cgma
RefEntityFactory Member List
This is the complete list of members for RefEntityFactory, including all inherited members.
add(RefEntity *ref_entity)RefEntityFactory [virtual]
add(Body *bodyPtr)RefEntityFactory [virtual]
add(RefVolume *refVolumePtr)RefEntityFactory [virtual]
add(RefGroup *refGroupPtr)RefEntityFactory [virtual]
add(RefFace *refFacePtr)RefEntityFactory [virtual]
add(RefEdge *refEdgePtr)RefEntityFactory [virtual]
add(RefVertex *refVertexPtr)RefEntityFactory [virtual]
bodies(DLIList< Body * > &bodies)RefEntityFactory [virtual]
bodyListRefEntityFactory [private]
bodyListIsSortedRefEntityFactory [private]
compress_ids(DLIList< CubitEntity * > &list)RefEntityFactory [static]
compress_ref_ids(const char *entity_type, int retain_max_id)RefEntityFactory
construct_Body(BodySM *body_sm=NULL)RefEntityFactory [virtual]
construct_RefEdge(Curve *curve=NULL)RefEntityFactory [virtual]
construct_RefFace(Surface *surface=NULL)RefEntityFactory [virtual]
construct_RefGroup(const char *name=NULL)RefEntityFactory [virtual]
construct_RefGroup(DLIList< RefEntity * > &entity_list)RefEntityFactory [virtual]
construct_RefVertex(TBPoint *point=NULL)RefEntityFactory [virtual]
construct_RefVolume(Lump *lump=NULL)RefEntityFactory [virtual]
CubitObserver()CubitObserver
current_body_id()RefEntityFactory [inline]
current_edge_id()RefEntityFactory [inline]
current_face_id()RefEntityFactory [inline]
current_group_id()RefEntityFactory [inline]
current_vertex_id()RefEntityFactory [inline]
current_volume_id()RefEntityFactory [inline]
delete_instance()RefEntityFactory [static]
get_body(int id)RefEntityFactory [virtual]
get_first_body()RefEntityFactory [virtual]
get_first_ref_edge()RefEntityFactory [virtual]
get_first_ref_face()RefEntityFactory [virtual]
get_first_ref_group()RefEntityFactory [virtual]
get_first_ref_vertex()RefEntityFactory [virtual]
get_first_ref_volume()RefEntityFactory [virtual]
get_last_body()RefEntityFactory [virtual]
get_last_ref_edge()RefEntityFactory [virtual]
get_last_ref_face()RefEntityFactory [virtual]
get_last_ref_group()RefEntityFactory [virtual]
get_last_ref_vertex()RefEntityFactory [virtual]
get_last_ref_volume()RefEntityFactory [virtual]
get_next_body()RefEntityFactory [virtual]
get_next_ref_edge()RefEntityFactory [virtual]
get_next_ref_face()RefEntityFactory [virtual]
get_next_ref_group()RefEntityFactory [virtual]
get_next_ref_vertex()RefEntityFactory [virtual]
get_next_ref_volume()RefEntityFactory [virtual]
get_ref_edge(int id)RefEntityFactory [virtual]
get_ref_entity(const char *type, int id)RefEntityFactory [virtual]
get_ref_entity(const std::type_info &type, int id)RefEntityFactory [virtual]
get_ref_face(int id)RefEntityFactory [virtual]
get_ref_group(int id)RefEntityFactory [virtual]
get_ref_vertex(int id)RefEntityFactory [virtual]
get_ref_volume(int id)RefEntityFactory [virtual]
incorporate_id(RefEntity *ref_ent)RefEntityFactory
instance_RefEntityFactory [protected, static]
ManageListSortingRefEntityFactory [protected]
maxBodyIdRefEntityFactory [protected]
maxCurveSubDomainIdRefEntityFactory [protected]
maximum_id(const char *entity_type)RefEntityFactory
maximum_id(RefEntity *ref_ent)RefEntityFactory
maximum_id(const std::type_info &type, int max_id)RefEntityFactory
maxRefCoordSysIdRefEntityFactory [protected]
maxRefEdgeIdRefEntityFactory [protected]
maxRefFaceIdRefEntityFactory [protected]
maxRefGroupIdRefEntityFactory [protected]
maxRefVertexIdRefEntityFactory [protected]
maxRefVolumeIdRefEntityFactory [protected]
maxSurfSubDomainIdRefEntityFactory [protected]
next_body_id()RefEntityFactory
next_curve_sub_domain_id()RefEntityFactory
next_ref_edge_id()RefEntityFactory
next_ref_face_id()RefEntityFactory
next_ref_group_id()RefEntityFactory
next_ref_vertex_id()RefEntityFactory
next_ref_volume_id()RefEntityFactory
next_surf_sub_domain_id()RefEntityFactory
notify_observer(const CubitEvent *observer_event)RefEntityFactory [virtual]
num_bodies() const RefEntityFactory [virtual]
num_ref_edges() const RefEntityFactory [virtual]
num_ref_faces() const RefEntityFactory [virtual]
num_ref_groups() const RefEntityFactory [virtual]
num_ref_vertices() const RefEntityFactory [virtual]
num_ref_volumes() const RefEntityFactory [virtual]
ref_edges(DLIList< RefEdge * > &ref_edges)RefEntityFactory [virtual]
ref_entity_list(char const *keyword, DLIList< RefEntity * > &entity_list, const CubitBoolean print_errors=CUBIT_TRUE)RefEntityFactory [virtual]
ref_faces(DLIList< RefFace * > &ref_faces)RefEntityFactory [virtual]
ref_groups(DLIList< RefGroup * > &ref_groups)RefEntityFactory [virtual]
ref_vertices(DLIList< RefVertex * > &ref_vertices)RefEntityFactory [virtual]
ref_volumes(DLIList< RefVolume * > &ref_volumes)RefEntityFactory [virtual]
refEdgeListRefEntityFactory [private]
refEdgeListIsSortedRefEntityFactory [private]
RefEntityFactory(bool make_lists=true)RefEntityFactory [protected]
refFaceListRefEntityFactory [private]
refFaceListIsSortedRefEntityFactory [private]
refGroupListRefEntityFactory [private]
refGroupListIsSortedRefEntityFactory [private]
refVertexListRefEntityFactory [private]
refVertexListIsSortedRefEntityFactory [private]
refVolumeListRefEntityFactory [private]
refVolumeListIsSortedRefEntityFactory [private]
register_observable(CubitObservable *observable)CubitObserver
register_observer(CubitObserver *obs)CubitObserver [static]
remove(RefEntity *ref_entity)RefEntityFactory [virtual]
remove(RefVertex *refVertexPtr)RefEntityFactory [virtual]
remove(RefEdge *refEdgePtr)RefEntityFactory [virtual]
remove(RefFace *refFacePtr)RefEntityFactory [virtual]
remove(RefGroup *refGroupPtr)RefEntityFactory [virtual]
remove(RefVolume *refVolumePtr)RefEntityFactory [virtual]
remove(Body *bodyPtr)RefEntityFactory [virtual]
renumber_geometry_by_properties(CubitBoolean retain_max_ids)RefEntityFactory [virtual]
reset_ids()RefEntityFactory
stop_watching_observable(CubitObservable *observable)CubitObserver [inline]
unregister_observable(CubitObservable *observable)CubitObserver
unregister_observer(CubitObserver *obs)CubitObserver [static]
watch_observable(CubitObservable *observable)CubitObserver [inline]
~CubitObserver()CubitObserver [virtual]
~RefEntityFactory()RefEntityFactory [protected, virtual]
