MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /**\file FileOptions.hpp 00017 *\author Jason Kraftcheck ([email protected]) 00018 *\date 2007-08-21 00019 */ 00020 00021 #ifndef FILE_OPTIONS_HPP 00022 #define FILE_OPTIONS_HPP 00023 00024 #include <string> 00025 #include <vector> 00026 #include "moab/Types.hpp" 00027 00028 namespace moab 00029 { 00030 00031 /**\brief Parse options string passed to file IO routines 00032 * 00033 * This is a utility class used by file-IO-related code to 00034 * parse the options string passed to Core::load_file and 00035 * Core::write_file 00036 */ 00037 class MOAB_EXPORT FileOptions 00038 { 00039 public: 00040 /*\param options_string The concatenation of a list of 00041 * options, separated either by the default separator 00042 * (semicolon) with a custom separator specified at 00043 * the beginning of the string (semicolon followed by 00044 * destired separator character.) 00045 */ 00046 FileOptions( const char* option_string ); 00047 00048 FileOptions( const FileOptions& copy ); 00049 FileOptions& operator=( const FileOptions& copy ); 00050 00051 ~FileOptions(); 00052 00053 /**\brief Check for option with no value 00054 * 00055 * Check for an option w/out a value. 00056 *\param name The option name 00057 *\return - MB_SUCCESS if option is found 00058 * - MB_TYPE_OUT_OF_RANGE if options is found, but has value 00059 * - MB_ENTITY_NOT_FOUND if option is not found. 00060 */ 00061 ErrorCode get_null_option( const char* name ) const; 00062 00063 /**\brief Check for option with boolean (true/false, yes/no) value. 00064 * 00065 * Check for an option with a true/false value. Allowable values 00066 * are "true", "false", "yes", "no", "1", "0", "on", "off". 00067 *\param name The option name 00068 *\param default_value The value to return if the option is not specified. 00069 *\param value The resulting value. This argument is set to the passed 00070 * default value if the option is not found. 00071 *\return - MB_TYPE_OUT_OF_RANGE if options is found, but has an invalid value 00072 * - MB_SUCCESS otherwise 00073 */ 00074 ErrorCode get_toggle_option( const char* name, bool default_value, bool& value ) const; 00075 00076 /**\brief Check for option with an integer value. 00077 * 00078 * Check for an option with an integer value 00079 *\param name The option name 00080 *\param value Output. The value. 00081 *\return - MB_SUCCESS if option is found 00082 * - MB_TYPE_OUT_OF_RANGE if options is found, but does not have an integer value 00083 * - MB_ENTITY_NOT_FOUND if option is not found. 00084 */ 00085 ErrorCode get_int_option( const char* name, int& value ) const; 00086 00087 /**\brief Check for option with an integer value. Accept option with no value. 00088 * 00089 * Check for an option with an integer value. 00090 * If the option is found but has no value specified, then 00091 * pass back the user-specified default value. 00092 * 00093 *\NOTE: This function will not pass back the default_val, but will instead 00094 * return MB_ENTITY_NOT_FOUND if the option is not specified at all. 00095 * The default value is returned only when the option is specified, 00096 * but is specified w/out a value. 00097 * 00098 *\param name The option name 00099 *\param default_val The default value for the option. 00100 *\param value Output. The value. 00101 *\return - MB_SUCCESS if option is found 00102 * - MB_TYPE_OUT_OF_RANGE if options is found but has a value that cannot be parsed as an 00103 *int 00104 * - MB_ENTITY_NOT_FOUND if option is not found. 00105 */ 00106 ErrorCode get_int_option( const char* name, int default_val, int& value ) const; 00107 00108 /**\brief Check for option with a double value. 00109 * 00110 * Check for an option with a double value 00111 *\param name The option name 00112 *\param value Output. The value. 00113 *\return - MB_SUCCESS if option is found 00114 * - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a double value 00115 * - MB_ENTITY_NOT_FOUND if option is not found. 00116 */ 00117 ErrorCode get_real_option( const char* name, double& value ) const; 00118 00119 /**\brief Check for option with any value. 00120 * 00121 * Check for an option with any value. 00122 *\param name The option name 00123 *\param value Output. The value. 00124 *\return - MB_SUCCESS if option is found 00125 * - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a value 00126 * - MB_ENTITY_NOT_FOUND if option is not found. 00127 */ 00128 ErrorCode get_str_option( const char* name, std::string& value ) const; 00129 00130 /**\brief Check for option 00131 * 00132 * Check for an option 00133 *\param name The option name 00134 *\param value The option value, or an empty string if no value. 00135 *\return MB_SUCCESS or MB_ENTITY_NOT_FOUND 00136 */ 00137 ErrorCode get_option( const char* name, std::string& value ) const; 00138 00139 /**\brief Check the string value of an option 00140 * 00141 * Check which of a list of possible values a string option contains. 00142 *\param name The option name 00143 *\param values A NULL-terminated array of C-style strings enumerating 00144 * the possible option values. 00145 *\param index Output: The index into <code>values</code> for the 00146 * option value. 00147 *\return MB_SUCCESS if matched name and value. 00148 * MB_ENTITY_NOT_FOUND if the option was not specified 00149 * MB_FAILURE if the option value is not in the input <code>values</code> array. 00150 */ 00151 ErrorCode match_option( const char* name, const char* const* values, int& index ) const; 00152 00153 /**\brief Check if an option matches a string value 00154 * 00155 * Check if the value for an option is the passed string. 00156 *\param name The option name 00157 *\param value The expected value. 00158 *\return MB_SUCCESS if matched name and value. 00159 * MB_ENTITY_NOT_FOUND if the option was not specified 00160 * MB_FAILURE if the option value doesn't match the passed string/ 00161 */ 00162 ErrorCode match_option( const char* name, const char* value ) const; 00163 00164 /**\brief Check for option for which the value is a list of ints 00165 * 00166 * Check for an option which is an int list. The value is expected to 00167 * be a comma-separated list of int ranges, where an int range can be 00168 * either a single integer value or a range of integer values separated 00169 * by a dash ('-'). 00170 * 00171 *\param name The option name 00172 *\param values Output. The list of integer values. 00173 *\return - MB_SUCCESS if option is found 00174 * - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list 00175 * - MB_ENTITY_NOT_FOUND if option is not found. 00176 */ 00177 ErrorCode get_ints_option( const char* name, std::vector< int >& values ) const; 00178 00179 /**\brief Check for option for which the value is a list of doubles 00180 * 00181 * Check for an option which is a double list. The value is expected to 00182 * be a comma-separated list of double values 00183 * 00184 *\param name The option name 00185 *\param values Output. The list of double values. 00186 *\return - MB_SUCCESS if option is found 00187 * - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list 00188 * - MB_ENTITY_NOT_FOUND if option is not found. 00189 */ 00190 ErrorCode get_reals_option( const char* name, std::vector< double >& values ) const; 00191 00192 /**\brief Check for option for which the value is a list of strings 00193 * 00194 * Check for an option which is a string list. The value is expected to 00195 * be a comma-separated list of string values, with no embedded spaces or commas. 00196 * 00197 *\param name The option name 00198 *\param values Output. The list of string values. 00199 *\return - MB_SUCCESS if option is found 00200 * - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain a string list 00201 * - MB_ENTITY_NOT_FOUND if option is not found. 00202 */ 00203 ErrorCode get_strs_option( const char* name, std::vector< std::string >& values ) const; 00204 00205 /** number of options */ 00206 inline unsigned size() const 00207 { 00208 return mOptions.size(); 00209 } 00210 00211 /** true if no options */ 00212 inline bool empty() const 00213 { 00214 return mOptions.empty(); 00215 } 00216 00217 /** Get list of options */ 00218 void get_options( std::vector< std::string >& list ) const; 00219 00220 /** Check if all options have been looked at */ 00221 bool all_seen() const; 00222 00223 /** Mark all options as seen. USed for non-root procs during bcast-delete read */ 00224 void mark_all_seen() const; 00225 00226 /** Get first unseen option */ 00227 ErrorCode get_unseen_option( std::string& value ) const; 00228 00229 private: 00230 /**\brief Check for option 00231 * 00232 * Check for an option 00233 *\param name The option name 00234 *\param value The option value, or an empty string if no value. 00235 *\return MB_SUCCESS or MB_ENTITY_NOT_FOUND 00236 */ 00237 ErrorCode get_option( const char* name, const char*& value ) const; 00238 00239 char* mData; 00240 std::vector< const char* > mOptions; 00241 mutable std::vector< bool > mSeen; 00242 00243 /** Case-insensitive compare of name with option value. */ 00244 static bool compare( const char* name, const char* option ); 00245 }; 00246 00247 } // namespace moab 00248 00249 #endif
