MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef READ_STL_HPP 00017 #define READ_STL_HPP 00018 00019 #include <cstdio> 00020 #include "moab/Forward.hpp" 00021 #include "moab/ReaderIface.hpp" 00022 00023 namespace moab 00024 { 00025 00026 class ReadUtilIface; 00027 00028 /** 00029 * \brief ASCII and Binary Stereo Lithography File readers. 00030 * \author Jason Kraftcheck 00031 * 00032 * STL files contain no connectivity infomration. Each triangle 00033 * is specified as by three sets of single-precision coordinate 00034 * triples. This reader does not use ANY tolerance when comparing 00035 * vertex locations to recover connectivity. The points must be 00036 * EXACTLY equal (including the sign on zero values.) If the file 00037 * was written by an application which represented connectivity 00038 * explicitly, there is no reason for the vertex coordinates to 00039 * be anything other than exactly equal. 00040 * 00041 * For binary STL files, the defacto standard is that they be written 00042 * with a little-endian byte order. The reader will attempt to 00043 * determine the byte order automatically, and if it is ambiguous, 00044 * will default to little-endian. The byte ordering may be forced by 00045 * by creating an integer tag named "__STL_BYTE_ORDER" and setting a 00046 * global/mesh value for the tag as 1 for big-endian or 0 for 00047 * little-endian. 00048 * 00049 * For binary files, this reader relies on the file size to determine 00050 * the validity of the file and may use it in guessing the byte order. 00051 * This should not be an issue, as the file size can be determined 00052 * exactly from the number of triangles for a valid file. However, if 00053 * for some reason the file is readable even though it is invalid (e.g. 00054 * it is some hybrid file with STL data in the beginning and some app- 00055 * specific data appended to the end of the file) the check on the file 00056 * size can be disabled by giving the reader a something other than a 00057 * regular file to read from. For example, on Unix-like systems, have 00058 * the reader read from a FIFO instead of a file: 00059 * mkfifo /tmp/fifo.stlb 00060 * cat my_binary_file.stlb > /tmp/fifo.stlb 00061 * and instruct the MOAB-based application to read from /tmp/fifo.stlb 00062 */ 00063 class ReadSTL : public ReaderIface 00064 { 00065 00066 public: 00067 //! factory method for STL reader 00068 static ReaderIface* factory( Interface* ); 00069 00070 //! Generic file loading code for both binary and ASCII readers. 00071 //! Calls reader-specific read_triangles function to do actual I/O. 00072 ErrorCode load_file( const char* file_name, 00073 const EntityHandle* file_set, 00074 const FileOptions& opts, 00075 const SubsetList* subset_list = 0, 00076 const Tag* file_id_tag = 0 ); 00077 00078 ErrorCode read_tag_values( const char* file_name, 00079 const char* tag_name, 00080 const FileOptions& opts, 00081 std::vector< int >& tag_values_out, 00082 const SubsetList* subset_list = 0 ); 00083 00084 //! Constructor 00085 ReadSTL( Interface* impl = NULL ); 00086 00087 //! Destructor 00088 virtual ~ReadSTL(); 00089 00090 // An object to hold vertex coordinates, and an operator 00091 // for storing them in a STL tree-based container. 00092 struct Point 00093 { 00094 float coords[3]; 00095 bool operator<( const Point& ) const; 00096 }; 00097 // Data returned by read_triangles. 00098 struct Triangle 00099 { 00100 Point points[3]; 00101 }; 00102 00103 enum ByteOrder 00104 { 00105 STL_BIG_ENDIAN, 00106 STL_LITTLE_ENDIAN, 00107 STL_UNKNOWN_BYTE_ORDER 00108 }; 00109 00110 protected: 00111 // I/O specific part of reader - read ASCII file 00112 ErrorCode ascii_read_triangles( const char* file_name, std::vector< Triangle >& tris_out ); 00113 00114 // I/O specific part of reader - read binary file 00115 ErrorCode binary_read_triangles( const char* file_name, ByteOrder byte_order, std::vector< Triangle >& tris_out ); 00116 00117 ReadUtilIface* readMeshIface; 00118 00119 //! interface instance 00120 Interface* mdbImpl; 00121 }; 00122 00123 } // namespace moab 00124 00125 #endif
