MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2007 Julien Pommier 00005 // Copyright (C) 2009 Gael Guennebaud <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 /* The sin, cos, exp, and log functions of this file come from 00012 * Julien Pommier's sse math library: http://gruntthepeon.free.fr/ssemath/ 00013 */ 00014 00015 #ifndef EIGEN_MATH_FUNCTIONS_ALTIVEC_H 00016 #define EIGEN_MATH_FUNCTIONS_ALTIVEC_H 00017 00018 namespace Eigen { 00019 00020 namespace internal { 00021 00022 template<> EIGEN_DEFINE_FUNCTION_ALLOWING_MULTIPLE_DEFINITIONS EIGEN_UNUSED 00023 Packet4f plog<Packet4f>(const Packet4f& _x) 00024 { 00025 Packet4f x = _x; 00026 _EIGEN_DECLARE_CONST_Packet4f(1 , 1.0f); 00027 _EIGEN_DECLARE_CONST_Packet4f(half, 0.5f); 00028 _EIGEN_DECLARE_CONST_Packet4i(0x7f, 0x7f); 00029 _EIGEN_DECLARE_CONST_Packet4i(23, 23); 00030 00031 _EIGEN_DECLARE_CONST_Packet4f_FROM_INT(inv_mant_mask, ~0x7f800000); 00032 00033 /* the smallest non denormalized float number */ 00034 _EIGEN_DECLARE_CONST_Packet4f_FROM_INT(min_norm_pos, 0x00800000); 00035 _EIGEN_DECLARE_CONST_Packet4f_FROM_INT(minus_inf, 0xff800000); // -1.f/0.f 00036 _EIGEN_DECLARE_CONST_Packet4f_FROM_INT(minus_nan, 0xffffffff); 00037 00038 /* natural logarithm computed for 4 simultaneous float 00039 return NaN for x <= 0 00040 */ 00041 _EIGEN_DECLARE_CONST_Packet4f(cephes_SQRTHF, 0.707106781186547524f); 00042 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p0, 7.0376836292E-2f); 00043 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p1, - 1.1514610310E-1f); 00044 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p2, 1.1676998740E-1f); 00045 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p3, - 1.2420140846E-1f); 00046 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p4, + 1.4249322787E-1f); 00047 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p5, - 1.6668057665E-1f); 00048 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p6, + 2.0000714765E-1f); 00049 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p7, - 2.4999993993E-1f); 00050 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_p8, + 3.3333331174E-1f); 00051 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_q1, -2.12194440e-4f); 00052 _EIGEN_DECLARE_CONST_Packet4f(cephes_log_q2, 0.693359375f); 00053 00054 00055 Packet4i emm0; 00056 00057 /* isvalid_mask is 0 if x < 0 or x is NaN. */ 00058 Packet4ui isvalid_mask = reinterpret_cast<Packet4ui>(vec_cmpge(x, p4f_ZERO)); 00059 Packet4ui iszero_mask = reinterpret_cast<Packet4ui>(vec_cmpeq(x, p4f_ZERO)); 00060 00061 x = pmax(x, p4f_min_norm_pos); /* cut off denormalized stuff */ 00062 emm0 = vec_sr(reinterpret_cast<Packet4i>(x), 00063 reinterpret_cast<Packet4ui>(p4i_23)); 00064 00065 /* keep only the fractional part */ 00066 x = pand(x, p4f_inv_mant_mask); 00067 x = por(x, p4f_half); 00068 00069 emm0 = psub(emm0, p4i_0x7f); 00070 Packet4f e = padd(vec_ctf(emm0, 0), p4f_1); 00071 00072 /* part2: 00073 if( x < SQRTHF ) { 00074 e -= 1; 00075 x = x + x - 1.0; 00076 } else { x = x - 1.0; } 00077 */ 00078 Packet4f mask = reinterpret_cast<Packet4f>(vec_cmplt(x, p4f_cephes_SQRTHF)); 00079 Packet4f tmp = pand(x, mask); 00080 x = psub(x, p4f_1); 00081 e = psub(e, pand(p4f_1, mask)); 00082 x = padd(x, tmp); 00083 00084 Packet4f x2 = pmul(x,x); 00085 Packet4f x3 = pmul(x2,x); 00086 00087 Packet4f y, y1, y2; 00088 y = pmadd(p4f_cephes_log_p0, x, p4f_cephes_log_p1); 00089 y1 = pmadd(p4f_cephes_log_p3, x, p4f_cephes_log_p4); 00090 y2 = pmadd(p4f_cephes_log_p6, x, p4f_cephes_log_p7); 00091 y = pmadd(y , x, p4f_cephes_log_p2); 00092 y1 = pmadd(y1, x, p4f_cephes_log_p5); 00093 y2 = pmadd(y2, x, p4f_cephes_log_p8); 00094 y = pmadd(y, x3, y1); 00095 y = pmadd(y, x3, y2); 00096 y = pmul(y, x3); 00097 00098 y1 = pmul(e, p4f_cephes_log_q1); 00099 tmp = pmul(x2, p4f_half); 00100 y = padd(y, y1); 00101 x = psub(x, tmp); 00102 y2 = pmul(e, p4f_cephes_log_q2); 00103 x = padd(x, y); 00104 x = padd(x, y2); 00105 // negative arg will be NAN, 0 will be -INF 00106 x = vec_sel(x, p4f_minus_inf, iszero_mask); 00107 x = vec_sel(p4f_minus_nan, x, isvalid_mask); 00108 return x; 00109 } 00110 00111 template<> EIGEN_DEFINE_FUNCTION_ALLOWING_MULTIPLE_DEFINITIONS EIGEN_UNUSED 00112 Packet4f pexp<Packet4f>(const Packet4f& _x) 00113 { 00114 Packet4f x = _x; 00115 _EIGEN_DECLARE_CONST_Packet4f(1 , 1.0f); 00116 _EIGEN_DECLARE_CONST_Packet4f(half, 0.5f); 00117 _EIGEN_DECLARE_CONST_Packet4i(0x7f, 0x7f); 00118 _EIGEN_DECLARE_CONST_Packet4i(23, 23); 00119 00120 00121 _EIGEN_DECLARE_CONST_Packet4f(exp_hi, 88.3762626647950f); 00122 _EIGEN_DECLARE_CONST_Packet4f(exp_lo, -88.3762626647949f); 00123 00124 _EIGEN_DECLARE_CONST_Packet4f(cephes_LOG2EF, 1.44269504088896341f); 00125 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_C1, 0.693359375f); 00126 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_C2, -2.12194440e-4f); 00127 00128 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_p0, 1.9875691500E-4f); 00129 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_p1, 1.3981999507E-3f); 00130 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_p2, 8.3334519073E-3f); 00131 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_p3, 4.1665795894E-2f); 00132 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_p4, 1.6666665459E-1f); 00133 _EIGEN_DECLARE_CONST_Packet4f(cephes_exp_p5, 5.0000001201E-1f); 00134 00135 Packet4f tmp, fx; 00136 Packet4i emm0; 00137 00138 // clamp x 00139 x = vec_max(vec_min(x, p4f_exp_hi), p4f_exp_lo); 00140 00141 /* express exp(x) as exp(g + n*log(2)) */ 00142 fx = pmadd(x, p4f_cephes_LOG2EF, p4f_half); 00143 00144 fx = vec_floor(fx); 00145 00146 tmp = pmul(fx, p4f_cephes_exp_C1); 00147 Packet4f z = pmul(fx, p4f_cephes_exp_C2); 00148 x = psub(x, tmp); 00149 x = psub(x, z); 00150 00151 z = pmul(x,x); 00152 00153 Packet4f y = p4f_cephes_exp_p0; 00154 y = pmadd(y, x, p4f_cephes_exp_p1); 00155 y = pmadd(y, x, p4f_cephes_exp_p2); 00156 y = pmadd(y, x, p4f_cephes_exp_p3); 00157 y = pmadd(y, x, p4f_cephes_exp_p4); 00158 y = pmadd(y, x, p4f_cephes_exp_p5); 00159 y = pmadd(y, z, x); 00160 y = padd(y, p4f_1); 00161 00162 // build 2^n 00163 emm0 = vec_cts(fx, 0); 00164 emm0 = vec_add(emm0, p4i_0x7f); 00165 emm0 = vec_sl(emm0, reinterpret_cast<Packet4ui>(p4i_23)); 00166 00167 // Altivec's max & min operators just drop silent NaNs. Check NaNs in 00168 // inputs and return them unmodified. 00169 Packet4ui isnumber_mask = reinterpret_cast<Packet4ui>(vec_cmpeq(_x, _x)); 00170 return vec_sel(_x, pmax(pmul(y, reinterpret_cast<Packet4f>(emm0)), _x), 00171 isnumber_mask); 00172 } 00173 00174 #ifdef __VSX__ 00175 // VSX support varies between different compilers and even different 00176 // versions of the same compiler. For gcc version >= 4.9.3, we can use 00177 // vec_cts to efficiently convert Packet2d to Packet2l. Otherwise, use 00178 // a slow version that works with older compilers. 00179 static inline Packet2l ConvertToPacket2l(const Packet2d& x) { 00180 #if EIGEN_GNUC_AT_LEAST(5, 0) || \ 00181 (EIGEN_GNUC_AT(4, 9) && __GNUC_PATCHLEVEL__ >= 3) 00182 return vec_cts(x, 0); // TODO: check clang version. 00183 #else 00184 double tmp[2]; 00185 memcpy(tmp, &x, sizeof(tmp)); 00186 Packet2l l = { static_cast<long long>(tmp[0]), 00187 static_cast<long long>(tmp[1]) }; 00188 return l; 00189 #endif 00190 } 00191 00192 template<> EIGEN_DEFINE_FUNCTION_ALLOWING_MULTIPLE_DEFINITIONS EIGEN_UNUSED 00193 Packet2d pexp<Packet2d>(const Packet2d& _x) 00194 { 00195 Packet2d x = _x; 00196 00197 _EIGEN_DECLARE_CONST_Packet2d(1 , 1.0); 00198 _EIGEN_DECLARE_CONST_Packet2d(2 , 2.0); 00199 _EIGEN_DECLARE_CONST_Packet2d(half, 0.5); 00200 00201 _EIGEN_DECLARE_CONST_Packet2d(exp_hi, 709.437); 00202 _EIGEN_DECLARE_CONST_Packet2d(exp_lo, -709.436139303); 00203 00204 _EIGEN_DECLARE_CONST_Packet2d(cephes_LOG2EF, 1.4426950408889634073599); 00205 00206 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_p0, 1.26177193074810590878e-4); 00207 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_p1, 3.02994407707441961300e-2); 00208 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_p2, 9.99999999999999999910e-1); 00209 00210 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_q0, 3.00198505138664455042e-6); 00211 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_q1, 2.52448340349684104192e-3); 00212 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_q2, 2.27265548208155028766e-1); 00213 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_q3, 2.00000000000000000009e0); 00214 00215 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_C1, 0.693145751953125); 00216 _EIGEN_DECLARE_CONST_Packet2d(cephes_exp_C2, 1.42860682030941723212e-6); 00217 00218 Packet2d tmp, fx; 00219 Packet2l emm0; 00220 00221 // clamp x 00222 x = pmax(pmin(x, p2d_exp_hi), p2d_exp_lo); 00223 /* express exp(x) as exp(g + n*log(2)) */ 00224 fx = pmadd(p2d_cephes_LOG2EF, x, p2d_half); 00225 00226 fx = vec_floor(fx); 00227 00228 tmp = pmul(fx, p2d_cephes_exp_C1); 00229 Packet2d z = pmul(fx, p2d_cephes_exp_C2); 00230 x = psub(x, tmp); 00231 x = psub(x, z); 00232 00233 Packet2d x2 = pmul(x,x); 00234 00235 Packet2d px = p2d_cephes_exp_p0; 00236 px = pmadd(px, x2, p2d_cephes_exp_p1); 00237 px = pmadd(px, x2, p2d_cephes_exp_p2); 00238 px = pmul (px, x); 00239 00240 Packet2d qx = p2d_cephes_exp_q0; 00241 qx = pmadd(qx, x2, p2d_cephes_exp_q1); 00242 qx = pmadd(qx, x2, p2d_cephes_exp_q2); 00243 qx = pmadd(qx, x2, p2d_cephes_exp_q3); 00244 00245 x = pdiv(px,psub(qx,px)); 00246 x = pmadd(p2d_2,x,p2d_1); 00247 00248 // build 2^n 00249 emm0 = ConvertToPacket2l(fx); 00250 00251 #ifdef __POWER8_VECTOR__ 00252 static const Packet2l p2l_1023 = { 1023, 1023 }; 00253 static const Packet2ul p2ul_52 = { 52, 52 }; 00254 00255 emm0 = vec_add(emm0, p2l_1023); 00256 emm0 = vec_sl(emm0, p2ul_52); 00257 #else 00258 // Code is a bit complex for POWER7. There is actually a 00259 // vec_xxsldi intrinsic but it is not supported by some gcc versions. 00260 // So we shift (52-32) bits and do a word swap with zeros. 00261 _EIGEN_DECLARE_CONST_Packet4i(1023, 1023); 00262 _EIGEN_DECLARE_CONST_Packet4i(20, 20); // 52 - 32 00263 00264 Packet4i emm04i = reinterpret_cast<Packet4i>(emm0); 00265 emm04i = vec_add(emm04i, p4i_1023); 00266 emm04i = vec_sl(emm04i, reinterpret_cast<Packet4ui>(p4i_20)); 00267 static const Packet16uc perm = { 00268 0x14, 0x15, 0x16, 0x17, 0x00, 0x01, 0x02, 0x03, 00269 0x1c, 0x1d, 0x1e, 0x1f, 0x08, 0x09, 0x0a, 0x0b }; 00270 #ifdef _BIG_ENDIAN 00271 emm0 = reinterpret_cast<Packet2l>(vec_perm(p4i_ZERO, emm04i, perm)); 00272 #else 00273 emm0 = reinterpret_cast<Packet2l>(vec_perm(emm04i, p4i_ZERO, perm)); 00274 #endif 00275 00276 #endif 00277 00278 // Altivec's max & min operators just drop silent NaNs. Check NaNs in 00279 // inputs and return them unmodified. 00280 Packet2ul isnumber_mask = reinterpret_cast<Packet2ul>(vec_cmpeq(_x, _x)); 00281 return vec_sel(_x, pmax(pmul(x, reinterpret_cast<Packet2d>(emm0)), _x), 00282 isnumber_mask); 00283 } 00284 #endif 00285 00286 } // end namespace internal 00287 00288 } // end namespace Eigen 00289 00290 #endif // EIGEN_MATH_FUNCTIONS_ALTIVEC_H
