cgma
TDFacetBoundaryEdge Member List
This is the complete list of members for TDFacetBoundaryEdge, including all inherited members.
add_facet_boundary_edge(CubitFacetEdge *edge_ptr)TDFacetBoundaryEdge [static]
add_surf(int new_id)TDFacetBoundaryEdge
add_surf_facet(DLIList< CubitFacet * > &facet_list)TDFacetBoundaryEdge
compute_curve_tangent(int surf_id, CubitFacetEdge *edge, double min_dot, CubitVector &T0, CubitVector &T3)TDFacetBoundaryEdge
control_points(CubitVector *ctrl_pts, int surf_id)TDFacetBoundaryEdge
control_points(CubitVector *ctrl_pts, int order, int surf_id)TDFacetBoundaryEdge
control_points(CubitFacet *facet, CubitVector *ctrl_pts)TDFacetBoundaryEdge
destroy_memory()TDFacetBoundaryEdge [inline, static]
edgeDataListTDFacetBoundaryEdge [private]
edgePtrTDFacetBoundaryEdge [private]
get_control_points(CubitPoint *point_ptr, CubitVector ctrl_pts[3], int surf_id)TDFacetBoundaryEdge
get_edge()TDFacetBoundaryEdge [inline]
get_facet_boundary_edge(CubitFacetEdge *edge_ptr)TDFacetBoundaryEdge [static]
get_next_edge()TDFacetBoundaryEdge [inline]
get_prev_edge()TDFacetBoundaryEdge [inline]
init_control_points(double min_dot)TDFacetBoundaryEdge
is_at_surf(int surf_id)TDFacetBoundaryEdge
is_facet_boundary_edge(const ToolData *td)TDFacetBoundaryEdge [inline, static]
is_internal_edge()TDFacetBoundaryEdge
memoryManagerTDFacetBoundaryEdge [private, static]
merge(ToolDataUser *other_td_user)ToolData [virtual]
merge_control_points()TDFacetBoundaryEdge
next_feature_edge(int surf_id, CubitFacetEdge *this_edge, CubitPoint *p0)TDFacetBoundaryEdge
next_tool_data()ToolData [inline]
next_tool_data(ToolData *data)ToolData [inline]
nextEdgePtrTDFacetBoundaryEdge [private]
prevEdgePtrTDFacetBoundaryEdge [private]
propogate(ToolDataUser *new_td_user)ToolData [virtual]
set_control_points(CubitPoint *point_ptr, CubitVector ctrl_pts[3], int surf_id)TDFacetBoundaryEdge
set_edge(CubitFacetEdge *edge_ptr)TDFacetBoundaryEdge [inline]
set_next_edge(CubitFacetEdge *edge_ptr)TDFacetBoundaryEdge [inline]
set_prev_edge(CubitFacetEdge *edge_ptr)TDFacetBoundaryEdge [inline]
set_surf_id(CubitFacet *facet_ptr, int surf_id)TDFacetBoundaryEdge
SetDynamicMemoryAllocation(memoryManager) static void set_memory_allocation_increment(int increment=0)TDFacetBoundaryEdge [inline, pure virtual]
TDFacetBoundaryEdge()TDFacetBoundaryEdge
ToolData()ToolData [inline, protected]
~TDFacetBoundaryEdge()TDFacetBoundaryEdge
~ToolData()ToolData [virtual]
