MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef MOAB_BSP_TREE_POLY_HPP 00002 #define MOAB_BSP_TREE_POLY_HPP 00003 00004 #include "moab/Types.hpp" 00005 #include <vector> 00006 00007 namespace moab 00008 { 00009 00010 class CartVect; 00011 00012 /**\brief Convex polyhedron 00013 * 00014 * This class is used to represent the convex polyhedron that bounds 00015 * a node in a general plane-based BSP-tree. 00016 */ 00017 class BSPTreePoly 00018 { 00019 public: 00020 struct Vertex; 00021 struct VertexUse; 00022 struct Edge; 00023 struct EdgeUse; 00024 struct Face; 00025 00026 private: 00027 Face* faceList; 00028 00029 void set_vertex_marks( int value ); 00030 00031 BSPTreePoly( const BSPTreePoly& copy ); // not implemented 00032 BSPTreePoly& operator=( const BSPTreePoly& copy ); // not implemented 00033 00034 public: 00035 /**\brief Initialize as a planar-faced hexahedron 00036 *\param hex_corners Corner coordinates for a hexahedron, in Exodus/Patran order 00037 */ 00038 BSPTreePoly( const CartVect hex_corners[8] ) : faceList( 0 ) 00039 { 00040 set( hex_corners ); 00041 } 00042 BSPTreePoly() : faceList( 0 ) {} 00043 ~BSPTreePoly() 00044 { 00045 clear(); 00046 } 00047 00048 /**\brief Initialize as a planar-faced hexahedron 00049 *\param hex_corners Corner coordinates for a hexahedron, in Exodus/Patran order 00050 */ 00051 ErrorCode set( const CartVect hex_corners[8] ); 00052 void clear(); 00053 00054 /**\brief Get handles for faces */ 00055 void get_faces( std::vector< const Face* >& face_list ) const; 00056 /**\brief Get corner coordinates for a face */ 00057 void get_vertices( const Face* face, std::vector< CartVect >& vertices ) const; 00058 00059 /** Intersect a plane with a polyhedron, retaining 00060 * the portion of the polyhedron below the plane. 00061 * This will fail if polyhedron is not convex. 00062 */ 00063 bool cut_polyhedron( const CartVect& plane_normal, double plane_coeff ); 00064 00065 /** Test if a point is contained in the polyhedron. 00066 * 00067 *\NOTE algorithm assumes *convex* polyhedron. 00068 */ 00069 bool is_point_contained( const CartVect& point ) const; 00070 00071 //! Assumes planar faces 00072 double volume() const; 00073 00074 // Check that data structure is consistent and represents 00075 // a closed polyhedron 00076 bool is_valid() const; 00077 00078 /** For debugging, does nothing unless debug feature is enabled */ 00079 static void reset_debug_ids(); 00080 }; 00081 00082 } // namespace moab 00083 00084 #endif
