MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef READIDEAS_HPP 00002 #define READIDEAS_HPP 00003 00004 #ifndef IS_BUILDING_MB 00005 #error "ReadIDEAS.hpp isn't supposed to be included into an application" 00006 #endif 00007 00008 #include <iostream> 00009 #include <fstream> 00010 #include <vector> 00011 00012 #include "moab/ReaderIface.hpp" 00013 #include "moab/Interface.hpp" 00014 #include "moab/RangeMap.hpp" 00015 00016 #define MAT_PROP_TABLE_TAG "mat_prop_table" 00017 #define PHYS_PROP_TABLE_TAG "phys_prop_table" 00018 00019 namespace moab 00020 { 00021 00022 class ReadUtilIface; 00023 00024 class ReadIDEAS : public ReaderIface 00025 { 00026 00027 public: 00028 static ReaderIface* factory( Interface* ); 00029 00030 ErrorCode load_file( const char* file_name, 00031 const EntityHandle* file_set, 00032 const FileOptions& opts, 00033 const SubsetList* subset_list = 0, 00034 const Tag* file_id_tag = 0 ); 00035 00036 ErrorCode read_tag_values( const char* file_name, 00037 const char* tag_name, 00038 const FileOptions& opts, 00039 std::vector< int >& tag_values_out, 00040 const SubsetList* subset_list = 0 ); 00041 00042 //! Constructor 00043 ReadIDEAS( Interface* impl = NULL ); 00044 00045 //! Destructor 00046 virtual ~ReadIDEAS() {} 00047 00048 protected: 00049 ErrorCode skip_header(); 00050 ErrorCode create_vertices( EntityHandle& first_vertex, const Tag* file_id_tag ); 00051 ErrorCode create_elements( EntityHandle first_vertex, const Tag* file_id_tag ); 00052 00053 private: 00054 std::ifstream file; 00055 RangeMap< int, EntityHandle > nodeIdMap; 00056 00057 // Read mesh interface 00058 ReadUtilIface* readMeshIface; 00059 00060 // MOAB Interface 00061 Interface* MBI; 00062 00063 /* Universal dataset numbers 00064 An integer describes a chunk of information. These chunks include headers, 00065 units, nodes, elements, patches, etc... described in the OpenFOAM IDEAS 00066 reader. 00067 00068 1) http://amira.zib.de/usersguide31/hxideas/HxFileFormat_IDEAS.html 00069 55,2414 data at nodes 00070 00071 2) http://www.sdrl.uc.edu/universal-file-formats-for-modal-analysis-testing-1 00072 /file-format-storehouse/unv_0015.htm/ 00073 15 nodes with single precision coordinates 00074 line1 (4I10,1P3E13.5): node_label coord_sys_num displacement_sys_num 00075 color x y z */ 00076 static const unsigned SINGLE_PRECISION_NODES = 15; 00077 00078 /* 3) http://www.sdrl.uc.edu/pdf/test_universal_file_formats.pdf 00079 781,2411 nodes with double precision coordinates 00080 line1 (4I10): node_label coord_sys_num displacement_sys_num color 00081 line2 (1P3D25.16): x y z */ 00082 static const unsigned DOUBLE_PRECISION_NODES0 = 781; 00083 static const unsigned DOUBLE_PRECISION_NODES1 = 2411; 00084 00085 /* 4) http://www.sdrl.uc.edu/universal-file-formats-for-modal-analysis-testing-1 00086 /file-format-storehouse/unv_0780.htm/ 00087 71, 780, 2412 element definitions 00088 line1 (8I10): element_label fe_id phys_prop_bin_num phys_prop_num 00089 mat_prop_bin_num mat_prop_num color num_of_nodes 00090 line2 (8I10): connectivity_node_labels */ 00091 static const unsigned ELEMENTS0 = 71; 00092 static const unsigned ELEMENTS1 = 780; 00093 static const unsigned ELEMENTS2 = 2412; 00094 00095 /* Mesh elements exist inside chunks 71, 780, and 2412. Each element definition 00096 includes the finite element id that describes the element type. These are 00097 used in the OpenFOAM IDEAS reader. The canonical node ordering matches that 00098 of MBCN, as suggested by the Gmsh 2.2.3 source code.*/ 00099 static const int ROD0 = 11; 00100 static const int ROD1 = 171; 00101 static const int TRI0 = 41; 00102 static const int TRI1 = 91; 00103 static const int QUAD0 = 44; 00104 static const int QUAD1 = 94; 00105 static const int TET = 111; 00106 static const int WEDGE = 112; 00107 static const int HEX = 115; 00108 }; 00109 00110 } // namespace moab 00111 #endif
