MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef STRUCTURED_ELEMENT_SEQUENCE 00017 #define STRUCTURED_ELEMENT_SEQUENCE 00018 00019 // 00020 // Class: StructuredElementSeq 00021 // 00022 // Purpose: represent a rectangular element of mesh 00023 // 00024 // A ScdElement represents a rectangular element of mesh, including both vertices and 00025 // elements, and the parametric space used to address that element. Vertex data, 00026 // i.e. coordinates, may not be stored directly in the element, but the element returns 00027 // information about the vertex handles of vertices in the element. Vertex and element 00028 // handles associated with the element are each contiguous. 00029 00030 #include "ElementSequence.hpp" 00031 #include "ScdElementData.hpp" 00032 00033 namespace moab 00034 { 00035 00036 class StructuredElementSeq : public ElementSequence 00037 { 00038 public: 00039 //! constructor 00040 StructuredElementSeq( EntityHandle start_handle, 00041 const int imin, 00042 const int jmin, 00043 const int kmin, 00044 const int imax, 00045 const int jmax, 00046 const int kmax, 00047 int* is_periodic = NULL ); 00048 00049 virtual ~StructuredElementSeq(); 00050 00051 ScdElementData* sdata() 00052 { 00053 return reinterpret_cast< ScdElementData* >( data() ); 00054 } 00055 ScdElementData const* sdata() const 00056 { 00057 return reinterpret_cast< const ScdElementData* >( data() ); 00058 } 00059 00060 //! get handle of vertex at i, j, k 00061 EntityHandle get_vertex( const int i, const int j, const int k ) const 00062 { 00063 return get_vertex( HomCoord( i, j, k ) ); 00064 } 00065 00066 //! get handle of vertex at homogeneous coords 00067 inline EntityHandle get_vertex( const HomCoord& coords ) const 00068 { 00069 return sdata()->get_vertex( coords ); 00070 } 00071 00072 //! get handle of element at i, j, k 00073 EntityHandle get_element( const int i, const int j, const int k ) const 00074 { 00075 return sdata()->get_element( i, j, k ); 00076 } 00077 00078 //! get handle of element at homogeneous coords 00079 EntityHandle get_element( const HomCoord& coords ) const 00080 { 00081 return sdata()->get_element( coords.i(), coords.j(), coords.k() ); 00082 } 00083 00084 //! get min params for this element 00085 const HomCoord& min_params() const 00086 { 00087 return sdata()->min_params(); 00088 } 00089 void min_params( HomCoord& coords ) const 00090 { 00091 coords = min_params(); 00092 } 00093 void min_params( int& i, int& j, int& k ) const 00094 { 00095 i = min_params().i(); 00096 j = min_params().j(); 00097 k = min_params().k(); 00098 } 00099 00100 //! get max params for this element 00101 const HomCoord& max_params() const 00102 { 00103 return sdata()->max_params(); 00104 } 00105 void max_params( HomCoord& coords ) const 00106 { 00107 coords = max_params(); 00108 } 00109 void max_params( int& i, int& j, int& k ) const 00110 { 00111 i = max_params().i(); 00112 j = max_params().j(); 00113 k = max_params().k(); 00114 } 00115 00116 //! get the number of vertices in each direction, inclusive 00117 void param_extents( int& di, int& dj, int& dk ) const 00118 { 00119 sdata()->param_extents( di, dj, dk ); 00120 } 00121 00122 //! given a handle, get the corresponding parameters 00123 ErrorCode get_params( const EntityHandle ehandle, int& i, int& j, int& k ) const 00124 { 00125 return sdata()->get_params( ehandle, i, j, k ); 00126 } 00127 00128 //! convenience functions for parameter extents 00129 int i_min() const 00130 { 00131 return min_params().i(); 00132 } 00133 int j_min() const 00134 { 00135 return min_params().j(); 00136 } 00137 int k_min() const 00138 { 00139 return min_params().k(); 00140 } 00141 int i_max() const 00142 { 00143 return max_params().i(); 00144 } 00145 int j_max() const 00146 { 00147 return max_params().j(); 00148 } 00149 int k_max() const 00150 { 00151 return max_params().k(); 00152 } 00153 00154 //! test the bounding vertex sequences and determine whether they fully 00155 //! define the vertices covering this element block's parameter space 00156 inline bool boundary_complete() const 00157 { 00158 return sdata()->boundary_complete(); 00159 } 00160 00161 //! test whether this sequence contains these parameters 00162 bool contains( const int i, const int j, const int k ) const 00163 { 00164 return sdata()->contains( HomCoord( i, j, k ) ); 00165 } 00166 inline bool contains( const HomCoord& coords ) const 00167 { 00168 return sdata()->contains( coords ); 00169 } 00170 00171 //! get connectivity of an entity given entity's parameters 00172 ErrorCode get_params_connectivity( const int i, 00173 const int j, 00174 const int k, 00175 std::vector< EntityHandle >& connectivity ) const 00176 { 00177 return sdata()->get_params_connectivity( i, j, k, connectivity ); 00178 } 00179 00180 //! Return whether box is periodic in i 00181 /** Return whether box is periodic in i 00182 * \return True if box is periodic in i direction 00183 */ 00184 int is_periodic_i() const 00185 { 00186 return sdata()->is_periodic_i(); 00187 }; 00188 00189 //! Return whether box is periodic in j 00190 /** Return whether box is periodic in j 00191 * \return True if box is periodic in j direction 00192 */ 00193 int is_periodic_j() const 00194 { 00195 return sdata()->is_periodic_j(); 00196 }; 00197 00198 //! Return whether box is periodic in i and j 00199 /** Return whether box is periodic in i and j 00200 * \param is_periodic_ij Non-zero if periodic in i [0] or j [1] 00201 */ 00202 void is_periodic( int is_periodic_ij[2] ) const 00203 { 00204 sdata()->is_periodic( is_periodic_ij ); 00205 }; 00206 00207 /***************** Methods from ElementSequence *****************/ 00208 00209 virtual ErrorCode get_connectivity( EntityHandle handle, 00210 std::vector< EntityHandle >& connect, 00211 bool topological = false ) const; 00212 00213 virtual ErrorCode get_connectivity( EntityHandle handle, 00214 EntityHandle const*& connect, 00215 int& connect_length, 00216 bool topological = false, 00217 std::vector< EntityHandle >* storage = 0 ) const; 00218 00219 virtual ErrorCode set_connectivity( EntityHandle handle, EntityHandle const* connect, int connect_length ); 00220 00221 virtual EntityHandle* get_connectivity_array(); 00222 00223 /***************** Methods from EntitySequence *****************/ 00224 00225 /* Replace the ElementSequence implementation of this method with 00226 * one that always returns zero, because we cannot re-use handles 00227 * that are within a ScdElementData 00228 */ 00229 virtual int values_per_entity() const; 00230 00231 virtual EntitySequence* split( EntityHandle here ); 00232 00233 virtual SequenceData* create_data_subset( EntityHandle start_handle, EntityHandle end_handle ) const; 00234 00235 virtual void get_const_memory_use( unsigned long& bytes_per_entity, unsigned long& size_of_sequence ) const; 00236 00237 protected: 00238 StructuredElementSeq( StructuredElementSeq& split_from, EntityHandle here ) : ElementSequence( split_from, here ) {} 00239 }; 00240 00241 } // namespace moab 00242 00243 #endif
