MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file Compiler.hpp 00002 * \author Jason Kraftcheck 00003 * \date 2010-12-16 00004 * 00005 * Provide pre-processor macros for compiler-specific features. All 00006 * defined macros should expand to nothing if not supported by the 00007 * compiler. 00008 */ 00009 00010 #ifndef moab_COMPILER_HPP 00011 #define moab_COMPILER_HPP 00012 00013 #ifdef IS_BUILDING_MB 00014 00015 /**\defgroup PRIVCOMP Private Compiler-Specifc Pre-Processor Macros */ 00016 /*@{*/ 00017 00018 /**\def __restrict__ 00019 *\brief Provide functionality similar to C99 \c restrict keyword 00020 * 00021 * Tell the compiler that a pointer is not aliased. This means that 00022 * programmer guarantees that no other pointer will be used to reference 00023 * memory that is referenced through the designated pointer unless it 00024 * is obivous to the compiler in the relevant function. A typical use 00025 * for this is to specify that two pointer arguments to a function will 00026 * never be used to reference overlapping memory. For example: 00027 *\code 00028 * void* memcpy(void* __restrict__ dest, const void* __restrict__ src, size_t len); 00029 *\endcode 00030 * Says that the memory locations indicated by the \c dest and \c src pointers 00031 * will never be used to reference overlapping memory, including offsets up to 00032 * \c len. 00033 * 00034 * Notifying the compiler about lack of pointer aliasing allows it to make 00035 * better optimizations. However, the behavior is undefined (and probably 00036 * broken in platform-specific ways) if designated pointers are aliased. 00037 */ 00038 #ifdef __cplusplus 00039 #if !defined __GNUC__ || __GNUC__ < 4 || __GNUC_MINOR__ < 5 00040 #define __restrict__ 00041 #endif 00042 #endif 00043 00044 /*@}*/ 00045 00046 #endif 00047 00048 /**\defgroup PUBCOMP Public Compiler-Specifc Pre-Processor Macros */ 00049 /*@{*/ 00050 00051 /**\def PRINT_FORMAT(start) 00052 *\brief Give a hint to the compiler the function is like \c printf 00053 * 00054 * Tell the compiler that the function involves a printf-style format 00055 * string and varargs list. This gives the compiler the opportunity 00056 * to warn if the argument types do not match the format string. 00057 * This macro should be inluded after the complete function declaration, 00058 * but before the closing semi-colon. 00059 * 00060 *\param START The position of the format string in the argument list, where 00061 * the first argument is 1. 00062 *\NOTE This macro is designed to be used with member functions of C++ classes, 00063 * and therefore explicitly accounts for the implicit \c this pointer 00064 * in the argument list. It will not work correctly with static or 00065 * non-member functions. 00066 *\NOTE This macro assumes that the arguments referenced in the format string 00067 * begin immediately after the format string itself. 00068 */ 00069 #ifdef __GNUC__ 00070 #define MB_PRINTF( START ) __attribute__( ( format( printf, ( START ) + 1, ( START ) + 2 ) ) ) 00071 #else 00072 #define MB_PRINTF( START ) 00073 #endif 00074 00075 /**\def MB_DLL_EXPORT 00076 *\brief Declare a function or class to be visible in shared library. 00077 */ 00078 /**\def MB_DLL_HIDDEN 00079 *\brief Declare a function or class to be internal to a shared library. 00080 */ 00081 #if defined _MSC_VER || defined __CYGWIN__ || defined __MINGW32__ || defined __MINGW64__ || defined _WIN32 00082 #if !defined IS_BUILDING_MB || !defined MB_EXPORTS 00083 #define MB_DLL_EXPORT __dllspec( dllexport ) 00084 #elif !defined MB_WIN_DLL 00085 #define MB_DLL_EXPORT __dllspec( dllimport ) 00086 #else 00087 #define MB_DLL_EXPORT 00088 #endif 00089 #define MB_DLL_HIDDEN 00090 #elif defined __GNUC__ && __GNUC__ > 3 00091 #define MB_DLL_EXPORT __attribute__( ( visibility( "default" ) ) ) 00092 #define MB_DLL_HIDDEN __attribute__( ( visibility( "hidden" ) ) ) 00093 #else 00094 #define MB_DLL_EXPORT 00095 #define MB_DLL_HIDDEN 00096 #endif 00097 00098 /**\def MB_DEPRECATED 00099 *\brief Mark function or API as deprecated 00100 */ 00101 #if defined( __GNUC__ ) && ( 1000 * __GNUC__ + __GNUC_MINOR__ ) > 3000 00102 #define MB_DEPRECATED __attribute__( ( __deprecated__ ) ) 00103 #else 00104 #define MB_DEPRECATED 00105 #endif 00106 00107 /*@}*/ 00108 00109 #endif // moab_COMPILER_HPP
