MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "Lasso.hpp" 00002 #include "AssocPair.hpp" 00003 00004 Lasso::~Lasso() 00005 { 00006 for( std::set< AssocPair* >::iterator i = assocPairs.begin(); i != assocPairs.end(); ++i ) 00007 delete *i; 00008 } 00009 00010 //! find a pair equivalent to these ifaces, passed as pointer to 00011 //! SIDL interface or interface instance 00012 AssocPair* Lasso::find_pair( void* iface0, void* iface1, bool* switched ) 00013 { 00014 for( std::set< AssocPair* >::iterator i = assocPairs.begin(); i != assocPairs.end(); ++i ) 00015 { 00016 if( ( *i )->equivalent( iface0, iface1, switched ) ) return *i; 00017 } 00018 00019 return NULL; 00020 } 00021 00022 //! find a pair with the right types 00023 AssocPair* Lasso::find_pair( iRel_IfaceType type1, iRel_IfaceType type2, bool* switched ) 00024 { 00025 for( std::set< AssocPair* >::iterator i = assocPairs.begin(); i != assocPairs.end(); ++i ) 00026 { 00027 if( ( *i )->equivalent( type1, type2, switched ) ) return *i; 00028 } 00029 00030 return NULL; 00031 } 00032 00033 void Lasso::find_pairs( void* iface, std::vector< AssocPair* >& iface_pairs ) 00034 { 00035 for( std::set< AssocPair* >::iterator i = assocPairs.begin(); i != assocPairs.end(); ++i ) 00036 { 00037 if( ( *i )->contains( iface ) ) iface_pairs.push_back( *i ); 00038 } 00039 } 00040 00041 int Lasso::insert_pair( AssocPair* this_pair ) 00042 { 00043 assocPairs.insert( this_pair ); 00044 return iBase_SUCCESS; 00045 } 00046 00047 int Lasso::erase_pair( AssocPair* this_pair ) 00048 { 00049 if( assocPairs.erase( this_pair ) == 0 ) return iBase_FAILURE; 00050 00051 // If the pair was removed, then delete it too 00052 delete this_pair; 00053 return iBase_SUCCESS; 00054 }
