MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "SequenceData.hpp" 00002 #include "SysUtil.hpp" 00003 #include "VarLenTag.hpp" 00004 #include <cassert> 00005 00006 namespace moab 00007 { 00008 00009 SequenceData::~SequenceData() 00010 { 00011 for( int i = -numSequenceData; i <= (int)numTagData; ++i ) 00012 free( arraySet[i] ); 00013 free( arraySet - numSequenceData ); 00014 } 00015 00016 void* SequenceData::create_data( int index, int bytes_per_ent, const void* initial_value ) 00017 { 00018 char* array = (char*)malloc( bytes_per_ent * size() ); 00019 if( initial_value ) SysUtil::setmem( array, initial_value, bytes_per_ent, size() ); 00020 00021 arraySet[index] = array; 00022 return array; 00023 } 00024 00025 void* SequenceData::create_sequence_data( int array_num, int bytes_per_ent, const void* initial_value ) 00026 { 00027 const int index = -1 - array_num; 00028 assert( array_num < numSequenceData ); 00029 assert( !arraySet[index] ); 00030 return create_data( index, bytes_per_ent, initial_value ); 00031 } 00032 00033 void* SequenceData::create_custom_data( int array_num, size_t total_bytes ) 00034 { 00035 const int index = -1 - array_num; 00036 assert( array_num < numSequenceData ); 00037 assert( !arraySet[index] ); 00038 00039 void* array = malloc( total_bytes ); 00040 arraySet[index] = array; 00041 return array; 00042 } 00043 00044 SequenceData::AdjacencyDataType* SequenceData::allocate_adjacency_data() 00045 { 00046 assert( !arraySet[0] ); 00047 const size_t s = sizeof( AdjacencyDataType* ) * size(); 00048 arraySet[0] = malloc( s ); 00049 memset( arraySet[0], 0, s ); 00050 return reinterpret_cast< AdjacencyDataType* >( arraySet[0] ); 00051 } 00052 00053 void SequenceData::increase_tag_count( unsigned amount ) 00054 { 00055 void** list = arraySet - numSequenceData; 00056 const size_t sz = sizeof( void* ) * ( numSequenceData + numTagData + amount + 1 ); 00057 void** new_list = (void**)realloc( list, sz ); 00058 if( !new_list ) 00059 { 00060 fprintf( stderr, "SequenceData::increase_tag_count(): reallocation of list failed\n" ); 00061 // Note: free(list) will be called in the destructor 00062 return; 00063 } 00064 else 00065 list = new_list; 00066 arraySet = list + numSequenceData; 00067 memset( arraySet + numTagData + 1, 0, sizeof( void* ) * amount ); 00068 numTagData += amount; 00069 } 00070 00071 void* SequenceData::allocate_tag_array( int tag_num, int bytes_per_ent, const void* default_value ) 00072 { 00073 if( (unsigned)tag_num >= numTagData ) increase_tag_count( tag_num - numTagData + 1 ); 00074 00075 assert( !arraySet[tag_num + 1] ); 00076 return create_data( tag_num + 1, bytes_per_ent, default_value ); 00077 } 00078 00079 SequenceData* SequenceData::subset( EntityHandle start, EntityHandle end, const int* sequence_data_sizes ) const 00080 { 00081 return new SequenceData( this, start, end, sequence_data_sizes ); 00082 } 00083 00084 SequenceData::SequenceData( const SequenceData* from, 00085 EntityHandle start, 00086 EntityHandle end, 00087 const int* sequence_data_sizes ) 00088 : numSequenceData( from->numSequenceData ), numTagData( from->numTagData ), startHandle( start ), endHandle( end ) 00089 { 00090 assert( start <= end ); 00091 assert( from != 0 ); 00092 assert( from->start_handle() <= start ); 00093 assert( from->end_handle() >= end ); 00094 00095 void** array = (void**)malloc( sizeof( void* ) * ( numSequenceData + numTagData + 1 ) ); 00096 arraySet = array + numSequenceData; 00097 const size_t offset = start - from->start_handle(); 00098 const size_t count = end - start + 1; 00099 00100 for( int i = 0; i < numSequenceData; ++i ) 00101 copy_data_subset( -1 - i, sequence_data_sizes[i], from->get_sequence_data( i ), offset, count ); 00102 copy_data_subset( 0, sizeof( AdjacencyDataType* ), from->get_adjacency_data(), offset, count ); 00103 for( unsigned i = 1; i <= numTagData; ++i ) 00104 arraySet[i] = 0; 00105 } 00106 00107 void SequenceData::copy_data_subset( int index, int size_per_ent, const void* source, size_t offset, size_t count ) 00108 { 00109 if( !source ) 00110 arraySet[index] = 0; 00111 else 00112 { 00113 arraySet[index] = malloc( count * size_per_ent ); 00114 memcpy( arraySet[index], (const char*)source + offset * size_per_ent, count * size_per_ent ); 00115 } 00116 } 00117 00118 void SequenceData::move_tag_data( SequenceData* destination, const int* tag_sizes, int num_tag_sizes ) 00119 { 00120 assert( destination->start_handle() >= start_handle() ); 00121 assert( destination->end_handle() <= end_handle() ); 00122 const size_t offset = destination->start_handle() - start_handle(); 00123 const size_t count = destination->size(); 00124 if( destination->numTagData < numTagData ) destination->increase_tag_count( numTagData - destination->numTagData ); 00125 00126 for( unsigned i = 1; i <= numTagData; ++i ) 00127 { 00128 if( !arraySet[i] ) continue; 00129 00130 assert( i <= (unsigned)num_tag_sizes ); 00131 if( num_tag_sizes ) 00132 { 00133 } // empty line to prevent compiler warning 00134 00135 const int tag_size = tag_sizes[i - 1]; 00136 if( !destination->arraySet[i] ) destination->arraySet[i] = malloc( count * tag_size ); 00137 memcpy( destination->arraySet[i], reinterpret_cast< char* >( arraySet[i] ) + offset * tag_size, 00138 count * tag_size ); 00139 } 00140 } 00141 00142 void SequenceData::release_tag_data( const int* tag_sizes, int num_tag_sizes ) 00143 { 00144 assert( num_tag_sizes >= (int)numTagData ); 00145 if( num_tag_sizes ) 00146 { 00147 } // empty line to prevent compiler warning 00148 for( unsigned i = 0; i < numTagData; ++i ) 00149 release_tag_data( i, tag_sizes[i] ); 00150 } 00151 00152 void SequenceData::release_tag_data( int tag_num, int tag_size ) 00153 { 00154 if( (unsigned)tag_num < numTagData ) 00155 { 00156 if( tag_size == MB_VARIABLE_LENGTH && arraySet[tag_num + 1] ) 00157 { 00158 VarLenTag* iter = reinterpret_cast< VarLenTag* >( arraySet[tag_num + 1] ); 00159 VarLenTag* const end = iter + size(); 00160 for( ; iter != end; ++iter ) 00161 iter->clear(); 00162 } 00163 free( arraySet[tag_num + 1] ); 00164 arraySet[tag_num + 1] = 0; 00165 } 00166 } 00167 00168 } // namespace moab
