cgma
TDGeomFacet Member List
This is the complete list of members for TDGeomFacet, including all inherited members.
add_cholla_curve(ChollaCurve *chcurv_ptr)TDGeomFacet [inline]
add_cholla_owner(ChollaEntity *cholla_entity)TDGeomFacet
add_cholla_point(ChollaPoint *chpt_ptr)TDGeomFacet [inline]
add_cholla_surf(ChollaSurface *f_s_m)TDGeomFacet
add_geom_facet(FacetEntity *facet_entity, int block_id)TDGeomFacet [static]
add_geom_facet(CubitFacet *facet_ptr, int block_id)TDGeomFacet [static]
add_geom_facet(CubitFacetEdge *edge_ptr, int block_id)TDGeomFacet [static]
add_geom_facet(CubitPoint *point_ptr, int block_id)TDGeomFacet [static]
add_partner_edge(CubitFacetEdge *partner)TDGeomFacet [inline]
add_partner_point(CubitPoint *partner)TDGeomFacet [inline]
add_point(CubitPoint *point)TDGeomFacet [inline]
blockIdTDGeomFacet [private]
ChollaCurveListTDGeomFacet [private]
ChollaPointListTDGeomFacet [private]
ChollaSurfaceListTDGeomFacet [private]
delete_point(CubitPoint *point)TDGeomFacet [inline]
destroy_memory()TDGeomFacet [inline, static]
geo_type()TDGeomFacet
get_block_id()TDGeomFacet [inline]
get_block_id(FacetEntity *mesh_entity)TDGeomFacet [static]
get_block_id(CubitFacet *facet_ptr)TDGeomFacet [static]
get_block_id(CubitFacetEdge *edge_ptr)TDGeomFacet [static]
get_block_id(CubitPoint *point_ptr)TDGeomFacet [static]
get_cholla_curves(DLIList< ChollaCurve * > &curv_list)TDGeomFacet [inline]
get_cholla_points(DLIList< ChollaPoint * > &point_list)TDGeomFacet [inline]
get_cholla_surfs(DLIList< ChollaSurface * > &surf_list)TDGeomFacet [inline]
get_first_point()TDGeomFacet [inline]
get_geom_facet(FacetEntity *facet_entity)TDGeomFacet [static]
get_geom_facet(CubitFacet *facet_ptr)TDGeomFacet [static]
get_geom_facet(CubitFacetEdge *edge_ptr)TDGeomFacet [static]
get_geom_facet(CubitPoint *point_ptr)TDGeomFacet [static]
get_hit_flag()TDGeomFacet [inline]
get_hit_flag(FacetEntity *mesh_entity)TDGeomFacet [static]
get_normal()TDGeomFacet [inline]
get_partner_edges(DLIList< CubitFacetEdge * > &partner_list)TDGeomFacet [inline]
get_partner_points(DLIList< CubitPoint * > &partner_list)TDGeomFacet [inline]
get_points(DLIList< CubitPoint * > &point_list)TDGeomFacet [inline]
hitFlagTDGeomFacet [private]
is_geom_facet(const ToolData *td)TDGeomFacet [static]
is_in_volume(ChollaVolume *chvol_ptr)TDGeomFacet
is_partner(CubitFacetEdge *edge_ptr)TDGeomFacet
is_partner(CubitPoint *point_ptr)TDGeomFacet
memoryManagerTDGeomFacet [private, static]
merge(ToolDataUser *other_td_user)ToolData [virtual]
myPointsTDGeomFacet [private]
next_tool_data()ToolData [inline]
next_tool_data(ToolData *data)ToolData [inline]
normalTDGeomFacet [private]
num_partner_edges()TDGeomFacet [inline]
num_partner_points()TDGeomFacet [inline]
partnerEdgeListTDGeomFacet [private]
partnerPointListTDGeomFacet [private]
propogate(ToolDataUser *new_td_user)ToolData [virtual]
remove_cholla_curve(ChollaCurve *chcurv_ptr)TDGeomFacet [inline]
remove_cholla_curves()TDGeomFacet [inline]
remove_cholla_point(ChollaPoint *point_ptr)TDGeomFacet [inline]
remove_cholla_points()TDGeomFacet [inline]
remove_cholla_surf(ChollaSurface *chsurf_ptr)TDGeomFacet [inline]
remove_cholla_surfs()TDGeomFacet [inline]
reset_TD_as_new()TDGeomFacet
set_block_id(int new_id)TDGeomFacet [inline]
set_hit_flag(int flag)TDGeomFacet [inline]
set_hit_flag(FacetEntity *mesh_entity, int new_val)TDGeomFacet [static]
set_normal(CubitVector &norm)TDGeomFacet [inline]
SetDynamicMemoryAllocation(memoryManager) static void set_memory_allocation_increment(int increment=0)TDGeomFacet [inline, pure virtual]
TDGeomFacet()TDGeomFacet
ToolData()ToolData [inline, protected]
~TDGeomFacet()TDGeomFacet
~ToolData()ToolData [virtual]
