MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef MB_INTERNALS_HPP 00017 #define MB_INTERNALS_HPP 00018 00019 #ifdef WIN32 00020 #pragma warning( disable : 4786 ) 00021 #endif 00022 00023 #ifndef IS_BUILDING_MB 00024 #error "Internals.hpp isn't supposed to be included into an application" 00025 #endif 00026 00027 #include "moab/Types.hpp" 00028 #include <cassert> 00029 00030 namespace moab 00031 { 00032 00033 /*! Define EntityHandle for both 32 bit and 64 bit systems. 00034 * The decision to use 64 bit handles must be made at compile time. 00035 * \bug we should probably have an Int64 typedef 00036 * 00037 * EntityHandle format: 00038 * 0xXYYYYYYY (assuming a 32-bit handle. Top 4 bits reserved on a 64 bit system) 00039 * X - reserved for entity type. This system can only handle 15 different types 00040 * Y - Entity id space. Max id is over 200M 00041 * 00042 * Note that for specialized databases (such as all hex) 16 bits are not 00043 * required for the entity type and the id space can be increased to over 2B. 00044 */ 00045 #define MB_TYPE_WIDTH 4 00046 #define MB_ID_WIDTH ( 8 * sizeof( EntityHandle ) - MB_TYPE_WIDTH ) 00047 #define MB_TYPE_MASK ( (EntityHandle)0xF << MB_ID_WIDTH ) 00048 // 2^MB_TYPE_WIDTH-1 ------^ 00049 00050 #define MB_START_ID ( (EntityID)1 ) //!< All entity id's currently start at 1 00051 #define MB_END_ID ( (EntityID)MB_ID_MASK ) //!< Last id is the complement of the MASK 00052 #define MB_ID_MASK ( ~MB_TYPE_MASK ) 00053 00054 //! Given a type and an id create a handle. 00055 inline EntityHandle CREATE_HANDLE( const unsigned type, const EntityID id, int& err ) 00056 { 00057 err = 0; //< Assume that there is a real error value defined somewhere 00058 00059 if( id > MB_END_ID || type > MBMAXTYPE ) 00060 { 00061 err = 1; //< Assume that there is a real error value defined somewhere 00062 return 1; //<You've got to return something. What do you return? 00063 } 00064 00065 return ( ( (EntityHandle)type ) << MB_ID_WIDTH ) | id; 00066 } 00067 00068 inline EntityHandle CREATE_HANDLE( const unsigned type, const EntityID id ) 00069 { 00070 assert( id <= MB_END_ID && type <= MBMAXTYPE ); 00071 return ( ( (EntityHandle)type ) << MB_ID_WIDTH ) | id; 00072 } 00073 00074 inline EntityHandle FIRST_HANDLE( unsigned type ) 00075 { 00076 return ( ( (EntityHandle)type ) << MB_ID_WIDTH ) | MB_START_ID; 00077 } 00078 00079 inline EntityHandle LAST_HANDLE( unsigned type ) 00080 { 00081 return ( (EntityHandle)( type + 1 ) << MB_ID_WIDTH ) - 1; 00082 } 00083 00084 //! Get the entity id out of the handle. 00085 inline EntityID ID_FROM_HANDLE( EntityHandle handle ) 00086 { 00087 return ( handle & MB_ID_MASK ); 00088 } 00089 00090 //! Get the type out of the handle. Can do a simple shift because 00091 //! handles are unsigned (therefore shifting fills with zero's) 00092 inline EntityType TYPE_FROM_HANDLE( EntityHandle handle ) 00093 { 00094 return static_cast< EntityType >( handle >> MB_ID_WIDTH ); 00095 } 00096 00097 } // namespace moab 00098 00099 #endif
