, including all inherited members.
| _check_template_params() | Eigen::PlainObjectBase< Derived > | [inline, static] |
| _init1(Index size, typename internal::enable_if< (Base::SizeAtCompileTime!=1||!internal::is_convertible< T, Scalar >::value)&&((!internal::is_same< typename internal::traits< Derived >::XprKind, ArrayXpr >::value||Base::SizeAtCompileTime==Dynamic)), T >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const Scalar &val0, typename internal::enable_if< Base::SizeAtCompileTime==1 &&internal::is_convertible< T, Scalar >::value, T >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const Index &val0, typename internal::enable_if< (!internal::is_same< Index, Scalar >::value)&&(internal::is_same< Index, T >::value)&&Base::SizeAtCompileTime==1 &&internal::is_convertible< T, Scalar >::value, T * >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const Scalar *data) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const EigenBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const ReturnByValue< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const RotationBase< OtherDerived, ColsAtCompileTime > &r) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const Scalar &val0, typename internal::enable_if< Base::SizeAtCompileTime!=Dynamic &&Base::SizeAtCompileTime!=1 &&internal::is_convertible< T, Scalar >::value &&internal::is_same< typename internal::traits< Derived >::XprKind, ArrayXpr >::value, T >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init1(const Index &val0, typename internal::enable_if< (!internal::is_same< Index, Scalar >::value)&&(internal::is_same< Index, T >::value)&&Base::SizeAtCompileTime!=Dynamic &&Base::SizeAtCompileTime!=1 &&internal::is_convertible< T, Scalar >::value &&internal::is_same< typename internal::traits< Derived >::XprKind, ArrayXpr >::value, T * >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init2(Index rows, Index cols, typename internal::enable_if< Base::SizeAtCompileTime!=2, T0 >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init2(const Scalar &val0, const Scalar &val1, typename internal::enable_if< Base::SizeAtCompileTime==2, T0 >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _init2(const Index &val0, const Index &val1, typename internal::enable_if< (!internal::is_same< Index, Scalar >::value)&&(internal::is_same< T0, Index >::value)&&(internal::is_same< T1, Index >::value)&&Base::SizeAtCompileTime==2, T1 >::type *=0) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _resize_to_match(const EigenBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _set(const DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| _set_noalias(const DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| AlignedMapType typedef | Eigen::PlainObjectBase< Derived > | |
| Base typedef | Eigen::PlainObjectBase< Derived > | |
| base() | Eigen::PlainObjectBase< Derived > | [inline] |
| base() const | Eigen::PlainObjectBase< Derived > | [inline] |
| coeff(Index rowId, Index colId) const | Eigen::PlainObjectBase< Derived > | [inline] |
| coeff(Index index) const | Eigen::PlainObjectBase< Derived > | [inline] |
| coeffRef(Index rowId, Index colId) | Eigen::PlainObjectBase< Derived > | [inline] |
| coeffRef(Index index) | Eigen::PlainObjectBase< Derived > | [inline] |
| coeffRef(Index rowId, Index colId) const | Eigen::PlainObjectBase< Derived > | [inline] |
| coeffRef(Index index) const | Eigen::PlainObjectBase< Derived > | [inline] |
| cols() const | Eigen::PlainObjectBase< Derived > | [inline] |
| conservativeResize(Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline] |
| conservativeResize(Index rows, NoChange_t) | Eigen::PlainObjectBase< Derived > | [inline] |
| conservativeResize(NoChange_t, Index cols) | Eigen::PlainObjectBase< Derived > | [inline] |
| conservativeResize(Index size) | Eigen::PlainObjectBase< Derived > | [inline] |
| conservativeResizeLike(const DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline] |
| ConstAlignedMapType typedef | Eigen::PlainObjectBase< Derived > | |
| ConstMapType typedef | Eigen::PlainObjectBase< Derived > | |
| data() const | Eigen::PlainObjectBase< Derived > | [inline] |
| data() | Eigen::PlainObjectBase< Derived > | [inline] |
| DenseType typedef | Eigen::PlainObjectBase< Derived > | |
| Eigen::Map class | Eigen::PlainObjectBase< Derived > | [friend] |
| Eigen::Map< const Derived, Unaligned > class | Eigen::PlainObjectBase< Derived > | [friend] |
| Eigen::Map< Derived, Unaligned > class | Eigen::PlainObjectBase< Derived > | [friend] |
| internal::matrix_swap_impl | Eigen::PlainObjectBase< Derived > | [friend] |
| IsPlainObjectBase enum value | Eigen::PlainObjectBase< Derived > | |
| lazyAssign(const DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline] |
| m_storage | Eigen::PlainObjectBase< Derived > | [protected] |
| Map(const Scalar *data) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(Scalar *data) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(const Scalar *data, Index size) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(Scalar *data, Index size) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(const Scalar *data, Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(Scalar *data, Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(const Scalar *data, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(Scalar *data, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(const Scalar *data, Index size, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(Scalar *data, Index size, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(const Scalar *data, Index rows, Index cols, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| Map(Scalar *data, Index rows, Index cols, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(const Scalar *data) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(Scalar *data) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(const Scalar *data, Index size) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(Scalar *data, Index size) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(const Scalar *data, Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(Scalar *data, Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(const Scalar *data, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(Scalar *data, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(const Scalar *data, Index size, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(Scalar *data, Index size, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(const Scalar *data, Index rows, Index cols, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| MapAligned(Scalar *data, Index rows, Index cols, const Stride< Outer, Inner > &stride) | Eigen::PlainObjectBase< Derived > | [inline, static] |
| NeedsToAlign enum value | Eigen::PlainObjectBase< Derived > | |
| operator=(const PlainObjectBase &other) | Eigen::PlainObjectBase< Derived > | [inline] |
| operator=(const ReturnByValue< OtherDerived > &func) | Eigen::PlainObjectBase< Derived > | [inline] |
| operator=(const EigenBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline] |
| Options enum value | Eigen::PlainObjectBase< Derived > | |
| packet(Index rowId, Index colId) const | Eigen::PlainObjectBase< Derived > | [inline] |
| packet(Index index) const | Eigen::PlainObjectBase< Derived > | [inline] |
| PacketScalar typedef | Eigen::PlainObjectBase< Derived > | |
| PlainObjectBase() | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| PlainObjectBase(internal::constructor_without_unaligned_array_assert) | Eigen::PlainObjectBase< Derived > | [inline, explicit, protected] |
| PlainObjectBase(const PlainObjectBase &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| PlainObjectBase(Index size, Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| PlainObjectBase(const DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| PlainObjectBase(const EigenBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| PlainObjectBase(const ReturnByValue< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline, protected] |
| RealScalar typedef | Eigen::PlainObjectBase< Derived > | |
| resize(Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | [inline] |
| resize(Index size) | Eigen::PlainObjectBase< Derived > | [inline] |
| resize(NoChange_t, Index cols) | Eigen::PlainObjectBase< Derived > | [inline] |
| resize(Index rows, NoChange_t) | Eigen::PlainObjectBase< Derived > | [inline] |
| resizeLike(const EigenBase< OtherDerived > &_other) | Eigen::PlainObjectBase< Derived > | [inline] |
| rows() const | Eigen::PlainObjectBase< Derived > | [inline] |
| setConstant(Index size, const Scalar &val) | Eigen::PlainObjectBase< Derived > | |
| setConstant(Index rows, Index cols, const Scalar &val) | Eigen::PlainObjectBase< Derived > | |
| setOnes(Index size) | Eigen::PlainObjectBase< Derived > | |
| setOnes(Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | |
| setRandom(Index size) | Eigen::PlainObjectBase< Derived > | |
| setRandom(Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | |
| setZero(Index size) | Eigen::PlainObjectBase< Derived > | |
| setZero(Index rows, Index cols) | Eigen::PlainObjectBase< Derived > | |
| StorageKind typedef | Eigen::PlainObjectBase< Derived > | |
| swap(DenseBase< OtherDerived > &other) | Eigen::PlainObjectBase< Derived > | [inline] |
| swap(DenseBase< OtherDerived > const &other) | Eigen::PlainObjectBase< Derived > | [inline] |
| writePacket(Index rowId, Index colId, const PacketScalar &val) | Eigen::PlainObjectBase< Derived > | [inline] |
| writePacket(Index index, const PacketScalar &val) | Eigen::PlainObjectBase< Derived > | [inline] |
