MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef DGMSOLVER_HPP 00002 #define DGMSOLVER_HPP 00003 #include <vector> 00004 00005 namespace moab 00006 { 00007 00008 class DGMSolver 00009 { 00010 DGMSolver(){}; 00011 ~DGMSolver(){}; 00012 00013 public: 00014 //! \brief compute combinational number, n choose k, maximum output is 00015 //! std::numeric_limits<unsigned int>::max(); 00016 // If overflows, return 0 00017 static unsigned int nchoosek( unsigned int n, unsigned int k ); 00018 00019 //! \brief compute the number of columns for a multivariate vandermonde matrix, given certen 00020 //! degree 00021 /** If degree = 0, out put is 1; 00022 *If kvars = 1, degree = k, output is k+1; 00023 *If kvars = 2, degree = k, output is (k+2)*(k+1)/2; 00024 */ 00025 static unsigned int compute_numcols_vander_multivar( unsigned int kvars, unsigned int degree ); 00026 00027 //! \brief compute the monomial basis of mutiple variables, up to input degree, 00028 //! lexicographically ordered 00029 /** if degree = 0, output basis = {1} 00030 *If kvars = 1, vars = {u}, degree = k, basis = {1,u,...,u^k} 00031 *If kvars = 2, vars = {u,v}, degree = k, basis = 00032 *{1,u,v,u^2,uv,v^2,u^3,u^2*v,uv^2,v^3,...,u^k,u^k-1*v,...,uv^k-1,v^k} If kvars = 3, vars = 00033 *{u,v,w}, degree = k, basis = 00034 *{1,u,v,w,u^2,uv,uw,v^2,v*w,w^2,...,u^k,u^k-1v,u^k-1w,...,v^k,v^k-1w,...,vw^k-1,w^k} \param 00035 *kvars Integer, number of variables \param vars Pointer to array of doubles, size = kvars, 00036 *variable values \param degree Integer, maximum degree \param basis Reference to vector, user 00037 *input container to hold output which is appended to existing data; users don't have to 00038 *preallocate for basis, this function will allocate interally 00039 */ 00040 static void gen_multivar_monomial_basis( const int kvars, 00041 const double* vars, 00042 const int degree, 00043 std::vector< double >& basis ); 00044 00045 //! \brief compute multivariate vandermonde matrix, monomial basis ordered in the same way as 00046 //! gen_multivar_monomial_basis 00047 /** if degree = 0, V = {1,...,1}'; 00048 *If kvars = 1, us = {u1;u2;..,;um}, degree = k, V = {1 u1 u1^2 ... u1^k;1 u2 u2^2 ... 00049 u2^k;...;1 um um^2 ... um^k}; *If kvars = 2, us = {u1 v1;u2 v2;...;um vm}, degree = k, V = {1 00050 u1 v1 u1^2 u1v1 v1^2;...;1 um vm um^2 umvm vm^2}; 00051 * \param mrows Integer, number of points to evaluate Vandermonde matrix 00052 * \param kvars Integer, number of variables 00053 * \param us Pointer to array of doubles, size = mrow*kvars, variable values for all points. 00054 Stored in row-wise, like {u1 v1 u2 v2 ...} 00055 * \param degree Integer, maximum degree 00056 * \param basis Reference to vector, user input container to hold Vandermonde matrix which is 00057 appended to existing data; users don't have to preallocate for basis, this function will 00058 allocate interally; the Vandermonde matrix is stored in an array, columnwise, like {1 ... 1 00059 u1 ...um u1^2 ... um^2 ...} 00060 */ 00061 static void gen_vander_multivar( const int mrows, 00062 const int kvars, 00063 const double* us, 00064 const int degree, 00065 std::vector< double >& V ); 00066 00067 static void rescale_matrix( int mrows, int ncols, double* V, double* ts ); 00068 00069 static void compute_qtransposeB( int mrows, int ncols, const double* Q, int bncols, double* bs ); 00070 00071 static void qr_polyfit_safeguarded( const int mrows, const int ncols, double* V, double* D, int* rank ); 00072 00073 static void backsolve( int mrows, int ncols, double* R, int bncols, double* bs, double* ws ); 00074 00075 static void backsolve_polyfit_safeguarded( int dim, 00076 int degree, 00077 const bool interp, 00078 int mrows, 00079 int ncols, 00080 double* R, 00081 int bncols, 00082 double* bs, 00083 const double* ws, 00084 int* degree_out ); 00085 00086 static void vec_dotprod( const int len, const double* a, const double* b, double* c ); 00087 00088 static void vec_scalarprod( const int len, const double* a, const double c, double* b ); 00089 00090 static void vec_crossprod( const double a[3], const double b[3], double ( &c )[3] ); 00091 00092 static double vec_innerprod( const int len, const double* a, const double* b ); 00093 00094 static double vec_2norm( const int len, const double* a ); 00095 00096 static double vec_normalize( const int len, const double* a, double* b ); 00097 00098 static double vec_distance( const int len, const double* a, const double* b ); 00099 00100 static void vec_projoff( const int len, const double* a, const double* b, double* c ); 00101 00102 static void vec_linear_operation( const int len, 00103 const double mu, 00104 const double* a, 00105 const double psi, 00106 const double* b, 00107 double* c ); 00108 00109 static void get_tri_natural_coords( const int dim, 00110 const double* cornercoords, 00111 const int npts, 00112 const double* currcoords, 00113 double* naturalcoords ); 00114 }; 00115 00116 } // namespace moab 00117 #endif
