MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef __smoab_detail_CellTypeToType_h 00002 #define __smoab_detail_CellTypeToType_h 00003 00004 #include "vtkCellType.h" 00005 #include <algorithm> 00006 00007 namespace smoab 00008 { 00009 namespace detail 00010 { 00011 00012 template < int N > 00013 struct QuadratricOrdering 00014 { 00015 }; 00016 00017 template <> 00018 struct QuadratricOrdering< VTK_QUADRATIC_WEDGE > 00019 { 00020 static const int NUM_VERTS = 15; 00021 void reorder( vtkIdType* connectivity ) const 00022 { 00023 std::swap_ranges( connectivity + 9, connectivity + 12, connectivity + 12 ); 00024 } 00025 }; 00026 00027 template <> 00028 struct QuadratricOrdering< VTK_TRIQUADRATIC_HEXAHEDRON > 00029 { 00030 static const int NUM_VERTS = 27; 00031 void reorder( vtkIdType* connectivity ) const 00032 { 00033 std::swap_ranges( connectivity + 12, connectivity + 16, connectivity + 16 ); 00034 00035 //move 20 to 22 00036 //move 22 to 23 00037 //move 23 to 20 00038 00039 //swap 20 with 22 00040 std::swap( connectivity[20], connectivity[23] ); 00041 00042 //swap 22 with 23 00043 std::swap( connectivity[22], connectivity[23] ); 00044 } 00045 }; 00046 00047 template < typename QuadraticOrdering > 00048 void FixQuadraticIdOrdering( vtkIdType* connectivity, vtkIdType numCells, QuadraticOrdering& ordering ) 00049 { 00050 //skip the first index that holds the length of the cells 00051 //if we skip it once here, and than properly increment it makes the code 00052 //far easier 00053 connectivity += 1; 00054 for( vtkIdType i = 0; i < numCells; ++i ) 00055 { 00056 ordering.reorder( connectivity ); 00057 connectivity += ordering.NUM_VERTS + 1; 00058 } 00059 } 00060 00061 int vtkCellType( moab::EntityType t, int& num_connect ) 00062 { 00063 int ctype = -1; 00064 switch( t ) 00065 { 00066 case moab::MBEDGE: 00067 if( num_connect == 2 ) 00068 ctype = VTK_LINE; 00069 else if( num_connect == 3 ) 00070 ctype = VTK_QUADRATIC_EDGE; 00071 break; 00072 case moab::MBTRI: 00073 if( num_connect == 3 ) 00074 ctype = VTK_TRIANGLE; 00075 else if( num_connect == 6 ) 00076 ctype = VTK_QUADRATIC_TRIANGLE; 00077 else if( num_connect == 7 ) 00078 ctype = VTK_BIQUADRATIC_TRIANGLE; 00079 break; 00080 case moab::MBQUAD: 00081 if( num_connect == 4 ) 00082 ctype = VTK_QUAD; 00083 else if( num_connect == 8 ) 00084 ctype = VTK_QUADRATIC_QUAD; 00085 else if( num_connect == 9 ) 00086 ctype = VTK_BIQUADRATIC_QUAD; 00087 break; 00088 case moab::MBPOLYGON: 00089 if( num_connect == 4 ) ctype = VTK_POLYGON; 00090 break; 00091 case moab::MBTET: 00092 if( num_connect == 4 ) 00093 ctype = VTK_TETRA; 00094 else if( num_connect == 10 ) 00095 ctype = VTK_QUADRATIC_TETRA; 00096 break; 00097 case moab::MBPYRAMID: 00098 if( num_connect == 5 ) 00099 ctype = VTK_PYRAMID; 00100 else if( num_connect == 13 ) 00101 ctype = VTK_QUADRATIC_PYRAMID; 00102 break; 00103 case moab::MBPRISM: 00104 if( num_connect == 6 ) 00105 ctype = VTK_WEDGE; 00106 else if( num_connect == 15 ) 00107 ctype = VTK_QUADRATIC_WEDGE; 00108 break; 00109 case moab::MBHEX: 00110 if( num_connect == 8 ) 00111 ctype = VTK_HEXAHEDRON; 00112 else if( num_connect == 20 ) 00113 ctype = VTK_QUADRATIC_HEXAHEDRON; 00114 else if( num_connect == 21 ) 00115 ctype = VTK_QUADRATIC_HEXAHEDRON, num_connect = 20; 00116 else if( num_connect == 27 ) 00117 ctype = VTK_TRIQUADRATIC_HEXAHEDRON; 00118 break; 00119 default: 00120 ctype = -1; 00121 break; 00122 } 00123 return ctype; 00124 } 00125 00126 int vtkLinearCellType( moab::EntityType t, int& num_connect ) 00127 { 00128 int ctype = -1; 00129 switch( t ) 00130 { 00131 case moab::MBEDGE: 00132 ctype = VTK_LINE; 00133 num_connect = 2; 00134 break; 00135 case moab::MBTRI: 00136 ctype = VTK_TRIANGLE; 00137 num_connect = 3; 00138 break; 00139 case moab::MBQUAD: 00140 ctype = VTK_QUAD; 00141 num_connect = 4; 00142 break; 00143 case moab::MBPOLYGON: 00144 ctype = VTK_POLYGON; 00145 num_connect = 4; 00146 break; 00147 case moab::MBTET: 00148 ctype = VTK_TETRA; 00149 num_connect = 4; 00150 break; 00151 case moab::MBPYRAMID: 00152 ctype = VTK_PYRAMID; 00153 num_connect = 5; 00154 break; 00155 case moab::MBPRISM: 00156 ctype = VTK_WEDGE; 00157 num_connect = 6; 00158 break; 00159 case moab::MBHEX: 00160 ctype = VTK_HEXAHEDRON; 00161 num_connect = 8; 00162 break; 00163 default: 00164 break; 00165 } 00166 return ctype; 00167 } 00168 00169 } // namespace detail 00170 } // namespace smoab 00171 00172 #endif // CELLTYPETOTYPE_H
