add_attribute(PartitionEntity *entity, const CubitSimpleAttrib &csa) | SubEntitySet | |
add_lower_order(PartitionEntity *partition) | SubEntitySet | |
add_lower_order(PartitionEntity *entity, const CubitSimpleAttrib &attrib, int dimension, DLIList< CubitVector * > &points_from_attrib, DLIList< int > &facets_from_attrib, DLIList< int > &children_from_attrib, DLIList< int > &facet_point_owners_from_attrib) | SubEntitySet | |
add_partition(PartitionEntity *partition, PartitionEntity *insert_after=0) | SubEntitySet | |
body() const | SubEntitySet | [inline] |
bodyNext | SubEntitySet | [private] |
bodyPtr | SubEntitySet | [private] |
bridge_destroyed(TopologyBridge *bridge) | SubEntitySet | [virtual] |
contains_bridge(TopologyBridge *bridge) const | TBOwner | [inline, virtual] |
entity_from_id(int id) const | SubEntitySet | |
get_attributes(PartitionEntity *entity, DLIList< CubitSimpleAttrib > &list) | SubEntitySet | |
get_attributes(PartitionEntity *entity, const char *name, DLIList< CubitSimpleAttrib > &list) | SubEntitySet | |
get_entity() const | SubEntitySet | [inline] |
get_geom_dimension(const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
get_geom_id(const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
get_id(PartitionEntity *entity) const | SubEntitySet | |
get_lower_order(DLIList< PartitionEntity * > &result_set) const | SubEntitySet | |
get_owner_layer() const | SubEntitySet | [inline, virtual] |
get_owners(DLIList< TopologyBridge * > &owner_list) const | SubEntitySet | [virtual] |
get_segment_count(const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
get_sub_entities(DLIList< PartitionEntity * > &result_set) const | SubEntitySet | |
get_unique_id() | SubEntitySet | |
has_lower_order() const | SubEntitySet | [inline] |
has_multiple_sub_entities() const | SubEntitySet | |
is_attribute(const CubitSimpleAttrib &csa, int id=0) const | SubEntitySet | [private] |
lastId | SubEntitySet | [private] |
layerNumber | SubEntitySet | [private] |
lowerOrderHead | SubEntitySet | [private] |
myEntity | SubEntitySet | [private] |
next_in_body() const | SubEntitySet | [inline] |
notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_reversed(TopologyBridge *bridge) | SubEntitySet | [virtual] |
notify_split(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
operator=(const SubEntitySet &) | SubEntitySet | [inline, private] |
operator==(const SubEntitySet &c) const | SubEntitySet | [inline, private] |
PartitionBody class | SubEntitySet | [friend] |
print_debug_info(const char *prefix=0) const | SubEntitySet | |
read_geometry(int &id, int &dimension, DLIList< CubitVector * > &point_list, DLIList< int > &point_connectivity, DLIList< int > &topo_connectivity, DLIList< int > &point_owners, const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
rem_all_attrib(PartitionEntity *entity) | SubEntitySet | |
rem_attribute(PartitionEntity *entity, const CubitSimpleAttrib &csa) | SubEntitySet | |
remove(PartitionEntity *partition) | SubEntitySet | |
remove_bridge(TopologyBridge *bridge) | SubEntitySet | [virtual] |
remove_non_geom_attribs(DLIList< CubitSimpleAttrib > &list) | SubEntitySet | [static] |
renumerate(int lowest_value, bool only_higher_ids) | SubEntitySet | |
reset_unique_id() | SubEntitySet | [inline] |
save_geometry() | SubEntitySet | |
save_geometry(int id, int dimension, DLIList< CubitVector * > *point_list, DLIList< int > *point_connectivity, DLIList< int > *topo_connectivity, DLIList< int > *point_owners, CubitSimpleAttrib &attrib) | SubEntitySet | |
set_id(PartitionEntity *entity, int id) | SubEntitySet | |
strip_attributes(TopologyBridge *bridge) | SubEntitySet | [static] |
strip_attributes() | SubEntitySet | |
subEntityHead | SubEntitySet | [private] |
SubEntitySet(TopologyBridge *real_entity, PartitionEntity *first_partition) | SubEntitySet | |
swap_bridge(TopologyBridge *remove, TopologyBridge *add, bool reversed) | SubEntitySet | [virtual] |
uniqueId | SubEntitySet | [private] |
unwrap_attribute(CubitSimpleAttrib &csa) const | SubEntitySet | [private] |
unwrap_attributes() | SubEntitySet | |
wrap_attribute(CubitSimpleAttrib &csa, int id) const | SubEntitySet | [private] |
~SubEntitySet() | SubEntitySet | [virtual] |
~TBOwner() | TBOwner | [virtual] |
~TBOwnerSet() | TBOwnerSet | |
