MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "MeshAssocPairSide.hpp" 00002 00003 #include <cstring> 00004 #include <sstream> 00005 #include <string> 00006 00007 #include <iMesh_extensions.h> 00008 00009 #include "Lasso.hpp" 00010 #include "iRel_Lasso.hpp" 00011 00012 #define PROCESS_ERROR \ 00013 do \ 00014 { \ 00015 if( iBase_SUCCESS != result ) \ 00016 { \ 00017 char this_descr[120]; \ 00018 iMesh_getDescription( instance_, this_descr, 120 ); \ 00019 ERRORR( result, this_descr ); \ 00020 } \ 00021 } while( false ) 00022 00023 // Redefine LASSOI 00024 #undef LASSOI 00025 #define LASSOI lasso_instance( relation ) 00026 00027 static const char* GLOBAL_ID_TAG_NAME = "GLOBAL_ID"; 00028 static const char* MESH_DIMENSION_TAG_NAME = "GEOM_DIMENSION"; 00029 static const char* RELATION_TAG_NAME = "__MESH_ASSOCIATION"; 00030 00031 MeshAssocPairSide::MeshAssocPairSide( iRel_Instance p_relation, iBase_Instance p_instance, int p_id ) 00032 : relation( p_relation ), instance_( reinterpret_cast< iMesh_Instance >( p_instance ) ), id( p_id ) 00033 { 00034 int result; 00035 00036 create_relation_side(); 00037 00038 iMesh_getTagHandle( instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result, strlen( GLOBAL_ID_TAG_NAME ) ); 00039 if( result == iBase_TAG_NOT_FOUND ) 00040 { 00041 iMesh_createTag( instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER, &gid_tag, &result, 00042 strlen( GLOBAL_ID_TAG_NAME ) ); 00043 } 00044 00045 iMesh_getTagHandle( instance_, MESH_DIMENSION_TAG_NAME, &dim_tag, &result, strlen( MESH_DIMENSION_TAG_NAME ) ); 00046 if( result == iBase_TAG_NOT_FOUND ) dim_tag = NULL; 00047 } 00048 00049 MeshAssocPairSide::~MeshAssocPairSide() 00050 { 00051 destroy_relation_side(); 00052 } 00053 00054 iBase_Instance MeshAssocPairSide::instance() const 00055 { 00056 return instance_; 00057 } 00058 00059 iRel_IfaceType MeshAssocPairSide::type() const 00060 { 00061 return iRel_IMESH_IFACE; 00062 } 00063 00064 int MeshAssocPairSide::create_relation_side() 00065 { 00066 int result; 00067 std::stringstream ss; 00068 ss << RELATION_TAG_NAME << id; 00069 std::string rel_tag_name( ss.str() ); 00070 00071 iMesh_getTagHandle( instance_, rel_tag_name.c_str(), &relation_tag, &result, rel_tag_name.size() ); 00072 if( result == iBase_TAG_NOT_FOUND ) 00073 { 00074 iMesh_createTag( instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE, &relation_tag, &result, 00075 rel_tag_name.size() ); 00076 } 00077 00078 PROCESS_ERROR; 00079 RETURNR( iBase_SUCCESS ); 00080 } 00081 00082 int MeshAssocPairSide::destroy_relation_side() 00083 { 00084 if( relation_tag ) 00085 { 00086 int result; 00087 00088 iMesh_destroyTag( instance_, relation_tag, true, &result ); 00089 relation_tag = NULL; 00090 00091 PROCESS_ERROR; 00092 } 00093 RETURNR( iBase_SUCCESS ); 00094 } 00095 00096 int MeshAssocPairSide::get_all_entities( int dimension, 00097 iBase_EntityHandle** entities, 00098 int* entities_alloc, 00099 int* entities_size ) 00100 { 00101 int this_type = ( dimension == -1 ? iBase_ALL_TYPES : dimension ); 00102 int result; 00103 00104 iMesh_getEntities( instance_, 0, this_type, iMesh_ALL_TOPOLOGIES, entities, entities_alloc, entities_size, 00105 &result ); 00106 PROCESS_ERROR; 00107 RETURNR( iBase_SUCCESS ); 00108 } 00109 00110 int MeshAssocPairSide::get_all_sets( iBase_EntitySetHandle** sets, int* sets_alloc, int* sets_size ) 00111 { 00112 int result; 00113 00114 iMesh_getEntSets( instance_, 0, 0, sets, sets_alloc, sets_size, &result ); 00115 PROCESS_ERROR; 00116 RETURNR( iBase_SUCCESS ); 00117 } 00118 00119 int MeshAssocPairSide::get_entities( int dimension, 00120 iBase_EntitySetHandle set_handle, 00121 iBase_EntityHandle** entities, 00122 int* entities_alloc, 00123 int* entities_size ) 00124 { 00125 int this_type = ( dimension == -1 ? iBase_ALL_TYPES : dimension ); 00126 int result; 00127 00128 iMesh_getEntities( instance_, set_handle, this_type, iMesh_ALL_TOPOLOGIES, entities, entities_alloc, entities_size, 00129 &result ); 00130 PROCESS_ERROR; 00131 RETURNR( iBase_SUCCESS ); 00132 } 00133 00134 int MeshAssocPairSide::get_ents_dims( iBase_EntityHandle* entities, 00135 int entities_size, 00136 int** ent_types, 00137 int* ent_types_alloc, 00138 int* ent_types_size ) 00139 { 00140 int result; 00141 00142 iMesh_getEntArrType( instance_, entities, entities_size, ent_types, ent_types_alloc, ent_types_size, &result ); 00143 PROCESS_ERROR; 00144 RETURNR( iBase_SUCCESS ); 00145 } 00146 00147 int MeshAssocPairSide::get_related_ents( iBase_EntityHandle** entities, int* entities_alloc, int* entities_size ) 00148 { 00149 int result; 00150 iMesh_getEntsByTagsRec( instance_, 0, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &relation_tag, NULL, 1, false, 00151 entities, entities_alloc, entities_size, &result ); 00152 PROCESS_ERROR; 00153 RETURNR( iBase_SUCCESS ); 00154 } 00155 00156 int MeshAssocPairSide::get_related_sets( iBase_EntitySetHandle** sets, int* sets_alloc, int* sets_size ) 00157 { 00158 int result; 00159 iMesh_getEntSetsByTagsRec( instance_, 0, &relation_tag, NULL, 1, false, sets, sets_alloc, sets_size, &result ); 00160 PROCESS_ERROR; 00161 RETURNR( iBase_SUCCESS ); 00162 } 00163 00164 int MeshAssocPairSide::get_relation_side( iBase_EntityHandle* entities, int num_entities, void* values ) 00165 { 00166 int values_alloc = num_entities * sizeof( iBase_EntityHandle ); 00167 int values_size; 00168 int result; 00169 00170 iMesh_getArrData( instance_, entities, num_entities, relation_tag, &values, &values_alloc, &values_size, &result ); 00171 PROCESS_ERROR; 00172 RETURNR( iBase_SUCCESS ); 00173 } 00174 00175 int MeshAssocPairSide::get_relation_side( iBase_EntitySetHandle* sets, int num_sets, void* values ) 00176 { 00177 char* data = static_cast< char* >( values ); 00178 int values_alloc = sizeof( iBase_EntityHandle ); 00179 int values_size; 00180 int result; 00181 00182 for( int i = 0; i < num_sets; i++ ) 00183 { 00184 iMesh_getEntSetData( instance_, sets[i], relation_tag, reinterpret_cast< void** >( &data ), &values_alloc, 00185 &values_size, &result ); 00186 data += values_size; 00187 PROCESS_ERROR; 00188 } 00189 RETURNR( iBase_SUCCESS ); 00190 } 00191 00192 int MeshAssocPairSide::set_relation_side( iBase_EntityHandle* entities, int num_entities, const void* values ) 00193 { 00194 int result; 00195 00196 iMesh_setArrData( instance_, entities, num_entities, relation_tag, static_cast< const char* >( values ), 00197 num_entities * sizeof( iBase_EntityHandle ), &result ); 00198 PROCESS_ERROR; 00199 RETURNR( iBase_SUCCESS ); 00200 } 00201 00202 int MeshAssocPairSide::set_relation_side( iBase_EntitySetHandle* sets, int num_sets, const void* values ) 00203 { 00204 const char* data = static_cast< const char* >( values ); 00205 int size = sizeof( iBase_EntityHandle ); 00206 int result; 00207 00208 for( int i = 0; i < num_sets; i++ ) 00209 { 00210 iMesh_setEntSetData( instance_, sets[i], relation_tag, data, size, &result ); 00211 data += size; 00212 PROCESS_ERROR; 00213 } 00214 RETURNR( iBase_SUCCESS ); 00215 } 00216 00217 int MeshAssocPairSide::rmv_relation_side( iBase_EntityHandle* entities, int num_entities ) 00218 { 00219 int result; 00220 00221 iMesh_rmvArrTag( instance_, entities, num_entities, relation_tag, &result ); 00222 PROCESS_ERROR; 00223 RETURNR( iBase_SUCCESS ); 00224 } 00225 00226 int MeshAssocPairSide::rmv_relation_side( iBase_EntitySetHandle* sets, int num_sets ) 00227 { 00228 int result; 00229 00230 for( int i = 0; i < num_sets; i++ ) 00231 { 00232 iMesh_rmvEntSetTag( instance_, sets[i], relation_tag, &result ); 00233 PROCESS_ERROR; 00234 } 00235 00236 RETURNR( iBase_SUCCESS ); 00237 } 00238 00239 int MeshAssocPairSide::get_iterator( iBase_EntitySetHandle set, iBase_EntityIterator* iter ) 00240 { 00241 int result; 00242 int resilient = 0; 00243 iMesh_initEntIter( instance_, set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, resilient, iter, &result ); 00244 RETURNR( iBase_SUCCESS ); 00245 } 00246 00247 int MeshAssocPairSide::get_gids( iBase_EntityHandle* entities, int num_entities, int* values ) 00248 { 00249 int values_alloc = num_entities * sizeof( int ); 00250 int values_size; 00251 int result; 00252 00253 iMesh_getArrData( instance_, entities, num_entities, gid_tag, &values, &values_alloc, &values_size, &result ); 00254 PROCESS_ERROR; 00255 RETURNR( iBase_SUCCESS ); 00256 } 00257 00258 int MeshAssocPairSide::get_gids( iBase_EntitySetHandle* sets, int num_sets, int* values ) 00259 { 00260 char* data = reinterpret_cast< char* >( values ); 00261 int values_alloc = sizeof( int ); 00262 int values_size; 00263 int result; 00264 00265 for( int i = 0; i < num_sets; i++ ) 00266 { 00267 iMesh_getEntSetData( instance_, sets[i], gid_tag, reinterpret_cast< void** >( &data ), &values_alloc, 00268 &values_size, &result ); 00269 data += values_size; 00270 PROCESS_ERROR; 00271 } 00272 RETURNR( iBase_SUCCESS ); 00273 } 00274 00275 int MeshAssocPairSide::get_dims( iBase_EntityHandle* entities, int num_entities, int* values ) 00276 { 00277 int values_alloc = num_entities * sizeof( int ); 00278 int values_size; 00279 int result; 00280 00281 iMesh_getArrData( instance_, entities, num_entities, dim_tag, &values, &values_alloc, &values_size, &result ); 00282 PROCESS_ERROR; 00283 RETURNR( iBase_SUCCESS ); 00284 } 00285 00286 int MeshAssocPairSide::get_dims( iBase_EntitySetHandle* sets, int num_sets, int* values ) 00287 { 00288 char* data = reinterpret_cast< char* >( values ); 00289 int values_alloc = sizeof( int ); 00290 int values_size; 00291 int result; 00292 00293 for( int i = 0; i < num_sets; i++ ) 00294 { 00295 iMesh_getEntSetData( instance_, sets[i], dim_tag, reinterpret_cast< void** >( &data ), &values_alloc, 00296 &values_size, &result ); 00297 data += values_size; 00298 PROCESS_ERROR; 00299 } 00300 RETURNR( iBase_SUCCESS ); 00301 }
