, including all inherited members.
append_simple_attribute_virt(const CubitSimpleAttrib &)=0 | TopologyBridge | [pure virtual] |
are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list) | Surface | [virtual] |
bodysm() | TopologyBridge | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() const =0 | GeometryEntity | [pure virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
ChildType typedef | Surface | |
closest_point(CubitVector const &location, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL, CubitVector *curvature1=NULL, CubitVector *curvature2=NULL)=0 | Surface | [pure virtual] |
closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface)=0 | Surface | [pure virtual] |
closest_point_trimmed(CubitVector from_point, CubitVector &point_on_surface)=0 | Surface | [pure virtual] |
closest_point_uv_guess(CubitVector const &location, double &u_guess, double &v_guess, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL)=0 | Surface | [pure virtual] |
closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL) | Surface | [virtual] |
closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list) | Surface | [virtual] |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2)=0 | Surface | [pure virtual] |
evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3]) | Surface | [virtual] |
geometry_type() | Surface | [inline, virtual] |
GeometryEntity() | GeometryEntity | [inline] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &children)=0 | TopologyBridge | [pure virtual] |
get_cone_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const =0 | Surface | [pure virtual] |
get_geometry_query_engine() const =0 | TopologyBridge | [pure virtual] |
get_geometry_sense()=0 | Surface | [pure virtual] |
get_nurb_params(bool &rational, int °ree_u, int °ree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const =0 | Surface | [pure virtual] |
get_param_range_U(double &lower_bound, double &upper_bound)=0 | Surface | [pure virtual] |
get_param_range_V(double &lower_bound, double &upper_bound)=0 | Surface | [pure virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &parents)=0 | TopologyBridge | [pure virtual] |
get_point_normal(CubitVector &point, CubitVector &normal)=0 | Surface | [pure virtual] |
get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance)=0 | Surface | [pure virtual] |
get_saved_id() const | GeometryEntity | [inline] |
get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
get_shell_sense(ShellSM *shell_ptr) const =0 | Surface | [pure virtual] |
get_simple_attribute(DLIList< CubitSimpleAttrib > &)=0 | TopologyBridge | [pure virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)=0 | TopologyBridge | [pure virtual] |
get_sphere_params(CubitVector ¢er, double &radius) const =0 | Surface | [pure virtual] |
get_torus_params(CubitVector ¢er, CubitVector &normal, double &major_radius, double &minor_radius) const =0 | Surface | [pure virtual] |
get_uv_sense() | Surface | [inline, virtual] |
is_closed_in_U() | Surface | [inline, virtual] |
is_closed_in_V() | Surface | [inline, virtual] |
is_cylindrical() | Surface | [inline, virtual] |
is_parametric()=0 | Surface | [pure virtual] |
is_periodic()=0 | Surface | [pure virtual] |
is_periodic_in_U(double &period)=0 | Surface | [pure virtual] |
is_periodic_in_V(double &period)=0 | Surface | [pure virtual] |
is_position_on(CubitVector &test_position)=0 | Surface | [pure virtual] |
is_singular_in_U(double u_param)=0 | Surface | [pure virtual] |
is_singular_in_V(double v_param)=0 | Surface | [pure virtual] |
layer() const | TopologyBridge | [inline, virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
MAX_TB_LAYER enum value | TopologyBridge | |
measure()=0 | GeometryEntity | [pure virtual] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
param_dir(CubitVector &, CubitVector &, double &, double &) | Surface | [inline, virtual] |
point_containment(const CubitVector &point)=0 | Surface | [pure virtual] |
point_containment(double u, double v)=0 | Surface | [pure virtual] |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
position_from_u_v(double u, double v)=0 | Surface | [pure virtual] |
principal_curvatures(CubitVector const &location, double &curvature_1, double &curvature_2, CubitVector *closest_location=NULL)=0 | Surface | [pure virtual] |
remove_all_simple_attribute_virt()=0 | TopologyBridge | [pure virtual] |
remove_simple_attribute_virt(const CubitSimpleAttrib &)=0 | TopologyBridge | [pure virtual] |
reverse_bridge_sense() | TopologyBridge | [inline] |
set_saved_id(int value) | GeometryEntity | [inline] |
set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
Surface() | Surface | |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
u_v_from_position(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL)=0 | Surface | [pure virtual] |
uv_derivitives(double u_param, double v_param, CubitVector &du, CubitVector &dv)=0 | Surface | [pure virtual] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~GeometryEntity() | GeometryEntity | [virtual] |
~Surface() | Surface | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
