MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2012 Désiré Nuentsa-Wakam <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 /* 00011 * NOTE: This file comes from a partly modified version of files slu_[s,d,c,z]defs.h 00012 * -- SuperLU routine (version 4.1) -- 00013 * Univ. of California Berkeley, Xerox Palo Alto Research Center, 00014 * and Lawrence Berkeley National Lab. 00015 * November, 2010 00016 * 00017 * Global data structures used in LU factorization - 00018 * 00019 * nsuper: #supernodes = nsuper + 1, numbered [0, nsuper]. 00020 * (xsup,supno): supno[i] is the supernode no to which i belongs; 00021 * xsup(s) points to the beginning of the s-th supernode. 00022 * e.g. supno 0 1 2 2 3 3 3 4 4 4 4 4 (n=12) 00023 * xsup 0 1 2 4 7 12 00024 * Note: dfs will be performed on supernode rep. relative to the new 00025 * row pivoting ordering 00026 * 00027 * (xlsub,lsub): lsub[*] contains the compressed subscript of 00028 * rectangular supernodes; xlsub[j] points to the starting 00029 * location of the j-th column in lsub[*]. Note that xlsub 00030 * is indexed by column. 00031 * Storage: original row subscripts 00032 * 00033 * During the course of sparse LU factorization, we also use 00034 * (xlsub,lsub) for the purpose of symmetric pruning. For each 00035 * supernode {s,s+1,...,t=s+r} with first column s and last 00036 * column t, the subscript set 00037 * lsub[j], j=xlsub[s], .., xlsub[s+1]-1 00038 * is the structure of column s (i.e. structure of this supernode). 00039 * It is used for the storage of numerical values. 00040 * Furthermore, 00041 * lsub[j], j=xlsub[t], .., xlsub[t+1]-1 00042 * is the structure of the last column t of this supernode. 00043 * It is for the purpose of symmetric pruning. Therefore, the 00044 * structural subscripts can be rearranged without making physical 00045 * interchanges among the numerical values. 00046 * 00047 * However, if the supernode has only one column, then we 00048 * only keep one set of subscripts. For any subscript interchange 00049 * performed, similar interchange must be done on the numerical 00050 * values. 00051 * 00052 * The last column structures (for pruning) will be removed 00053 * after the numercial LU factorization phase. 00054 * 00055 * (xlusup,lusup): lusup[*] contains the numerical values of the 00056 * rectangular supernodes; xlusup[j] points to the starting 00057 * location of the j-th column in storage vector lusup[*] 00058 * Note: xlusup is indexed by column. 00059 * Each rectangular supernode is stored by column-major 00060 * scheme, consistent with Fortran 2-dim array storage. 00061 * 00062 * (xusub,ucol,usub): ucol[*] stores the numerical values of 00063 * U-columns outside the rectangular supernodes. The row 00064 * subscript of nonzero ucol[k] is stored in usub[k]. 00065 * xusub[i] points to the starting location of column i in ucol. 00066 * Storage: new row subscripts; that is subscripts of PA. 00067 */ 00068 00069 #ifndef EIGEN_LU_STRUCTS 00070 #define EIGEN_LU_STRUCTS 00071 namespace Eigen { 00072 namespace internal { 00073 00074 typedef enum {LUSUP, UCOL, LSUB, USUB, LLVL, ULVL} MemType; 00075 00076 template <typename IndexVector, typename ScalarVector> 00077 struct LU_GlobalLU_t { 00078 typedef typename IndexVector::Scalar StorageIndex; 00079 IndexVector xsup; //First supernode column ... xsup(s) points to the beginning of the s-th supernode 00080 IndexVector supno; // Supernode number corresponding to this column (column to supernode mapping) 00081 ScalarVector lusup; // nonzero values of L ordered by columns 00082 IndexVector lsub; // Compressed row indices of L rectangular supernodes. 00083 IndexVector xlusup; // pointers to the beginning of each column in lusup 00084 IndexVector xlsub; // pointers to the beginning of each column in lsub 00085 Index nzlmax; // Current max size of lsub 00086 Index nzlumax; // Current max size of lusup 00087 ScalarVector ucol; // nonzero values of U ordered by columns 00088 IndexVector usub; // row indices of U columns in ucol 00089 IndexVector xusub; // Pointers to the beginning of each column of U in ucol 00090 Index nzumax; // Current max size of ucol 00091 Index n; // Number of columns in the matrix 00092 Index num_expansions; 00093 }; 00094 00095 // Values to set for performance 00096 struct perfvalues { 00097 Index panel_size; // a panel consists of at most <panel_size> consecutive columns 00098 Index relax; // To control degree of relaxing supernodes. If the number of nodes (columns) 00099 // in a subtree of the elimination tree is less than relax, this subtree is considered 00100 // as one supernode regardless of the row structures of those columns 00101 Index maxsuper; // The maximum size for a supernode in complete LU 00102 Index rowblk; // The minimum row dimension for 2-D blocking to be used; 00103 Index colblk; // The minimum column dimension for 2-D blocking to be used; 00104 Index fillfactor; // The estimated fills factors for L and U, compared with A 00105 }; 00106 00107 } // end namespace internal 00108 00109 } // end namespace Eigen 00110 #endif // EIGEN_LU_STRUCTS
