add() | RStarTreeNode< Y > | |
choose_sub_tree(RStarTreeNode< Y > *n, RStarTreeNode< Y > *e) | RStarTreeNode< Y > | [private] |
condense_tree(RStarTreeNode< Y > *l, RStarTreeNode< Y > *root, RStarTreeNode< Y > *&new_root) | RStarTreeNode< Y > | [private] |
dist_is_box() | RStarTreeNode< Y > | [inline] |
distIsBox | RStarTreeNode< Y > | [private] |
find_leaf(Y e, CubitBox &e_box, RStarTreeNode< Y > *t, RStarTreeNode< Y > *&l) | RStarTreeNode< Y > | [private] |
flush(CubitBox &new_box) | RStarTreeNode< Y > | |
get_child(int i) | RStarTreeNode< Y > | [inline] |
get_data() | RStarTreeNode< Y > | [inline] |
get_dist() | RStarTreeNode< Y > | [inline] |
get_leaf_level() | RStarTreeNode< Y > | [inline] |
get_parent() | RStarTreeNode< Y > | [inline] |
insert(RStarTreeNode< Y > *e, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels) | RStarTreeNode< Y > | |
is_data() | RStarTreeNode< Y > | [inline] |
is_leaf() | RStarTreeNode< Y > | [inline] |
margin(CubitBox &bounding_box) | RStarTreeNode< Y > | [private] |
markedFlag | RStarTreeNode< Y > | [private] |
maxChildren | RStarTreeNode< Y > | [private] |
minChildren | RStarTreeNode< Y > | [private] |
myBoundingBox | RStarTreeNode< Y > | [private] |
myChildrenNodes | RStarTreeNode< Y > | [private] |
myData | RStarTreeNode< Y > | [private] |
myDist | RStarTreeNode< Y > | [private] |
myId | RStarTreeNode< Y > | [private] |
myLevel | RStarTreeNode< Y > | [private] |
myParent | RStarTreeNode< Y > | [private] |
nextChildIndex | RStarTreeNode< Y > | [private] |
num_children() | RStarTreeNode< Y > | [inline] |
overflow_treatment(RStarTreeNode< Y > *l, RStarTreeNode< Y > *e, RStarTreeNode< Y > *&ll, RStarTreeNode< Y > *root, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels) | RStarTreeNode< Y > | [private] |
recalc_b_box() | RStarTreeNode< Y > | |
reinsert(RStarTreeNode< Y > *l, RStarTreeNode< Y > *e, RStarTreeNode< Y > *root, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels) | RStarTreeNode< Y > | [private] |
remove(Y e, RStarTreeNode< Y > *&new_root, CubitBoolean &delete_root) | RStarTreeNode< Y > | |
remove_child(RStarTreeNode< Y > *child) | RStarTreeNode< Y > | |
RStarTreeNode(Y data, double tol, int max_children, int min_children) | RStarTreeNode< Y > | |
RStarTreeNode(CubitBox &bounding_box, int max_children, int min_children) | RStarTreeNode< Y > | |
set_dist(double dis) | RStarTreeNode< Y > | [inline] |
set_dist_is_box(int val) | RStarTreeNode< Y > | [inline] |
set_leaf_level(int r_type) | RStarTreeNode< Y > | [inline] |
set_parent(RStarTreeNode< Y > *parent) | RStarTreeNode< Y > | [inline] |
sort_center_distance(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
sort_high_x(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
sort_high_y(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
sort_high_z(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
sort_low_x(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
sort_low_y(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
sort_low_z(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2) | RStarTreeNode< Y > | [private, static] |
space_left() | RStarTreeNode< Y > | |
split_node(RStarTreeNode< Y > *l, RStarTreeNode< Y > *e, RStarTreeNode< Y > *&ll) | RStarTreeNode< Y > | [private] |
super_box(DLIList< RStarTreeNode< Y > * > &node_list) | RStarTreeNode< Y > | [private] |
validate_tree(int print) | RStarTreeNode< Y > | |
volume(CubitBox &box) | RStarTreeNode< Y > | [inline, private] |
volume(RStarTreeNode< Y > *curr) | RStarTreeNode< Y > | [inline, private] |
~RStarTreeNode() | RStarTreeNode< Y > | |
