add_refentity_name(RefEntity *entity, CubitString &name, bool update_attribs=true, bool check_name_validity=true) | RefEntityName | |
add_refentity_name(RefEntity *entity, DLIList< CubitString > &names, bool update_attribs=true, bool check_name_validity=true) | RefEntityName | |
base_name(const CubitString &name) | RefEntityName | [static] |
clean(CubitString &raw_name) | RefEntityName | [private] |
copy_refentity_names(const RefEntity *source, RefEntity *target, CubitBoolean update_attribs=CUBIT_TRUE) | RefEntityName | |
copy_refentity_names(DLIList< RefEntity * > &source_list, RefEntity *target, CubitBoolean unique_base_names=CUBIT_TRUE, CubitBoolean update_attribs=CUBIT_TRUE) | RefEntityName | |
delete_instance() | RefEntityName | [inline, static] |
fixDuplicateNames | RefEntityName | [private, static] |
generate_unique_name(CubitString &name) | RefEntityName | [private] |
generateDefaultNames | RefEntityName | [private, static] |
get_character(const CubitString &type) const | RefEntityName | |
get_fix_duplicate_names() | RefEntityName | [static] |
get_generate_default_names() | RefEntityName | [static] |
get_merge_base_names() | RefEntityName | [inline, static] |
get_refentity(const CubitString &name) | RefEntityName | |
get_refentity_id(const CubitString &name) | RefEntityName | |
get_refentity_name(const RefEntity *entity, DLIList< CubitString > &names) | RefEntityName | |
get_refentity_type(const CubitString &name) | RefEntityName | |
get_replacement_setting() | RefEntityName | [static] |
get_suffix_setting() | RefEntityName | [static] |
initialize_settings() | RefEntityName | [static] |
instance() | RefEntityName | [static] |
instance_ | RefEntityName | [private, static] |
list_refentity_names(const char *type="all") | RefEntityName | |
merge_refentity_names(RefEntity *retained, RefEntity *dead) | RefEntityName | |
mergeBaseNames | RefEntityName | [private, static] |
nameEntityList | RefEntityName | [private] |
num_name_change_warnings() | RefEntityName | [inline] |
num_name_change_warnings(int new_val) | RefEntityName | [inline] |
numNameChangeWarnings | RefEntityName | [private, static] |
print_name_change_warnings() | RefEntityName | [inline] |
print_name_change_warnings(bool new_val) | RefEntityName | [inline] |
printNameChangeWarnings | RefEntityName | [private, static] |
RefEntityName() | RefEntityName | [protected] |
remove_refentity_name(RefEntity *entity, const CubitString &name, CubitBoolean update_attribs=CUBIT_TRUE) | RefEntityName | |
remove_refentity_name(RefEntity *entity, CubitBoolean update_attribs=CUBIT_TRUE) | RefEntityName | |
replacementCharacter | RefEntityName | [private, static] |
same_base_name(const CubitString &name1, const CubitString &name2) | RefEntityName | |
set_character(char rep, const CubitString &type) | RefEntityName | |
set_fix_duplicate_names(int on_off) | RefEntityName | [static] |
set_generate_default_names(int on_off) | RefEntityName | [static] |
set_merge_base_names(CubitBoolean flag) | RefEntityName | [inline, static] |
set_replacement_setting(CubitString rep) | RefEntityName | [static] |
set_suffix_setting(CubitString rep) | RefEntityName | [static] |
suffixCharacter | RefEntityName | [private, static] |
switch_refentity_names(RefEntity *entity1, RefEntity *entity2) | RefEntityName | |
~RefEntityName() | RefEntityName | |
