cgma
SplitCompositeSurfaceTool Member List
This is the complete list of members for SplitCompositeSurfaceTool, including all inherited members.
delete_instance()SplitCompositeSurfaceTool [inline, static]
find_face_with_non_zero_param_dir(DLIList< Surface * > &surf_list, CubitVector &dir, CubitVector &pos, Surface *&ret_surf, double &du, double &dv, double &step)SplitCompositeSurfaceTool [private]
find_faces_for_pos(CubitVector &pos, DLIList< Surface * > surf_list, CubitPointContainment &containment, DLIList< Surface * > &out_list)SplitCompositeSurfaceTool [private]
get_additional_split_points(Surface *surf, DLIList< DLIList< CubitVector * > * > &vec_lists)SplitCompositeSurfaceTool [private]
instance()SplitCompositeSurfaceTool [static]
instance_SplitCompositeSurfaceTool [private, static]
split_surface(RefFace *ref_face_ptr, DLIList< CubitVector * > &locations, DLIList< DLIList< CubitVector * > * > &vec_lists, CubitBoolean preview_flg=CUBIT_FALSE, CubitBoolean create_ref_edges_flg=CUBIT_FALSE, CubitBoolean clear_previous_previews=CUBIT_TRUE)SplitCompositeSurfaceTool
split_surface(DLIList< RefFace * > &ref_face_list, DLIList< CubitVector * > &locations, DLIList< DLIList< DLIList< CubitVector * > * > * > &list_of_vec_lists, CubitBoolean preview_flg=CUBIT_FALSE, CubitBoolean create_ref_edges_flg=CUBIT_FALSE, CubitBoolean clear_previous_previews=CUBIT_TRUE)SplitCompositeSurfaceTool
