CompareMetric Member List
This is the complete list of members for CompareMetric, including all inherited members.
AveragingMethod enum nameMBMesquite::QualityMetric
CompareMetric(QualityMetric *qm1, QualityMetric *qm2, bool mask_qm2_coord=false)CompareMetric [inline]
ELEMENT_BASED enum valueMBMesquite::QualityMetric
epsilonCompareMetric [private, static]
equal(Vector3D grad1, const Vector3D &grad2) const CompareMetric
equal(SymMatrix3D hess1, const SymMatrix3D &hess2) const CompareMetric
equal(Matrix3D hess1, const Matrix3D &hess2) const CompareMetric
evaluate(PatchData &pd, size_t handle, double &value, MsqError &err)CompareMetric [virtual]
evaluate_with_gradient(PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)CompareMetric [virtual]
evaluate_with_Hessian(PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)CompareMetric [virtual]
evaluate_with_Hessian_diagonal(PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< SymMatrix3D > &Hessian_diagonal, MsqError &err)CompareMetric [virtual]
evaluate_with_indices(PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)CompareMetric [virtual]
fixed_vertex_bitmap(PatchData &pd, const MsqMeshEntity *elem, std::vector< size_t > &free_indices)MBMesquite::QualityMetric [static]
GEOMETRIC enum valueMBMesquite::QualityMetric
get_evaluations(PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)CompareMetric [virtual]
get_mask_axis(PatchData &pd)CompareMetric
get_metric_type() const CompareMetric [virtual]
get_name() const CompareMetric [virtual]
get_negate_flag() const CompareMetric [virtual]
get_single_pass(PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)MBMesquite::QualityMetric [virtual]
HARMONIC enum valueMBMesquite::QualityMetric
HMS enum valueMBMesquite::QualityMetric
initialize_queue(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)MBMesquite::QualityMetric [virtual]
LAST_WITH_GRADIENT enum valueMBMesquite::QualityMetric
LAST_WITH_HESSIAN enum valueMBMesquite::QualityMetric
LINEAR enum valueMBMesquite::QualityMetric
m2DiagCompareMetric [private]
m2GradCompareMetric [private]
m2HandlesCompareMetric [private]
m2HessCompareMetric [private]
maskAxisCompareMetric [private]
maskPlaneCompareMetric [private]
MAX_MINUS_MIN enum valueMBMesquite::QualityMetric
MAX_OVER_MIN enum valueMBMesquite::QualityMetric
MAXIMUM enum valueMBMesquite::QualityMetric
metric1CompareMetric [private]
metric2CompareMetric [private]
MetricType enum nameMBMesquite::QualityMetric
MINIMUM enum valueMBMesquite::QualityMetric
QualityMetric()MBMesquite::QualityMetric [inline, protected]
remove_fixed_diagonals(EntityTopology type, uint32_t fixed_vertices, std::vector< Vector3D > &gradients, std::vector< SymMatrix3D > &hess_diagonal_blocks)MBMesquite::QualityMetric [static]
remove_fixed_gradients(EntityTopology type, uint32_t fixed_vertices, std::vector< Vector3D > &gradients)MBMesquite::QualityMetric [static]
remove_fixed_hessians(EntityTopology type, uint32_t fixed_vertices, std::vector< Matrix3D > &hessians)MBMesquite::QualityMetric [static]
RMS enum valueMBMesquite::QualityMetric
STANDARD_DEVIATION enum valueMBMesquite::QualityMetric
SUM enum valueMBMesquite::QualityMetric
SUM_OF_RATIOS_SQUARED enum valueMBMesquite::QualityMetric
SUM_SQUARED enum valueMBMesquite::QualityMetric
vertex_barrier_function(double det, double delta)MBMesquite::QualityMetric [inline, static]
VERTEX_BASED enum valueMBMesquite::QualityMetric
weighted_average_metrics(const double coef[], const double metric_values[], const int &num_values, MsqError &err)MBMesquite::QualityMetric
~QualityMetric()MBMesquite::QualityMetric [inline, virtual]
