MOAB
4.9.3pre
00001 /* 00002 Copyright (c) 2011, Intel Corporation. All rights reserved. 00003 00004 Redistribution and use in source and binary forms, with or without modification, 00005 are permitted provided that the following conditions are met: 00006 00007 * Redistributions of source code must retain the above copyright notice, this 00008 list of conditions and the following disclaimer. 00009 * Redistributions in binary form must reproduce the above copyright notice, 00010 this list of conditions and the following disclaimer in the documentation 00011 and/or other materials provided with the distribution. 00012 * Neither the name of Intel Corporation nor the names of its contributors may 00013 be used to endorse or promote products derived from this software without 00014 specific prior written permission. 00015 00016 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND 00017 ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED 00018 WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE 00019 DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR 00020 ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES 00021 (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; 00022 LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON 00023 ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT 00024 (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS 00025 SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. 00026 00027 ******************************************************************************** 00028 * Content : Eigen bindings to Intel(R) MKL 00029 * Level 3 BLAS SYRK/HERK implementation. 00030 ******************************************************************************** 00031 */ 00032 00033 #ifndef EIGEN_GENERAL_MATRIX_MATRIX_TRIANGULAR_MKL_H 00034 #define EIGEN_GENERAL_MATRIX_MATRIX_TRIANGULAR_MKL_H 00035 00036 namespace Eigen { 00037 00038 namespace internal { 00039 00040 template <typename Index, typename Scalar, int AStorageOrder, bool ConjugateA, int ResStorageOrder, int UpLo> 00041 struct general_matrix_matrix_rankupdate : 00042 general_matrix_matrix_triangular_product< 00043 Index,Scalar,AStorageOrder,ConjugateA,Scalar,AStorageOrder,ConjugateA,ResStorageOrder,UpLo,BuiltIn> {}; 00044 00045 00046 // try to go to BLAS specialization 00047 #define EIGEN_MKL_RANKUPDATE_SPECIALIZE(Scalar) \ 00048 template <typename Index, int LhsStorageOrder, bool ConjugateLhs, \ 00049 int RhsStorageOrder, bool ConjugateRhs, int UpLo> \ 00050 struct general_matrix_matrix_triangular_product<Index,Scalar,LhsStorageOrder,ConjugateLhs, \ 00051 Scalar,RhsStorageOrder,ConjugateRhs,ColMajor,UpLo,Specialized> { \ 00052 static EIGEN_STRONG_INLINE void run(Index size, Index depth,const Scalar* lhs, Index lhsStride, \ 00053 const Scalar* rhs, Index rhsStride, Scalar* res, Index resStride, Scalar alpha) \ 00054 { \ 00055 if (lhs==rhs) { \ 00056 general_matrix_matrix_rankupdate<Index,Scalar,LhsStorageOrder,ConjugateLhs,ColMajor,UpLo> \ 00057 ::run(size,depth,lhs,lhsStride,rhs,rhsStride,res,resStride,alpha); \ 00058 } else { \ 00059 general_matrix_matrix_triangular_product<Index, \ 00060 Scalar, LhsStorageOrder, ConjugateLhs, \ 00061 Scalar, RhsStorageOrder, ConjugateRhs, \ 00062 ColMajor, UpLo, BuiltIn> \ 00063 ::run(size,depth,lhs,lhsStride,rhs,rhsStride,res,resStride,alpha); \ 00064 } \ 00065 } \ 00066 }; 00067 00068 EIGEN_MKL_RANKUPDATE_SPECIALIZE(double) 00069 //EIGEN_MKL_RANKUPDATE_SPECIALIZE(dcomplex) 00070 EIGEN_MKL_RANKUPDATE_SPECIALIZE(float) 00071 //EIGEN_MKL_RANKUPDATE_SPECIALIZE(scomplex) 00072 00073 // SYRK for float/double 00074 #define EIGEN_MKL_RANKUPDATE_R(EIGTYPE, MKLTYPE, MKLFUNC) \ 00075 template <typename Index, int AStorageOrder, bool ConjugateA, int UpLo> \ 00076 struct general_matrix_matrix_rankupdate<Index,EIGTYPE,AStorageOrder,ConjugateA,ColMajor,UpLo> { \ 00077 enum { \ 00078 IsLower = (UpLo&Lower) == Lower, \ 00079 LowUp = IsLower ? Lower : Upper, \ 00080 conjA = ((AStorageOrder==ColMajor) && ConjugateA) ? 1 : 0 \ 00081 }; \ 00082 static EIGEN_STRONG_INLINE void run(Index size, Index depth,const EIGTYPE* lhs, Index lhsStride, \ 00083 const EIGTYPE* rhs, Index rhsStride, EIGTYPE* res, Index resStride, EIGTYPE alpha) \ 00084 { \ 00085 /* typedef Matrix<EIGTYPE, Dynamic, Dynamic, RhsStorageOrder> MatrixRhs;*/ \ 00086 \ 00087 MKL_INT lda=lhsStride, ldc=resStride, n=size, k=depth; \ 00088 char uplo=(IsLower) ? 'L' : 'U', trans=(AStorageOrder==RowMajor) ? 'T':'N'; \ 00089 MKLTYPE alpha_, beta_; \ 00090 \ 00091 /* Set alpha_ & beta_ */ \ 00092 assign_scalar_eig2mkl<MKLTYPE, EIGTYPE>(alpha_, alpha); \ 00093 assign_scalar_eig2mkl<MKLTYPE, EIGTYPE>(beta_, EIGTYPE(1)); \ 00094 MKLFUNC(&uplo, &trans, &n, &k, &alpha_, lhs, &lda, &beta_, res, &ldc); \ 00095 } \ 00096 }; 00097 00098 // HERK for complex data 00099 #define EIGEN_MKL_RANKUPDATE_C(EIGTYPE, MKLTYPE, RTYPE, MKLFUNC) \ 00100 template <typename Index, int AStorageOrder, bool ConjugateA, int UpLo> \ 00101 struct general_matrix_matrix_rankupdate<Index,EIGTYPE,AStorageOrder,ConjugateA,ColMajor,UpLo> { \ 00102 enum { \ 00103 IsLower = (UpLo&Lower) == Lower, \ 00104 LowUp = IsLower ? Lower : Upper, \ 00105 conjA = (((AStorageOrder==ColMajor) && ConjugateA) || ((AStorageOrder==RowMajor) && !ConjugateA)) ? 1 : 0 \ 00106 }; \ 00107 static EIGEN_STRONG_INLINE void run(Index size, Index depth,const EIGTYPE* lhs, Index lhsStride, \ 00108 const EIGTYPE* rhs, Index rhsStride, EIGTYPE* res, Index resStride, EIGTYPE alpha) \ 00109 { \ 00110 typedef Matrix<EIGTYPE, Dynamic, Dynamic, AStorageOrder> MatrixType; \ 00111 \ 00112 MKL_INT lda=lhsStride, ldc=resStride, n=size, k=depth; \ 00113 char uplo=(IsLower) ? 'L' : 'U', trans=(AStorageOrder==RowMajor) ? 'C':'N'; \ 00114 RTYPE alpha_, beta_; \ 00115 const EIGTYPE* a_ptr; \ 00116 \ 00117 /* Set alpha_ & beta_ */ \ 00118 /* assign_scalar_eig2mkl<MKLTYPE, EIGTYPE>(alpha_, alpha); */\ 00119 /* assign_scalar_eig2mkl<MKLTYPE, EIGTYPE>(beta_, EIGTYPE(1));*/ \ 00120 alpha_ = alpha.real(); \ 00121 beta_ = 1.0; \ 00122 /* Copy with conjugation in some cases*/ \ 00123 MatrixType a; \ 00124 if (conjA) { \ 00125 Map<const MatrixType, 0, OuterStride<> > mapA(lhs,n,k,OuterStride<>(lhsStride)); \ 00126 a = mapA.conjugate(); \ 00127 lda = a.outerStride(); \ 00128 a_ptr = a.data(); \ 00129 } else a_ptr=lhs; \ 00130 MKLFUNC(&uplo, &trans, &n, &k, &alpha_, (MKLTYPE*)a_ptr, &lda, &beta_, (MKLTYPE*)res, &ldc); \ 00131 } \ 00132 }; 00133 00134 00135 EIGEN_MKL_RANKUPDATE_R(double, double, dsyrk) 00136 EIGEN_MKL_RANKUPDATE_R(float, float, ssyrk) 00137 00138 //EIGEN_MKL_RANKUPDATE_C(dcomplex, MKL_Complex16, double, zherk) 00139 //EIGEN_MKL_RANKUPDATE_C(scomplex, MKL_Complex8, double, cherk) 00140 00141 00142 } // end namespace internal 00143 00144 } // end namespace Eigen 00145 00146 #endif // EIGEN_GENERAL_MATRIX_MATRIX_TRIANGULAR_MKL_H
