AveragingQMTest Member List
This is the complete list of members for AveragingQMTest, including all inherited members.
check_average_and_weights(const double *vals, unsigned n, QualityMetric::AveragingMethod method, const double *weights)AveragingQMTest [private]
check_average_and_weights_fails(QualityMetric::AveragingMethod scheme)AveragingQMTest [private]
check_average_gradient_fails(QualityMetric::AveragingMethod scheme)AveragingQMTest [private]
check_average_gradients(QualityMetric::AveragingMethod scheme)AveragingQMTest [private]
check_hessian_diagonal_fails(QualityMetric::AveragingMethod scheme)AveragingQMTest [private]
check_hessian_fails(QualityMetric::AveragingMethod scheme)AveragingQMTest [private]
check_pmean_hessian(QualityMetric::AveragingMethod scheme, double inner_power, double outer_power, bool scale)AveragingQMTest [private]
check_pmean_hessian_diagonals(QualityMetric::AveragingMethod scheme, double inner_power, double outer_power, bool scale)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_liner)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_rms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_hms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_minimum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_maximum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_harmonic)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_geometric)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_sum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_sum_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_standard_deviation)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_max_over_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_max_minus_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_metrics_sum_of_ratios_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_linear)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_rms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_hms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_minimum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_maximum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_harmonic)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_geometric)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_sum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_sum_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_standard_deviation)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_max_over_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_max_minus_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_and_weights_sum_of_ratios_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_linear)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_rms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_hms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_minimum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_maximum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_harmonic)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_geometric)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_sum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_sum_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_standard_deviation)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_max_over_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_max_minus_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_gradients_sum_of_ratios_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_linear)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_rms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_hms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_minimum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_maximum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_harmonic)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_geometric)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_sum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_sum_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_standard_deviation)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_max_over_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_max_minus_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessians_sum_of_ratios_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_linear)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_rms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_hms)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_minimum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_maximum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_harmonic)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_geometric)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_sum)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_sum_squared)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_standard_deviation)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_max_over_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_max_minus_min)AveragingQMTest [private]
CPPUNIT_TEST(test_average_corner_hessian_diagonals_sum_of_ratios_squared)AveragingQMTest [private]
CPPUNIT_TEST_SUITE(AveragingQMTest)AveragingQMTest [private]
CPPUNIT_TEST_SUITE_END()AveragingQMTest [private]
LEN_LIST_1AveragingQMTest [private, static]
LEN_LIST_2AveragingQMTest [private, static]
test_average_and_weights_geometric()AveragingQMTest
test_average_and_weights_harmonic()AveragingQMTest
test_average_and_weights_hms()AveragingQMTest
test_average_and_weights_linear()AveragingQMTest
test_average_and_weights_max_minus_min()AveragingQMTest
test_average_and_weights_max_over_min()AveragingQMTest
test_average_and_weights_maximum()AveragingQMTest
test_average_and_weights_minimum()AveragingQMTest
test_average_and_weights_rms()AveragingQMTest
test_average_and_weights_standard_deviation()AveragingQMTest
test_average_and_weights_sum()AveragingQMTest
test_average_and_weights_sum_of_ratios_squared()AveragingQMTest
test_average_and_weights_sum_squared()AveragingQMTest
test_average_corner_gradients_geometric()AveragingQMTest
test_average_corner_gradients_harmonic()AveragingQMTest
test_average_corner_gradients_hms()AveragingQMTest
test_average_corner_gradients_linear()AveragingQMTest
test_average_corner_gradients_max_minus_min()AveragingQMTest
test_average_corner_gradients_max_over_min()AveragingQMTest
test_average_corner_gradients_maximum()AveragingQMTest
test_average_corner_gradients_minimum()AveragingQMTest
test_average_corner_gradients_rms()AveragingQMTest
test_average_corner_gradients_standard_deviation()AveragingQMTest
test_average_corner_gradients_sum()AveragingQMTest
test_average_corner_gradients_sum_of_ratios_squared()AveragingQMTest
test_average_corner_gradients_sum_squared()AveragingQMTest
test_average_corner_hessian_diagonals_geometric()AveragingQMTest
test_average_corner_hessian_diagonals_harmonic()AveragingQMTest
test_average_corner_hessian_diagonals_hms()AveragingQMTest
test_average_corner_hessian_diagonals_linear()AveragingQMTest
test_average_corner_hessian_diagonals_max_minus_min()AveragingQMTest
test_average_corner_hessian_diagonals_max_over_min()AveragingQMTest
test_average_corner_hessian_diagonals_maximum()AveragingQMTest
test_average_corner_hessian_diagonals_minimum()AveragingQMTest
test_average_corner_hessian_diagonals_rms()AveragingQMTest
test_average_corner_hessian_diagonals_standard_deviation()AveragingQMTest
test_average_corner_hessian_diagonals_sum()AveragingQMTest
test_average_corner_hessian_diagonals_sum_of_ratios_squared()AveragingQMTest
test_average_corner_hessian_diagonals_sum_squared()AveragingQMTest
test_average_corner_hessians_geometric()AveragingQMTest
test_average_corner_hessians_harmonic()AveragingQMTest
test_average_corner_hessians_hms()AveragingQMTest
test_average_corner_hessians_linear()AveragingQMTest
test_average_corner_hessians_max_minus_min()AveragingQMTest
test_average_corner_hessians_max_over_min()AveragingQMTest
test_average_corner_hessians_maximum()AveragingQMTest
test_average_corner_hessians_minimum()AveragingQMTest
test_average_corner_hessians_rms()AveragingQMTest
test_average_corner_hessians_standard_deviation()AveragingQMTest
test_average_corner_hessians_sum()AveragingQMTest
test_average_corner_hessians_sum_of_ratios_squared()AveragingQMTest
test_average_corner_hessians_sum_squared()AveragingQMTest
test_average_metrics_geometric()AveragingQMTest
test_average_metrics_harmonic()AveragingQMTest
test_average_metrics_hms()AveragingQMTest
test_average_metrics_liner()AveragingQMTest
test_average_metrics_max_minus_min()AveragingQMTest
test_average_metrics_max_over_min()AveragingQMTest
test_average_metrics_maximum()AveragingQMTest
test_average_metrics_minimum()AveragingQMTest
test_average_metrics_rms()AveragingQMTest
test_average_metrics_standard_deviation()AveragingQMTest
test_average_metrics_sum()AveragingQMTest
test_average_metrics_sum_of_ratios_squared()AveragingQMTest
test_average_metrics_sum_squared()AveragingQMTest
VAL_LIST_1AveragingQMTest [private, static]
VAL_LIST_2AveragingQMTest [private, static]
