MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef WRITE_CGNS_HPP 00017 #define WRITE_CGNS_HPP 00018 00019 #include "moab/Forward.hpp" 00020 #include "moab/WriterIface.hpp" 00021 #include <cstdio> 00022 00023 // Junior 00024 #include "cgnslib.h" 00025 #include "moab/Range.hpp" 00026 00027 // Junior 00028 #if CGNS_VERSION < 3100 00029 #define cgsize_t int 00030 #else 00031 #if CG_BUILD_SCOPE 00032 #error enumeration scoping needs to be off 00033 #endif 00034 #endif 00035 00036 namespace moab 00037 { 00038 00039 class WriteUtilIface; 00040 00041 /** 00042 * \brief Export CGNS files. 00043 * \author Carlos Junqueira Junior 00044 */ 00045 00046 class WriteCGNS : public WriterIface 00047 { 00048 00049 public: 00050 //! factory method 00051 static WriterIface* factory( Interface* ); 00052 00053 //! Constructor 00054 WriteCGNS( Interface* impl ); 00055 00056 //! Destructor 00057 virtual ~WriteCGNS(); 00058 00059 // A structure to store Set information. 00060 class SetStruct 00061 { 00062 public: 00063 std::string TagName; // Tag name 00064 cgsize_t IdSet; // Id of the Set 00065 cgsize_t NbEdges; // Number of Edges in the Set 00066 cgsize_t NbFaces; // Number of Faces in the Set 00067 cgsize_t NbCells; // Number of Cells in the Set 00068 // vector with the number of entities in the Sets 00069 // 0-MBEDGE | 1-MBTRI | 2-MBQUAD | 3-MBTET | 4-MBPYRAMID | 5-MBPRISM | 6-MBHEX 00070 std::vector< cgsize_t > NbEntities; 00071 ElementType_t CGNSType; 00072 00073 SetStruct() : IdSet( -1 ), NbEdges( 0 ), NbFaces( 0 ), NbCells( 0 ){}; 00074 ~SetStruct(){}; 00075 }; 00076 00077 //! writes out a file 00078 ErrorCode write_file( const char* file_name, 00079 const bool overwrite, 00080 const FileOptions& opts, 00081 const EntityHandle* output_list, 00082 const int num_sets, 00083 const std::vector< std::string >& qa_list, 00084 const Tag* tag_list = NULL, 00085 int num_tags = 0, 00086 int export_dimension = 3 ); 00087 00088 // Get and count vertex entities 00089 ErrorCode get_vertex_entities( cgsize_t& VrtSize, std::vector< moab::EntityHandle >& Nodes ); 00090 00091 // Get and count edge entities 00092 ErrorCode get_edge_entities( cgsize_t& EdgeSize, std::vector< moab::EntityHandle >& Edges ); 00093 00094 // Get and count face entities 00095 ErrorCode get_face_entities( cgsize_t& FaceSize, std::vector< moab::EntityHandle >& Faces ); 00096 00097 // Get and count cell entities 00098 ErrorCode get_cell_entities( cgsize_t& CellSize, std::vector< moab::EntityHandle >& Cells ); 00099 00100 // Write coordinates in the cgns file 00101 ErrorCode write_coord_cgns( std::vector< moab::EntityHandle >& nodes ); 00102 00103 // Set Tag values on entities 00104 ErrorCode set_tag_values( std::vector< moab::Tag >& TagHandles, 00105 std::vector< moab::EntityHandle >& Edges, 00106 std::vector< moab::EntityHandle >& Faces, 00107 std::vector< moab::EntityHandle >& Cells, 00108 std::vector< WriteCGNS::SetStruct >& Sets ); 00109 00110 // Get Entities in the set 00111 ErrorCode get_set_entities( int i, 00112 std::vector< moab::Tag >& TagHandles, 00113 std::vector< WriteCGNS::SetStruct >& Sets ); 00114 00115 // Get the CGNSType 00116 ErrorCode get_cgns_type( int i, std::vector< WriteCGNS::SetStruct >& Sets ); 00117 00118 // Get the connectivity table 00119 ErrorCode get_conn_table( std::vector< moab::EntityHandle >& Elements, 00120 std::vector< int >& Begin, 00121 std::vector< int >& End, 00122 std::vector< moab::Tag >& TagHandles, 00123 std::vector< WriteCGNS::SetStruct >& Sets, 00124 std::vector< std::vector< cgsize_t > >& ConnTable ); 00125 00126 // Read the Moab type and return CGNS type 00127 int moab_cgns_conv( const EntityHandle handle ); 00128 00129 private: 00130 // interface instance 00131 Interface* mbImpl; 00132 WriteUtilIface* mWriteIface; 00133 00134 // File var 00135 const char* fileName; 00136 int IndexFile; 00137 00138 // Base var 00139 const char* BaseName; 00140 int IndexBase; 00141 00142 // Zone var 00143 const char* ZoneName; 00144 int IndexZone; 00145 00146 // Section var 00147 int IndexSection; 00148 00149 // Coordinates var 00150 int IndexCoord[3]; 00151 00152 // Mesh dimension 00153 int celldim; 00154 int physdim; 00155 cgsize_t isize[3]; 00156 00157 // Entities of mesh 00158 std::vector< moab::EntityHandle > Nodes; 00159 std::vector< moab::EntityHandle > Edges; 00160 std::vector< moab::EntityHandle > Faces; 00161 std::vector< moab::EntityHandle > Cells; 00162 00163 // Number of entities in the mesh 00164 cgsize_t VrtSize; 00165 cgsize_t EdgeSize; 00166 cgsize_t FaceSize; 00167 cgsize_t CellSize; 00168 }; 00169 00170 } // namespace moab 00171 00172 #endif
