MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 00002 program MigrateMesh 00003 implicit none 00004 00005 #include "moab/MOABConfig.h" 00006 #ifdef MOAB_HAVE_MPI 00007 # include "mpif.h" 00008 #else 00009 # error "enable parallel build" 00010 #endif 00011 00012 !#define NONOVERLAP 00013 00014 ! init the parallel partition 00015 integer ierr, sz, rank, i 00016 integer newComm 00017 integer gcomm, comm1, comm2 00018 integer pid1, pid2 ! this is for physics ids 00019 integer compid1, compid2 ! component ids are unique over all pes, and established in 00020 ! advance; 00021 integer nghlay ! number of ghost layers for loading 00022 integer groupTasks(9) ! run on at most 9 processes 00023 integer startG1, startG2, endG1, endG2 ! start and end for group tasks, for creation 00024 integer sizeG1, sizeG2 ! size of the group that gets created 00025 character*10 appname 00026 character*132 readopts 00027 character*132 filename 00028 character*132 outfile 00029 character*132 wopts 00030 integer allgroup, group1, group2 ! Corresponding to MPI_Group in C 00031 integer tagcomm1, tagcomm2 00032 integer iMOAB_InitializeFortran, iMOAB_RegisterFortranApplication 00033 integer iMOAB_LoadMesh, iMOAB_SendMesh, iMOAB_ReceiveMesh, iMOAB_WriteMesh 00034 integer iMOAB_FreeSenderBuffers 00035 integer iMOAB_DeregisterApplication, iMOAB_Finalize 00036 integer repart_scheme , context_id 00037 00038 call MPI_INIT(ierr) 00039 call MPI_Comm_dup(MPI_COMM_WORLD, gcomm, ierr) 00040 call MPI_COMM_SIZE(gcomm, sz, ierr) 00041 call MPI_COMM_RANK(gcomm, rank, ierr) 00042 if (rank .eq. 0) print *, "size:", sz 00043 call errorout(ierr, 'cannot get rank' ) 00044 if ( (0 .eq. rank) .and. (sz>9) ) then 00045 print *, "size is " , sz, ". run on at most 9 tasks " 00046 call exit(1) 00047 endif 00048 ! create 2 overlapping groups, for generality 00049 ! create communicators for each group; 00050 ! one group will represent the sender, the other group the receiver 00051 ! about one third of tasks will be on group 1 only, and one fourth will be on group 2 only 00052 ! about (1-1./3 -1./4) will be overlapping, these tasks will be common to both groups 00053 ! the mesh will be read on the sender comm, will be sent to receiver comm 00054 00055 ! create new MPI groups for processors 1/3*sz, 1/3*sz+1, ..., sz-1 (group 1) and 0, 1, .., 3/4*sz-1 (group 2) 00056 00057 00058 call MPI_COMM_GROUP (gcomm, allgroup, ierr) 00059 call errorout(ierr, 'cannot get world group' ) 00060 ! first group, sz/3 to sz-1 00061 startG1 = sz/2 00062 endG1 = sz-1 00063 sizeG1 = endG1 - startG1 + 1 00064 ! used for new API in iMOAB, for tag migrate, release buffers 00065 context_id = -1 00066 00067 do i=1, sizeG1 00068 groupTasks (i) = startG1+i-1 00069 end do 00070 00071 call MPI_Group_incl(allgroup, sizeG1, groupTasks, group1, ierr) 00072 call errorout(ierr, 'cannot create group 1' ) 00073 00074 ! second group, 0, 1, 3/4*sz 00075 startG2 = 0 00076 endG2 = 3*sz/4 -1 00077 if (endG2 <0) endG2 = 0 ! so it will work even for 1 task 00078 #ifdef NONOVERLAP 00079 endG2 = startG1-1 00080 #endif 00081 sizeG2 = endG2 - startG2 + 1 00082 do i=1, sizeG2 00083 groupTasks(i) = startG2+i-1 00084 enddo 00085 00086 call MPI_Group_incl(allgroup, sizeG2, groupTasks, group2, ierr) 00087 call errorout(ierr, 'cannot create group 2' ) 00088 00089 if ( (0 .eq. rank) ) then 00090 print *, "group 1 tasks: ", (i, i=startG1, endG1) 00091 print *, "group 2 tasks: ", (i, i=startG2, endG2) 00092 endif 00093 ! now create both communicators 00094 ! when we are not on tasks in the communicator, the MPI_Comm created will be null 00095 tagcomm1 = 1 00096 call MPI_Comm_create_group(gcomm, group1, tagcomm1, comm1, ierr) 00097 call errorout(ierr, 'cannot create communicator 1' ) 00098 00099 tagcomm2 = 2 00100 call MPI_Comm_create_group(gcomm, group2, tagcomm2, comm2, ierr) 00101 call errorout(ierr, 'cannot create communicator 2' ) 00102 00103 00104 ierr = iMOAB_InitializeFortran() 00105 00106 repart_scheme = 0 ! this is for trivial partitioning 00107 #ifdef MOAB_HAVE_ZOLTAN 00108 repart_scheme = 1 ! use the graph partitioner in that case 00109 #endif 00110 ! give some dummy values to component ids, just to differentiate between them 00111 ! the par comm graph is unique between components 00112 compid1 = 4 00113 compid2 = 7 00114 call errorout(ierr, 'did not initialize fortran' ) 00115 if (rank == 0) print *, "initialize iMOAB fortran applications" 00116 00117 if (comm1 /= MPI_COMM_NULL) then 00118 appname='phis1'//CHAR(0) 00119 ierr = iMOAB_RegisterFortranApplication(trim(appname), comm1, compid1, pid1) 00120 print *, ' register ', appname, " on rank ", rank, " pid1 ", pid1 00121 endif 00122 if (comm2 /= MPI_COMM_NULL) then 00123 appname = 'phis2'//CHAR(0) 00124 ierr = iMOAB_RegisterFortranApplication(trim(appname), comm2, compid2, pid2) 00125 print *, ' register ', appname, " on rank ", rank, " pid2 ", pid2 00126 endif 00127 00128 00129 if (comm1 /= MPI_COMM_NULL) then 00130 filename = 'spherecube.h5m'//CHAR(0) 00131 readopts = 'PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS'//CHAR(0) 00132 if (rank .eq. sz-2 ) print *, "loading " , trim(filename) , " with options " , trim(readopts) 00133 nghlay = 0 00134 00135 ierr = iMOAB_LoadMesh(pid1, trim(filename), trim(readopts), nghlay) 00136 if (rank .eq. sz-1 ) print *, "loaded in parallel ", trim(filename), " error: ", ierr 00137 ierr = iMOAB_SendMesh(pid1, gcomm, group2, compid2, repart_scheme); ! send to component 2 00138 call errorout(ierr, 'cannot send elements' ) 00139 endif 00140 00141 if (comm2 /= MPI_COMM_NULL) then 00142 ierr = iMOAB_ReceiveMesh(pid2, gcomm, group1, compid1); ! receive from component 1 00143 call errorout(ierr, 'cannot receive elements' ) 00144 endif 00145 00146 ! we can now free the sender buffers 00147 if (comm1 /= MPI_COMM_NULL) then 00148 00149 ierr = iMOAB_FreeSenderBuffers(pid1, context_id) 00150 endif 00151 call MPI_Barrier(gcomm, ierr) 00152 call errorout(ierr, 'cannot stop at barrier' ) 00153 00154 if (comm2 /= MPI_COMM_NULL) then 00155 outfile = 'receivedMesh.h5m'//CHAR(0) 00156 wopts = 'PARALLEL=WRITE_PART;'//CHAR(0) 00157 ! write out the mesh file to disk 00158 ierr = iMOAB_WriteMesh(pid2, trim(outfile), trim(wopts)) 00159 call errorout(ierr, 'cannot write received mesh' ) 00160 endif 00161 00162 00163 if (comm2 /= MPI_COMM_NULL) then 00164 ierr = iMOAB_DeregisterApplication(pid2) 00165 call errorout(ierr, 'cannot deregister app 2 receiver' ) 00166 endif 00167 if (comm1 /= MPI_COMM_NULL) then 00168 ierr = iMOAB_DeregisterApplication(pid1) 00169 call errorout(ierr, 'cannot deregister app 1 sender' ) 00170 endif 00171 00172 ierr = iMOAB_Finalize() 00173 call errorout(ierr, 'did not finalize iMOAB' ) 00174 00175 if (MPI_COMM_NULL /= comm1) call MPI_Comm_free(comm1, ierr) 00176 call errorout(ierr, 'did not free comm1' ) 00177 00178 if (MPI_COMM_NULL /= comm2) call MPI_Comm_free(comm2, ierr) 00179 call errorout(ierr, 'did not free comm2' ) 00180 00181 call MPI_Group_free(allgroup, ierr) 00182 call MPI_Group_free(group1, ierr) 00183 call MPI_Group_free(group2, ierr) 00184 call MPI_Comm_free(gcomm, ierr) 00185 00186 call MPI_Finalize(ierr) 00187 call errorout(ierr, 'did not finalize MPI' ) 00188 contains 00189 SUBROUTINE errorout(ierr, message) 00190 integer ierr 00191 character*(*) message 00192 if (ierr.ne.0) then 00193 print *, message 00194 call exit (1) 00195 end if 00196 end 00197 00198 end program MigrateMesh
