MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2008 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef SWEPT_ELEMENT_SEQUENCE 00017 #define SWEPT_ELEMENT_SEQUENCE 00018 00019 // 00020 // Class: SweptElementSequence 00021 // 00022 // Purpose: represent a swept element of mesh 00023 // 00024 00025 #include "ElementSequence.hpp" 00026 #include "ScdElementData.hpp" 00027 00028 namespace moab 00029 { 00030 00031 class SweptElementSeq : public ElementSequence 00032 { 00033 public: 00034 //! constructor 00035 SweptElementSeq( EntityHandle start_handle, 00036 const int imin, 00037 const int jmin, 00038 const int kmin, 00039 const int imax, 00040 const int jmax, 00041 const int kmax, 00042 const int* Cq ); 00043 00044 virtual ~SweptElementSeq(); 00045 00046 ScdElementData* sdata() 00047 { 00048 return reinterpret_cast< ScdElementData* >( data() ); 00049 } 00050 ScdElementData const* sdata() const 00051 { 00052 return reinterpret_cast< const ScdElementData* >( data() ); 00053 } 00054 00055 //! get handle of vertex at i, j, k 00056 EntityHandle get_vertex( const int i, const int j, const int k ) const 00057 { 00058 return get_vertex( HomCoord( i, j, k ) ); 00059 } 00060 00061 //! get handle of vertex at homogeneous coords 00062 inline EntityHandle get_vertex( const HomCoord& coords ) const 00063 { 00064 return sdata()->get_vertex( coords ); 00065 } 00066 00067 //! get handle of element at i, j, k 00068 EntityHandle get_element( const int i, const int j, const int k ) const 00069 { 00070 return sdata()->get_element( i, j, k ); 00071 } 00072 00073 //! get handle of element at homogeneous coords 00074 EntityHandle get_element( const HomCoord& coords ) const 00075 { 00076 return sdata()->get_element( coords.i(), coords.j(), coords.k() ); 00077 } 00078 00079 //! get min params for this element 00080 const HomCoord& min_params() const 00081 { 00082 return sdata()->min_params(); 00083 } 00084 void min_params( HomCoord& coords ) const 00085 { 00086 coords = min_params(); 00087 } 00088 void min_params( int& i, int& j, int& k ) const 00089 { 00090 i = min_params().i(); 00091 j = min_params().j(); 00092 k = min_params().k(); 00093 } 00094 00095 //! get max params for this element 00096 const HomCoord& max_params() const 00097 { 00098 return sdata()->max_params(); 00099 } 00100 void max_params( HomCoord& coords ) const 00101 { 00102 coords = max_params(); 00103 } 00104 void max_params( int& i, int& j, int& k ) const 00105 { 00106 i = max_params().i(); 00107 j = max_params().j(); 00108 k = max_params().k(); 00109 } 00110 00111 //! get the number of vertices in each direction, inclusive 00112 void param_extents( int& di, int& dj, int& dk ) const 00113 { 00114 sdata()->param_extents( di, dj, dk ); 00115 } 00116 00117 //! given a handle, get the corresponding parameters 00118 ErrorCode get_params( const EntityHandle ehandle, int& i, int& j, int& k ) const 00119 { 00120 return sdata()->get_params( ehandle, i, j, k ); 00121 } 00122 00123 //! convenience functions for parameter extents 00124 int i_min() const 00125 { 00126 return min_params().i(); 00127 } 00128 int j_min() const 00129 { 00130 return min_params().j(); 00131 } 00132 int k_min() const 00133 { 00134 return min_params().k(); 00135 } 00136 int i_max() const 00137 { 00138 return max_params().i(); 00139 } 00140 int j_max() const 00141 { 00142 return max_params().j(); 00143 } 00144 int k_max() const 00145 { 00146 return max_params().k(); 00147 } 00148 00149 //! test the bounding vertex sequences and determine whether they fully 00150 //! define the vertices covering this element block's parameter space 00151 inline bool boundary_complete() const 00152 { 00153 return sdata()->boundary_complete(); 00154 } 00155 00156 //! test whether this sequence contains these parameters 00157 bool contains( const int i, const int j, const int k ) const 00158 { 00159 return sdata()->contains( HomCoord( i, j, k ) ); 00160 } 00161 inline bool contains( const HomCoord& coords ) const 00162 { 00163 return sdata()->contains( coords ); 00164 } 00165 00166 //! get connectivity of an entity given entity's parameters 00167 ErrorCode get_params_connectivity( const int i, 00168 const int j, 00169 const int k, 00170 std::vector< EntityHandle >& connectivity ) const 00171 { 00172 return sdata()->get_params_connectivity( i, j, k, connectivity ); 00173 } 00174 00175 /***************** Methods from ElementSeq *****************/ 00176 00177 virtual ErrorCode get_connectivity( EntityHandle handle, 00178 std::vector< EntityHandle >& connect, 00179 bool topological = false ) const; 00180 00181 virtual ErrorCode get_connectivity( EntityHandle handle, 00182 EntityHandle const*& connect, 00183 int& connect_length, 00184 bool topological = false, 00185 std::vector< EntityHandle >* storage = 0 ) const; 00186 00187 virtual ErrorCode set_connectivity( EntityHandle handle, EntityHandle const* connect, int connect_length ); 00188 00189 virtual EntityHandle* get_connectivity_array(); 00190 00191 /***************** Methods from EntitySequence *****************/ 00192 00193 /* Replace the ElementSequence implementation of this method with 00194 * one that always returns zero, because we cannot re-use handles 00195 * that are within a ScdElementData 00196 */ 00197 virtual int values_per_entity() const; 00198 00199 virtual EntitySequence* split( EntityHandle here ); 00200 00201 virtual SequenceData* create_data_subset( EntityHandle start_handle, EntityHandle end_handle ) const; 00202 00203 virtual void get_const_memory_use( unsigned long& bytes_per_entity, unsigned long& size_of_sequence ) const; 00204 00205 protected: 00206 SweptElementSeq( SweptElementSeq& split_from, EntityHandle here ) : ElementSequence( split_from, here ) {} 00207 }; 00208 00209 } // namespace moab 00210 00211 #endif
